3 Replies Latest reply on Feb 22, 2014 9:40 AM by hemanthR
    How to integrate Edge Animation in slideshow (not create slideshow with EA) ?
    LtAl64
      I'd like to integrate an animation I create into the theme slideshow, but can't find how :/
      Would greatly appreciate some help here.
      Cheers
        • 1. Re: How to integrate Edge Animation in slideshow (not create slideshow with EA) ?
          hemanthR Adobe Employee
          If your are creating a slide show in a html page you will need to just copy the below mentioned contents to you page  from the HMTL page exported from Animate
          1. The first , in the "<header> part of the page content wrapped inside the following comment tags:
          <!--Adobe Edge Runtime-->
          <!--Adobe Edge Runtime End-->
          Put this inside the page you are trying to add the animation to, making sure it is inside the <header></header> tags in your page.
          2. The second ,  inside the <body> tags of the html file exported by animate and is wrapped inside a <div></div> tag.  It will look something like this:
          <div id="Stage" class="EDGE-54038123"></div>
          Put this at the position where you want the animation to play in your page
          • 2. Re: How to integrate Edge Animation in slideshow (not create slideshow with EA) ?
            LtAl64 Level 1
            Thanks a lot for a reply.
            However, I can't find the right place to add the second so as it works. Could you please help me out ? :/
            Here is the code of the section-slideshow.php, where should I add it ? :
            <?php
            // Get Slides
            global $gpp, $post;
            $slides = $gpp['slide_show'];
            $images = explode( ',', $slides );
            <?php
            //    Homepage Slideshow
            if ( '' <> $gpp['slide_show'] && isset($gpp['slideshow_enabled']) && $gpp['slideshow_enabled'] == 'yes' || '' <> $gpp['slide_show'] && isset( $gpp['slideshow_enabled'])  && $gpp['slideshow_enabled'] == 'yes' ) { ?>
            <div id="home-slider-wrap">
            <div id="home-slider">
                    <div class="flexslider home-slider">
                <ul class="slides">
                            <?php
                            foreach( $images as $id ) {
                                $attachment_caption = get_post_field('post_excerpt', $id);
                                $attachment_title = get_post_field('post_title', $id);
                                $attachment_button = get_post_meta( $id, '_gpp_slider_button_title', true );
                                $attachment_url = get_post_meta( $id, '_gpp_custom_url', true );
                                <li>
            <div class="slide <?php if ( empty( $attachment_title ) ) echo "slide-no-title" ?>">
            <?php echo wp_get_attachment_image( $id, "slide", 0 ); ?>
                                        <?php if ( ! empty ( $attachment_title ) || ! empty ( $attachment_caption ) ) { ?>
                                            <div class="flex-caption">
                                                <?php if ( ! empty ( $attachment_title ) ) { ?>
                                                    <h2 class="home-slide-title">
                                                        <?php echo $attachment_title; ?>
                                                    </h2>
                                                <?php } ?>
                                                <?php if ( ! empty ( $attachment_caption ) ) {
                                                    echo '<p class="slider-caption">' . $attachment_caption . '</p>'; } ?>
                                                <?php if ( ! empty ( $attachment_button ) ) { ?>
                                                    <h3 class="slide-button"><a href="<?php echo $attachment_url; ?>"><?php echo $attachment_button; ?></a></h3>
                                                <?php } ?>
                                        <?php } ?>
                                            </div>
                                    </div>
                                </li>
                            <?php } ?>
                        </ul> <!-- .slides -->
                    </div> <!-- .flexslider -->
                </div> <!-- #home-slider -->
            </div>
            <?php } ?>
            • 3. Re: How to integrate Edge Animation in slideshow (not create slideshow with EA) ?
              I am not very sure how  the flexslider works nor that php code in the page.But by guess is ,you could try inserting edge animate stage div  as another list <li>  item.
