17 Replies Latest reply on Mar 19, 2014 9:19 AM by 喜狼_edny
    ID cs6:How to Fit Frame to Version heart(or Page) with script?
    喜狼_edny Level 1
      More times, I need my Frame fit to my Version,or fit to my page,fit to version hear.jpg
      I looking for the scrip in the Internet, only see "frames  to content"
      Who would like to help me?
      Thank you very much~
        • 1. Re: ID cs6:How to Fit Frame to Version heart(or Page) with script?
          I've moved your question to the scripting forum. I think you'll get more help here.
          • 2. Re: ID cs6:How to Fit Frame to Version heart(or Page) with script?
            Kai Rübsamen Level 4
            you can try the following lines:
            var curDoc = app.activeDocument;
            if ( app.selection.length != 1 ) {
                ( alert ( "Something wrong with your selection!" ) );
                exit();
            var curSel = app.selection[0];
            var curPage = curSel.parentPage;
            var rO = curDoc.viewPreferences.rulerOrigin;
            if (rO != 1380143215) {
                curDoc.viewPreferences.rulerOrigin = RulerOrigin.pageOrigin;
            var pW = curDoc.documentPreferences.pageWidth;
            var y1, x1, y2, x2;
            if ( curPage.side == PageSideOptions.leftHand ){
                x2 = curPage.marginPreferences.left;
                x1 = curPage.marginPreferences.right;
            else {
                x1 = curPage.marginPreferences.left;
                x2 = curPage.marginPreferences.right;
            x2 = pW - x2;
            var gB = curSel.geometricBounds;
            // fit to margins
            gB[1] = x1;
            gB[3] = x2;
            curSel.geometricBounds = gB;
            // fit to page
            /* gB[1] = 0;
            gB[3] = pW;
            curSel.geometricBounds = gB; */
            curSel.fit ( FitOptions.FRAME_TO_CONTENT );
            resetAsBefore();
            function resetAsBefore() {
                if ( rO != 1380143215 ) {
                        curDoc.viewPreferences.rulerOrigin = rO;
            Everything in /* */ will not executed. So at the moment your selection will fit to the page margins. If you put the lines under // fit to margins in /* */ and delete those under // fit to page, your textframe will fit to the page.
            best
            Kai
            • 3. Re: ID cs6:How to Fit Frame to Version heart(or Page) with script?
              喜狼_edny Level 1
              Hi  Kai Rübsamen
              Thank  you very much.
              Some times I must press Ctrl+Z, It will  be ok?
              and ,I want to select more than one text frame.
              and, the script is wrong in some document ,Tested, I find  should be make the Coordinate origin to the The upper left corner
              Could you like to add this Function into the scrip.
              thanks
              fit to margins
                  exit();
              var y1, x1, y2, x2;
              else {
              x2 = pW - x2;
              // fit to margins
              gB[1] = x1;
              gB[3] = x2;
              resetAsBefore();
              fit to page
                  exit();
              var y1, x1, y2, x2;
              else {
              x2 = pW - x2;
              // fit to page
              gB[1] = 0;
              gB[3] = pW;
              resetAsBefore();
              best wishes
              • 4. Re: ID cs6:How to Fit Frame to Version heart(or Page) with script?
                the script is not wrong. You get, what you showed in your screen: One frame that fits either to the type area or to the bounds of the page.
                If you want to select more than one frame or want to change all frames in a story, this is probably also possible, but: If you draw your frames correct from the beginning, in most cases there is no need for aligning them afterwards.
                • 5. Re: ID cs6:How to Fit Frame to Version heart(or Page) with script?
                  喜狼_edny Level 1
                  HI
                  Kai Rübsamen
                  I know how to ues it,
                  but I find something,I have update my Relay of the up (3 floor)
                  and it is now fit horizontal, Could you add fit to Vertical
                  thanks
                  http://forums.adobe.com/servlet/JiveServlet/showImage/2-6148509-554890/duble-click.jpg
                  thanks
                  • 6. Re: ID cs6:How to Fit Frame to Version heart(or Page) with script?
                    The next version should solve the problem with your zeroPoint. It is now also possible to have a textframe with a short single line.
                    if ( app.selection.length != 1 || app.selection[0].constructor.name != "TextFrame" ) {
                        exit();
                    // set the zeroPoint to 0
                    var zP = curDoc.zeroPoint;
                    if (zP != [0,0]) {
                        curDoc.zeroPoint = [0,0];
                    var y1, x1, y2, x2;
                    else {
                    x2 = pW - x2;
                    // fit to margins
                    gB[1] = x1;
                    gB[3] = x2;
                    // fit to page
                    /* gB[1] = 0;
                    gB[3] = pW;
                    fitFrame(curSel);
                    resetAsBefore();
                    function fitFrame(aFrame) {
                        var gB = aFrame.geometricBounds;
                        gB[2] = gB[2]+ 50;
                        aFrame.geometricBounds =  gB;
                        var lastBaseLine = aFrame.lines.lastItem().baseline;
                        aFrame.geometricBounds =  [ gB[0], gB[1], lastBaseLine, gB[3] ];
                        // set the zeroPoint back to the origin state
                        if (zP != [0,0]) {
                            curDoc.zeroPoint = zP;
                    • 7. Re: ID cs6:How to Fit Frame to Version heart(or Page) with script?
