4 Replies Latest reply on Feb 23, 2014 1:18 AM by Peter Grainge
    root.fpj gets corrupted
    Krischu Level 1
      When using RH9 with the file structure located on a network drive we are getting all sorts of errors with reading or writing root.fpj.
      In the end, root.fpj is left corrupted/truncated and you are lucky when you have made a backup.
      This happens right in the moment when you want to add a new theme (CTRL-T). Once you have added the theme and you want to leave RH 9 you are getting a window, saying
      Beim Speichern von Daten in
      <H:\Robohelp_deutsch\Robohelp-Projekte\Version-1.2.-folder\SomeFolder\Company-123\XYZ-000\ root.fpj <5> ist ein Fehler aufgetreten.
      Clicking OK give the same error but with a <1>
      Then the same text, but while reading, and then you can kiss goodbye to your root.fpj
      Christoph
