1. Re: Unhappy with System
ECBowen Feb 20, 2014 12:37 PM (in response to rsukhram@tgioa.com)The GPU's wont help AE much but I would definitely switch to a 780Ti for Premiere if you have the PSU that can handle it. AE should be fine with that amount of ram and 2x 8 core unless those Xeons are under 2.6Ghz in which case they would be poor for editing.
Eric
ADK
2. Re: Unhappy with System
Bill Gehrke Feb 20, 2014 12:42 PM (in response to rsukhram@tgioa.com)If you are unhappy with all that expensive hardware I would recommend that you test your hardware software setup with our Premiere Pro BenchMark (PPBM) Use the PPBM7 Project and Statistics files.
Message was edited by: Bill Gehrke
3. Re: Unhappy with System
rsukhram@tgioa.com Feb 20, 2014 12:46 PM (in response to ECBowen)thanks Eric,
the xeons are E5-2670 (2.6GHz)
I have a Antec HPC 1300 watt PSU. How many displays does the 780Ti support? Would I benefit in Premiere if I setup 2 780Ti's?
Also where do you think i am lacking for AE to perform since its not the GPU? could it be the Xeons?
4. Re: Unhappy with System
rsukhram@tgioa.com Feb 20, 2014 12:49 PM (in response to Bill Gehrke)ok never ran this before. I will run. Should I post back anything here?
5. Re: Unhappy with System
ECBowen Feb 20, 2014 1:21 PM (in response to rsukhram@tgioa.com)2x 780Ti would not help the realtime performance. Only the export performance would be effected. The Xeons @ 2.6GHz is low for 8 cores but should be able to handle what threads well. Do you have the Multiprocessing enabled and enable that for Ram preview as well.
Eric
ADK
6. Re: Unhappy with System
Bill Gehrke Feb 20, 2014 5:03 PM (in response to rsukhram@tgioa.com)If you register on the site you can see the results page. The fastest system recorded is a dual Xeon system and with your Speccy program you can see the configuration. It has the E5-2687W @ 3.1 GHz CPU's but the major difference is the Areca RAID controller rather than the Maximus GPU's
7. Re: Unhappy with System
tronit Feb 21, 2014 6:35 AM (in response to ECBowen)Hi
I think i might use your adivice on a computer build,
I just got an offer for a computer build with these specs:
CoolerMaster Case HAF X CPU Core i7-4770K Quad 3.5GHz LGA 1150 8MB Box ASUS SABERTOOTH Z87, Intel Socket 1150 1x GeForce GTX780 3GB GDDR5 HDMI 4x DIMM 8GB DDR3 2133MHz Kingston HyperX XMP Beast (32gb Total) 2x SSD 2.5" Samsung 840 Pro 256GB SATA3 540MB/s CoolerMaster Silent Pro M II 850W 80plus Cooler Master Seidon 240, Seidon 240 I'ts costing me somewhere around 2200euros
I mainly work with 3ds Max with Vray Renderer, and Adobe Creative Suite CS6 Products,Premiere, After Effects, Illustrator, Photoshop and Flash.
What do you think, will this setup do fine on my workflow, or should i try and move on with any quadro graphic card.
Currently I'm working on old PC
Dual Quad Core
2x Intel Xeon e5440 @ 2.83 GHz8 Gb Ram
And a very poor graphic card GeForce GT 610 : (Thank you in adnvace.
8. Re: Unhappy with System
rsukhram@tgioa.com Feb 21, 2014 6:54 AM (in response to ECBowen)initially i did not. Adobe gave me these setting yesterday. Let me know if you think there is anything I should alter. I know my caching should not be on the same drive as the OS (I am installing a dedicated 1 TB drive for this today)
Im going to do a re-format of my SSD today and start from scratch.
Also in regard to hyper threading should I enable or disable? I have 16 physical cores (32 with HT) bu ti heard this halves the speed of the CPU.
9. Re: Unhappy with System
ECBowen Feb 21, 2014 8:04 AM (in response to rsukhram@tgioa.com)Move the media cache off the OS drive. Uncheck the Box under the AE Multiprocessing where it says only for render q.
Eric
ADK
10. Re: Unhappy with System
rsukhram@tgioa.com Feb 24, 2014 6:14 AM (in response to Bill Gehrke)Good morning Bill,
I downloaded and ran the test file (PPBM7-DE) and did all the timelines as per the instruction but I cannot get the "Statistics PPBM7-v3" file to run. I am using Win 8.1. Is there a reccomended program to runt this file?
Also I got a snapshot of my system from that speccy program.
11. Re: Unhappy with System
Bill Gehrke Feb 24, 2014 7:22 AM (in response to rsukhram@tgioa.com)When you say that you cannot the Statistics file to run what does the system tell you?
