15 Replies Latest reply on Feb 20, 2014 11:33 PM by BigMFishing
    Quicktime application
    BigMFishing
      I just got my PC back from being repaired. I have re-installed both Photoshop Elements 11 and Premiere Elements 11
      I just need to download quicktime for my Windows 7. Which Quicktime should I download? I do not remember which quicktime I had previously before PC had Problems. Any help will be greatly appreciated.
                      Thank you,
                                         Marvin Engel
                           Big M's Fishing Charters LLC
        • 1. Re: Quicktime application
          the_wine_snob Level 9
          Marvin,
          I would download, and install the very latest version.
          I have not read of any of the recent versions causing any issues with Adobe programs, like happened back about 7.4.x, where 2 - 3 versions in a row were highly problematic. I stayed with 7.3.5, and waited until I got great reports on 7.5.5, before upgrading. Nothing like that seems to be happening now.
          • 2. Re: Quicktime application
            A.T. Romano Level 7
            Marvin Engel
            There is only one QuickTime version for the Windows user, that is, its 32 bit application, whether or not your Windows is 32 or 64 bit.
            The link to the QuickTime 7.7.4 latest version is
            https://www.apple.com/quicktime/download/
            Please let us know if the download and install of QuickTime was a success.
            Thanks.
            ATR
            • 3. Re: Quicktime application
              A.T. Romano Level 7
              Marvin Engel
              I just saw Hunt's post after I had posted mine.
              QuickTime 7.7.4 will work just fine for you.
              ATR
              • 4. Re: Quicktime application
                BigMFishing Level 1
                Thanks for the Information Bill.
                • 5. Re: Quicktime application
                  ATR,
                  While I have not upgraded to 7.4.4, I have read of zero issues with it, like I saw back in the 7.4.x days.
                  There are sources for earlier versions, but if the latest is working with Adobe programs, I do not recommend that one go back in time.
                  Soon, I will probably upgrade, but until I need to, I will keep my 7.6.9 Pro on my computers. I feel the same way regarding iTunes - I will keep what works for me, and not just blindly upgrade to the "newer version," until I find a need to do so.
                  • 6. Re: Quicktime application
                    Marvin,
                    You are most welcome.
                    Please let us know if you ever have an issue with Apple's QT Player. Those reports warned many to ignore the 7.4.x versions, if they had Adobe programs, but that was some years ago now.
                    Happy editing,
                    • 7. Re: Quicktime application
                      A.T. Romano Level 7
                      From what you wrote, it sounds like you do not work from QuickTime (the non Pro, free variety). Is that correct?
                      ATR
                      • 8. Re: Quicktime application
                        BigMFishing Level 1
                        Yes Sir AT.
                        I just use it so I can view other videos that are sent to me from some of
                        my buddies. When I was re-installing Premiere Elements 11 earlier today, a
                        notification came up saying I would need to install quicktime to view
                        videos. That is when I remembered I did not know what version I previously
                        had on this Laptop. I sent my Laptop off for repairs. The left click button
                        stuck down and I had an issue with the COM Surrogate. It kept saying COM
                        Surrogate has stopped working when I would want to view my photos, and
                        Videos. Seems to be working great now. Thank God I backed up all my files,
                        documents, etc., on my External Hardrive. I purchased the WD 1TB External
                        Hardrive.
                        On quick time 7.4.4, how do you use it besides what I am using it for. I am
                        totally not familiar with quick time at all.
                                          Marvin
                        • 9. Re: Quicktime application
                          A.T. Romano Level 7
                          Marvin
                          Thanks for the update and asking about QuickTime (non pro, free).
                          If you wanted to export your Timeline content to a .mov (QuickTime) file via Publish+Share/Computer/QuickTime, you would discover missing components which allow for the export unless you had QuickTime installed on your computer with Premiere Elements. There are other activities requiring the presense of QuickTime on your computer when working with Premiere Elements (any version).
                          Under certain circumstances, the absence of QuickTime has resulted in miscellaneous negative explained and unexplained  effects in Premiere Elements.
