3 Replies Latest reply on Feb 20, 2014 12:11 PM by Guy Lev
    Ball crossing around screen with if else
    Guy Lev
      Hi There
      I wish to make a ball go across the screen ( eventually it will be clouds )
      I wish that the ball will reach the end of the screen anf then do the animation again.
      This is the code I have written but the part that doesn't work is the part inside the else....
      Guy Lev
      Israel AUGM
      //setting the initial position of the ball
      var xpos = -100;
      // calling the symbol from library
      var myball = sym.createChildSymbol("ball", "Stage");
      //referencing the symbol
      var myballsym = myball.getSymbolElement();
      //setting the left posistion according tho the xpos var
      myballsym.css({"position":"relative","left":xpos});
      //checking the position of the ball
      if ( xpos <=200 ) {
      myballsym.animate({ "left": "400px" }, 2000);
      }else  {
      var xpos = -100;
        • 1. Re: Ball crossing around screen with if else
          Guy Lev Level 1
          I did manage to do that the ball goes back to the initial position  - but the loop part doesn't really work like that....
          There must be another way of writning that...
          var xpos = -100;
          if ( xpos <=200 ) {
          myballsym.animate({ "left": "400px" }, 2000, function(){
          var xpos = 100;
          • 2. Re: Ball crossing around screen with if else
            SimonDBench Level 1
            Give this a try.
            animationComplete()
            function animationComplete(){
                      myballsym.css({"position":"relative","left":-100});
                      var animation = myballsym.animate({ "left": "400px" }, 2000, animationComplete);
            The end function resets and triggers the animation so you end up with a loop when you call the animationComplete function.
            Simon
            • 3. Re: Ball crossing around screen with if else
              Guy Lev Level 1
              Great!
              Exactly what I need
              thanks again!!!
