1. Re: Is it possible to update all instances of a library item used in a document?
Steve Werner Feb 21, 2014 3:03 PM (in response to LeslieInV)What kind of library item? An image or graphic? Something you've drawn in InDesign? A block of text?
In the case of external graphics (linked to a graphic outside of InDesign), it's easy. Edit the graphic (TIFF, AI file, etc) in the original application, and it will update in InDesign.
I think ID 5.5 has an Edit > Place and Link option which can create a link between the original (parent) object and a placed example.
However, InDesign cannot create such a link using a library.
2. Re: Is it possible to update all instances of a library item used in a document?
LeslieInV Feb 27, 2014 12:49 PM (in response to Steve Werner)These library items are graphics drawn in InDesign to look like screen controls like buttons, text boxes, drop lists etc.
3. Re: Is it possible to update all instances of a library item used in a document?
John Mensinger Feb 27, 2014 1:04 PM (in response to LeslieInV)Library objects do not work like the Macromedia "symbols" that Adobe inherited in Flash and Fireworks.
I don't know how, (what properties), you want to change relative to all instances of the object, but since it is a native InDesign-drawn object, there's a good chance you can use the Object tab of the Find/Change feature to change it's appearance throughout the document.
4. Re: Is it possible to update all instances of a library item used in a document?
LeslieInV Mar 5, 2014 8:49 AM (in response to John Mensinger)I wanted to change the stroke of numerous instances all at once. Didn't know about the the Object tab of the Find/Change feature. Very Cool - Thanks!
