10 Replies Latest reply on Feb 22, 2014 3:47 PM by Chris Cox
    Black flickering boxes in PS CC on rMBP 13" (late 2013)
    kyrresu
      I got my new rMBP 13" today and installed Photoshop CC - and was a little disappointed with the experience.
      When I´m using brushes black boxes start appearing/flickering when moving the brush around the canvas. After some googling I understand there were a similar problem with MacBook Air last summer and Apple made a fix for it. I can not find a fix for the late 2013 rMBP at the moment.
      Does anyone else have the same problem - or is it a problem with my machine? Is it a problem with Photoshop CC? I have version 14.2.1. The problem appears when the display is set to both high and low resolution.
      I´m grateful for all responses.
      My system:
      Apple MBP 13" (late 2013), i5, 2.4GHz, 8 GB RAM, 256 SSD.
      kyrresu
        • 1. Re: Black flickering boxes in PS CC on rMBP 13" (late 2013)
          Curt Y Level 7
          What type of video card?
          • 2. Re: Black flickering boxes in PS CC on rMBP 13" (late 2013)
            Level 7
            You might be running into some bugs with Nik/Google plugins (that cause problems for OpenGL usage in Photoshop).
            It could be a hardware issue, or a driver bug in MacOS.
            • 3. Re: Black flickering boxes in PS CC on rMBP 13" (late 2013)
              kyrresu Level 1
              Video card is Intel Iris 1024 MB
              • 4. Re: Black flickering boxes in PS CC on rMBP 13" (late 2013)
                kyrresu Level 1
                Chris Cox,
                Thank you for your reply. I have not Nic Collection installed. I will post a video demonstrating the problem soon.
                • 5. Re: Black flickering boxes in PS CC on rMBP 13" (late 2013)
                  kyrresu Level 1
                  Here is a video of the problem I described: https://vimeo.com/87317624
                  • 6. Re: Black flickering boxes in PS CC on rMBP 13" (late 2013)
                    Level 7
                    Yes, that's a video driver bug or something else messing with OpenGL.
                    Make sure you haven't installed any third party plugins, close down other apps, and try disabling OpenGL drawing in Photoshop's preferences (then restarting Photoshop) as a temporary way to avoid the driver issue.
                    • 7. Re: Black flickering boxes in PS CC on rMBP 13" (late 2013)
                      kyrresu Level 1
                      Chris Cox,
                      I talked to Apple Support today, and showed them the video. They said it's not a problem with the machine or the video card, but a problem with Photoshop/Adobe. They also said that Adobe had to fix the problem with their programs not working properly on the MBPs.
                      So... here I stand in the middle of Adobe and Apple. I can send the machine back to the store for 13 more days, so I will look more into the problem, and if it does not help send the machine back to the store.
                      Best,
                      K
                      • 8. Re: Black flickering boxes in PS CC on rMBP 13" (late 2013)
                        Level 7
                        You got someone at Apple who didn't even try to figure it out.
                        Photoshop doesn't show this flicker on other hardware, even on the same OS version.  So you have a problem specific to your hardware (or the hardware model) that causes artifacts when the OS draws the cursor -- um, logic says that has to be some combination of the hardware, the driver, or the OS.  (and possibly something else, like a utility messing with the driver)
                        Can you post the log from Help -> System Info ?  That should give us some information on the affected GPU and driver versions.
                        • 9. Re: Black flickering boxes in PS CC on rMBP 13" (late 2013)
                          kyrresu Level 1
                          Chris,
                          I don1t know where the problem is. I hvae tested with PSD-files saved in CS5.5, and there is less flickering there, even thoug these files are from 300 to 800 mb.
                          In SketchUp everything is smooth, and I think SketchUp is using OpenGL aswell.
                          Here is the log:
                          Adobe Photoshop Version: 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00) x64
                          Operating System: Mac OS 10.9.1
                          System architecture: Intel CPU Family:6, Model:69, Stepping:1 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
                          Physical processor count: 2
                          Logical processor count: 4
                          Processor speed: 2400 MHz
                          Built-in memory: 8192 MB
                          Free memory: 4764 MB
                          Memory available to Photoshop: 7234 MB
                          Memory used by Photoshop: 70 %
                          Image tile size: 128K
                          Image cache levels: 4
                          Font Preview: Medium
                          TextComposer: Latin
                          Display: 1
                          Main Display
                          High DPI Monitor
                          Display Bounds: top=0, left=0, bottom=1050, right=1680
                          OpenGL Drawing: Enabled.
                          OpenGL Allow Old GPUs: Not Detected.
                          OpenGL Drawing Mode: Basic
                          OpenGL Allow Normal Mode: True.
                          OpenGL Allow Advanced Mode: True.
                          AIFCoreInitialized=1
                          AIFOGLInitialized=1
                          OGLContextCreated=1
                          NumGPUs=1
                          gpu[0].OGLVersion="2.1"
                          gpu[0].MemoryMB=1024
                          gpu[0].RectTextureSize=16384
                          gpu[0].Renderer="Intel Iris OpenGL Engine"
                          gpu[0].RendererID=16925953
                          gpu[0].Vendor="Intel Inc."
