7 Replies Latest reply on Mar 5, 2014 1:05 PM by KodsSpyd
    Cursor position offset for input fields (within an iFrame) only on Apple iPad
    KodsSpyd
      Hello, I have made an animation that after it completes, it displays an iFrame which has some input fields.  The input fields behave great on a laptop pc or mac but when I use an Apple iPad, the cursor positions are way off outside of the input fields as I type.
      Here is the website page: http://pbpromos.com/ipad-input-fields-error/
      Here I have the same iframe, one inside of edge and the other outside of edge.  Both work fine on a pc or mac but if you try to use an Ipad, you will see that the edge one shows the input field cursor down and outside of the input field.
      You can see for yourself,   I have set this up for you to test and see this error.
      The animate oam file is:  https://www.dropbox.com/s/hvydp2x61f6aq13/test-ipad-input-fields.oam
      Here is a link to the edge files, the .an and java files files:
      https://www.dropbox.com/sh/5ljxhc81gu97bcn/zphJ6pMc2J
      Much Much appreciate anything you can do on this!
      Appreciate greatly anything you can do for me, as I am pretty desperate for a solution or work-around.
