1 Reply Latest reply on Feb 21, 2014 1:51 PM by A.T. Romano
    Applying transitions in premier elements...
    mommafineapple
      Is it possible to apply a transition to ALL photos at once in premier elements?. I have over 200 photos I'm making a video with and it would take forever to apply between each set of photos. I tried setting default but nothing happened...??  Thanks
        • 1. Re: Applying transitions in premier elements...
          A.T. Romano Level 7
          mommafineapple
          You put us at a disadvantage not know what version of Premiere Elements you are using and on what computer operating system it is running.
          In view of that, I will offer a generalized answer.
          Select all your photos all at one time, go to Timeline Menu/Apply Default Transition.
          Beforehand, you can set the Default Transition from a lineup of transition in the Transition display area.
          Details are needed from you so that the response can be customized for your workflow.
          ATR