                          gpu[0].VendorID=32902
                          gpu[0].HasNPOTSupport=1
                          gpu[0].CompileProgramGLSL=1
                          gpu[0].TestFrameBuffer=1
                          gpu[0].OCLPresent=1
                          gpu[0].OCLVersion="1.2 (Oct  1 2013 18:21:51)"
                          gpu[0].CUDASupported=0
                          gpu[0].OCLBandwidth=1.36376e+10
                          gpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
                          gpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[16384]
                          gpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
                          gpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
                          gpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
                          gpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
                          gpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                          gpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                          gpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
                          gpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[60]
                          gpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                          gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                          gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                          gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                          gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                          gpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                          gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                          gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                          gpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                          gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                          gpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                          License Type: Subscription
                          Serial number: 94070911831523524836
                          Application folder: /Applications/Adobe Photoshop CC/
                          Photoshop scratch has async I/O enabled
                          Scratch volume(s):
                            Macintosh HD, 233,0G, 178,1G free
                          Required Plug-ins folder: /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app/Contents/Required/Plug-Ins/
                          Primary Plug-ins folder: /Applications/Adobe Photoshop CC/Plug-Ins/
                          Installed components:
                             adbeape.framework   adbeape   3.4.0.29366   0.1160850
                             AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.3.2.31983   79.546835
                             adobe_caps.framework   adobe_caps   7.0.0.21   1.248010
                             AdobeACE.framework   AdobeACE   2.20.02.31977   79.548223
                             AdobeAGM.framework   AdobeAGM   4.30.29.31977   79.548223
                             AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
                             AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
                             AdobeBIB.framework   AdobeBIB   1.2.03.31977   79.548223
                             AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   79.548223
                             AdobeCoolType.framework   AdobeCoolType   5.15.00.31977   79.548223
                             AdobeCrashReporter.framework   AdobeCrashReporter   7.0.1
                             AdobeExtendScript.framework   AdobeExtendScript   4.5.5.31983   79.546835
                             AdobeJP2K.framework   AdobeJP2K   1.2.2.31977   79.248139
                             AdobeLinguistic.framework      19061
                             AdobeMPS.framework   AdobeMPS   5.8.1.31977   79.535029
                             AdobeOwl.framework   AdobeOwl   5.0.24   79.547804
                             AdobePDFL.framework   AdobePDFL   11.0.0.31977   79.508720
                             AdobePDFSettings.framework   AdobePDFSettings   1.4
                             AdobePIP.framework   AdobePIP   7.0.0.1786
                             AdobeScCore.framework   AdobeScCore   4.5.5.31983   79.546835
                             AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
                             AdobeXMP.framework   AdobeXMPCore   79.154911   79.154911
                             AdobeXMPFiles.framework   AdobeXMPFiles   79.154911   79.154911
                             AdobeXMPScript.framework   AdobeXMPScript   79.154911   79.154911
                             ahclient.framework   ahclient   1.8.0.31
                             aif_core.framework   AdobeAIF   5.0.00   79.534508
                             aif_ocl.framework   AdobeAIF   5.0.00   79.534508
                             aif_ogl.framework   AdobeAIF   5.0.00   79.534508
                             AlignmentLib.framework   xcode   Copyright © 2013 Adobe Systems Incorporated
                             amtlib.framework   amtlib   7.0.0.249
                             boost_date_time.framework   boost_date_time   7.0.0.0
                             boost_signals.framework   boost_signals   7.0.0.0
                             boost_system.framework   boost_system   7.0.0.0
                             boost_threads.framework   boost_threads   7.0.0.0
                             Cg.framework   NVIDIA Cg
                             CIT.framework   CIT   2.1.6.30929   151865
                             CITThreading.framework   CITThreading   2.1.6.30929   151865
                             dvaaudiodevice.framework   dvaaudiodevice   7.0.0.0
                             dvacore.framework   dvacore   7.0.0.0
                             dvamarshal.framework   dvamarshal   7.0.0.0
                             dvamediatypes.framework   dvamediatypes   7.0.0.0
                             dvaplayer.framework   dvaplayer   7.0.0.0
                             dvatransport.framework   dvatransport   7.0.0.0
                             dvaunittesting.framework   dvaunittesting   7.0.0.0
                             dynamiclink.framework   dynamiclink   7.0.0.0
                             FileInfo.framework   FileInfo   79.154511   79.154511
                             filter_graph.framework   AdobeAIF   5.0.00   79.534508
                             ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
                             ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
                             LogSession.framework   LogSession   2.1.2.1785
                             mediacoreif.framework   mediacoreif   7.0.0.0
                             patchmatch.framework   patchmatch   1.2.00.31977   79.542390
                             PlugPlugOwl.framework   PlugPlugOwl   4.2.0.36
                             UpdaterNotifications.framework   UpdaterNotifications   7.0.1.102   "7.0.1.102"
                             WRServices.framework
                          Required plug-ins:
                             3D Studio 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                             Accented Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Adaptive Wide Angle 14.2, Copyright © 2014 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
                             Angled Strokes 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Average 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Average.plugin”
                             Bas Relief 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             BMP 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Camera Raw 8.3 (141), Copyright © 2013 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                             Camera Raw Filter 8.3 (141), Copyright © 2013 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                             Chalk & Charcoal 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Chrome 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Cineon 14.2.1 x001  ©2002-2014 Adobe Systems Incorporated - from the file “Cineon.plugin”
                             Clouds 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Clouds.plugin”
                             Collada DAE 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                             Color Halftone 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Colored Pencil 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             CompuServe GIF 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Conté Crayon 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Craquelure 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Crop and Straighten Photos 14.2.1 x001  ©2003-2014 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
                             Crop and Straighten Photos Filter 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Crosshatch 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Crystallize 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Cutout 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Dark Strokes 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             De-Interlace 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Dicom 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “dicom.plugin”