                          Whenever we troubleshoot, the first two classical questions are
                          a. Do you have the latest version of QuickTime installed
                          and
                          b. Are you running the program as Run As Administrator and from User Account with Administrative Privileges
                          and
                          c Other, which is probably is the video card driver version up to date.
                          QuickTime like Premiere Elements requires Administrator permissions.
                          One never has enough backups. So it looks like you are doing well with that.
                          I have never run into the COM Surrogate issue. So, I did some Googling on it and found the following.
                          http://helpdeskgeek.com/help-desk/fix-com-surrogate-has-stopped-working-in-windows-7/
                          I would be a little guarded about codec approach, but...
                          More later.
                          ATR
                          • 10. Re: Quicktime application
                            BigMFishing Level 1
                            I have never had any problems with the quick time. I always thought it was
                            some type of driver software used to just view video's and slideshows that
                            were sent to me, or to be able to view online vids.
                            On the COM surrogate issue, I did go online and try to correct it, but none
                            of the information to resolve it would correct it. Since I got my laptop
                            back from HP Repair center in Grapevine Texas, everything seems to be
                            working fine so far. What would happen is if I clicked like say on my
                            pictures folder and used the right arrow at bottom of screen to go to the
                            next pic it would turn the screen to a hazy white and freeze up, then the
                            COM Surrogate would pop up saying it had stopped working. It would give me
                            to choices wait for program to respond (which it never did) or close the
                            program which I would have to do. I had never even heard if this issue ever
                            until about three weeks ago. I need to learn more on how to use quick time
                            7.4.4
                            I really appreciate the information on quick time and the link on COM
                            Surrogate. I will check the link out.
                                        Thank you,
                                                         Marvin Engel
                            • 11. Re: Quicktime application
                              BigMFishing Level 1
                              AT.
                              The link you provided is the exact same link I used to try to correct the
                              issue. I tried two of the steps and stopped there. I was afraid I would
                              wipe out all my videos and pics before I was able to copy all files to
                              external hard drive.
                              • 12. Re: Quicktime application
                                A.T. Romano Level 7
                                Marvin
                                Where are you seeing the right arrow at bottom of screen? Do you mean the arrow keys of the computer keyboard?
                                If you are not referring to the keyboard's arrow keys, could you post a screenshot of the arrow to which you refer?
                                Some times these remedies cause more problems than the original problem. So, good that you are cautious.
                                Thanks.
                                ATR
                                • 13. Re: Quicktime application
                                  BigMFishing Level 1
                                  I should have been more specific. My Fault.
                                  It is the left and right arrow keys under each pic I have in a documents
                                  pic folder.The ones that you probably use on your PC when you scroll
                                  through several pics. I would use these arrow keys so I would not have to
                                  close the pic and go back and click on the next pic to open it up. When the
                                  COM Surrogate would come up on the pics, it would happen when I would go to
                                  the next pic or even sometimes when I would click on pic to view in full
                                  screen. (I still do not know what COM Surrogate does or how it works) I
                                  know the tech with HP told me that it would take a Complete System Reboot
                                  or System Bios Reboot to wipe out and re-install correctly. He did ask me
                                  if the Blue Screen ever came up and I told him not with this issue. (When
                                  Java had their problems early last year, I did have Blue Screen pop up
                                  System Bios and had to send my laptop off to get repaired. Froze up on Blue
                                  Screen and it was locked there)
                                  On the Video's, it would just appear sometimes at the start of the vid or
                                  middle or close to end. I just never knew what part of video it would come
                                  up and stop working. But both the pics and video's are working fine now. I
                                  can even click the arrows to go to next pic rapidly and it is working just
                                  fine so far.
                                  • 14. Re: Quicktime application
                                    A.T. Romano Level 7
                                    Marvin
                                    That was great news. I misunderstood. I thought that the COM Surrogate problem still existed.
                                    We will keep positive thoughts that the issue is gone as a result of the computer repairs.
                                    Thanks for the update and clarification.
                                    ATR
                                    • 15. Re: Quicktime application
                                      BigMFishing Level 1
                                      No problem AT. If is run into any more issues I will let you know.
                                                  Thank you,
                                                            Marvin Engel
