3 Replies Latest reply on Feb 21, 2014 6:56 AM by jsavage77
    Strange crash after exporting PDF...
    jsavage77 Level 1
      I have a script with the following at the end:
      var pathName = "~/Desktop/salesChartEMC.pdf";
      var saveName = new File (pathName);
      saveOpts = new PDFSaveOptions();
      saveOpts.compatibility = PDFCompatibility.ACROBAT5;
      saveOpts.generateThumbnails = true;
      saveOpts.preserveEditability = true;
      templateFile.saveAs(saveName, saveOpts);
      templateFile.close(SaveOptions.DONOTSAVECHANGES);
      alert("PDF successfully saved as "+pathName);
         The script keeps crashing at the templateFile.close(...) line.  If I comment out that line, the script works without crashing and I can switch back and forth between open documents and work as normally.  However, as soon as I manually close the PDF that is still open, Illustrator crashes again.  Has anyone run into this behavior before?