                             Difference Clouds 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Clouds.plugin”
                             Diffuse Glow 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Displace 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Dry Brush 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Eazel Acquire 14.2.1 x001  ©1997-2014 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
                             Embed Watermark NO VERSION - from the file “DigiSign.plugin”
                             Entropy 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                             Extrude 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             FastCore Routines 14.2.1 x001  ©1990-2014 Adobe Systems Incorporated - from the file “FastCore.plugin”
                             Fibers 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Film Grain 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Filter Gallery 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Flash 3D 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                             Fresco 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Glass 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Glowing Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Google Earth 4 KMZ 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                             Graphic Pen 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Halftone Pattern 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             HDRMergeUI 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
                             IFF Format 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Ink Outlines 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             JPEG 2000 14.2.1 x001  ©2001-2014 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
                             Kurtosis 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                             Lens Blur 14.2, Copyright © 2002-2014 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
                             Lens Correction 14.2, Copyright © 2002-2014 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
                             Lens Flare 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Liquify 14.2, Copyright © 2001-2014 Adobe Systems Incorporated - from the file “Liquify.plugin”
                             Matlab Operation 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                             Maximum 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                             Mean 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                             Measurement Core 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
                             Median 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                             Mezzotint 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Minimum 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                             MMXCore Routines 14.2.1 x001  ©1990-2014 Adobe Systems Incorporated - from the file “MMXCore.plugin”
                             Mosaic Tiles 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Multiprocessor Support 14.2.1 x001  ©1990-2014 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
                             Neon Glow 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Note Paper 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             NTSC Colors 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
                             Ocean Ripple 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Oil Paint 14.2, Copyright © 2014 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
                             OpenEXR 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Paint Daubs 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Palette Knife 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Patchwork 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Paths to Illustrator 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             PCX 14.2.1 x001  ©1989-2014 Adobe Systems Incorporated - from the file “PCX.plugin”
                             Photocopy 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Photoshop 3D Engine 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
                             Photoshop Touch CC (14.2.0.0) ©1993-2014 Adobe Systems Incorporated - from the file “PSDX.plugin”
                             Picture Package Filter 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                             Pinch 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Pixar 14.2.1 x001  ©1989-2014 Adobe Systems Incorporated - from the file “Pixar.plugin”
                             Plaster 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Plastic Wrap 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             PNG 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Pointillize 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Polar Coordinates 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Portable Bit Map 14.2.1 x001  ©1989-2014 Adobe Systems Incorporated - from the file “PBM.plugin”
                             Poster Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Radial Blur 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Radiance 14.2.1 x001  ©2003-2014 Adobe Systems Incorporated - from the file “Radiance.plugin”
                             Range 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                             Read Watermark NO VERSION - from the file “DigiRead.plugin”
                             Reticulation 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Ripple 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Rough Pastels 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Save for Web 14.2, Copyright © 1999-2014 Adobe Systems Incorporated - from the file “Save for Web.plugin”
                             ScriptingSupport 14.2.1, Copyright © 2014 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
                             Shake Reduction 14.2, Copyright © 2014 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
                             Shear 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Skewness 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                             Smart Blur 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Smudge Stick 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Solarize 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Solarize.plugin”
                             Spatter 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Spherize 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Sponge 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Sprayed Strokes 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Stained Glass 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Stamp 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Standard Deviation 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                             STL 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                             Sumi-e 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Summation 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                             Targa 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Texturizer 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Tiles 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Torn Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Twirl 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Underpainting 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Vanishing Point 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
                             Variance 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                             Water Paper 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Watercolor 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Wave 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Wavefront|OBJ 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                             Wind 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Wireless Bitmap 14.2.1 x001  ©1989-2014 Adobe Systems Incorporated - from the file “WBMP.plugin”
                             ZigZag 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                          Optional and third party plug-ins: NONE
                          Plug-ins that failed to load: NONE
                          Flash:
                             Adobe Exchange
                             Kuler
                          Installed TWAIN devices: NONE
                          • 10. Re: Black flickering boxes in PS CC on rMBP 13" (late 2013)
                            Level 7
                            The problem is not with the files - the problem is in the video card driver, the OS, the hardware (not as likely), or some other application messing with the graphics state.
                            In this case my most likely guess is the Intel driver.