                      If you want to align your frame horizontally and vertically you can change the corresponding parts to something like:
                      var doc = app.activeDocument;
                      //Get page width and page height using the function "getBounds"
                      var gB = getBounds( doc, curPage);
                      //Resize the text frame to match the publication margins
                      function getBounds( doc, curPage){
                          var pW = doc.documentPreferences.pageWidth;
                          var pH = doc.documentPreferences.pageHeight;
                          var y1, x1, y2, x2;
                          y1 = curPage.marginPreferences.top;
                          x2 = pW - x2;
                          y2 = pH - curPage.marginPreferences.bottom
                          return [y1, x1, y2, x2];
                      • 8. Re: ID cs6:How to Fit Frame to Version heart(or Page) with script?
                        喜狼_edny Level 1
                        thank you thank you
                        You are too enthusiastic.~!
                        It is very good, only, I can not understant, have a "+", the height not Enough?
                        • 9. Re: ID cs6:How to Fit Frame to Version heart(or Page) with script?
                          If you select the frame above, your second example (the frame at the bottom) can never be a result of my script (hopefully ;-)). So I did not understand, what cause the overflow in your case.
                          • 10. Re: ID cs6:How to Fit Frame to Version heart(or Page) with script?
                            喜狼_edny Level 1
                            I find it, for it is missing this ...
                            " curSel.fit ( FitOptions.FRAME_TO_CONTENT );
                            resetAsBefore();
                            I Still can not add the  vertical in the below script, Always Cause Coordinate origin to be Fail
                            -single-handed,It is right.
                                exit();
                            if (zP != [0,0]) {
                            var y1, x1, y2, x2;
                            else {
                            x2 = pW - x2;
                            // fit to margins
                            gB[1] = x1;
                            gB[3] = x2;
                            // fit to page
                            /*gB[1] = 0;
                            gB[3] = pW;
                            curSel.geometricBounds = gB;*/
                            resetAsBefore();
                                if (zP != [0,0]) {
                            • 11. Re: ID cs6:How to Fit Frame to Version heart(or Page) with script?
                              Hopefully you understand, that you have here different needs and the various script-elements does different things here ;-)
                              If you want to align your textframe to all four sides of the type-are, you can try this one. Try also to delete the // at the line with "fitFrame". I spent also some comments for a better understanding.
                              // the current document
                              // there must be one selection with the selection-tool and the selection must be a textframe
                                  exit();
                              // the current selection
                              // the page of the current selection
                              if (zP != [0,0]) {
                              // set the ruler to page origin and store the user-pref
                              // page width and height
                              var pH = curDoc.documentPreferences.pageHeight;
                              var y1, x1, y2, x2;
                              // check if the page is a single, left or right page and store the margins
                              else {
                              x2 = pW - x2;
                              y2 = pH - curPage.marginPreferences.bottom;
                              // fit to margins
                              gB[0] = y1;
                              gB[1] = x1;
                              gB[2] = y2;
                              gB[3] = x2;
                              // fitFrame(curSel);
                              // set the zeroPoint and ruler to the original state
                              resetAsBefore();
                                  gB[2] = gB[2]+ 50;
                                  if (zP != [0,0]) {
                              • 12. Re: ID cs6:How to Fit Frame to Version heart(or Page) with script?
                                喜狼_edny Level 1
                                Hi
                                Kai Rübsamen
                                It is just I want,It is very good!
                                You are so Calendar harm, Very, very,very Invincible
                                The best wishes  for you
                                • 13. Re: ID cs6:How to Fit Frame to Version heart(or Page) with script?
                                  喜狼_edny Level 1
                                  Hi
                                  Kai Rübsamen
                                  The script of "fit to 4 size page"  is very Perfect
                                  I am so sorry,for I comebake to Pester you,I must admit, I am so greedy
                                  ① I find the"fit to margins " and "fit to page" is not rigth,when my text only 1 row~
                                  ② and I want to know,How to fit to Column......
                                  It is the script
                                      exit();
                                  if (zP != [0,0]) {
                                  var y1, x1, y2, x2;
                                  else {
                                  x2 = pW - x2;
                                  // fit to margins
                                  gB[1] = x1;
                                  gB[3] = x2;
                                  // fit to page
                                  /*gB[1] = 0;
                                  gB[3] = pW;
                                  resetAsBefore();
                                      if (zP != [0,0]) {
                                  • 14. Re: ID cs6:How to Fit Frame to Version heart(or Page) with script?
                                    As I said before: You got different things for different needs here!
                                    fitFrame(curSel) and curSel.fit() are not the same things! The first one should solve your problem.
                                    To your columns question: I never scripted this before and have sadly at the moment no time to dive in this, sorry.
                                    • 15. Re: ID cs6:How to Fit Frame to Version heart(or Page) with script?
                                      喜狼_edny Level 1
                                      Hi Kai Rübsamen~
                                      I miss you very much!
                                      Text suitable column is very very useful for me, example  in Magazine publishing,there are Many text boxes, it can beQuickly align column edge。
                                      Hope you can help me achieve~
                                      Best wishes for you~
                                      http://forums.adobe.com/servlet/JiveServlet/showImage/2-6154317-555469/Fit+to+ColuColumn.jpg
                                      • 16. Re: ID cs6:How to Fit Frame to Version heart(or Page) with script?
                                        you have luck, I find the question interesting but I’m not sure, if I do this in the right way. I’m a graphic designer and not really a scripter ;-)
                                        Find here a first version. This version is not really flexible. The script assumes, that you select a textframe or a rectangle.
                                        I would think, that the second version should compare the distance between the left edge and the nearest column. I’m busy at the moment. Maybe I have the next days a bit time to dive in for this second version.
                                        Any feedback in the meantime appreciated.
                                        // Masseinheiten, Ursprung und Nullpunkt speichern und bei Bedarf verändern
                                        hM = curDoc.viewPreferences.horizontalMeasurementUnits;
                                        vM = curDoc.viewPreferences.verticalMeasurementUnits;
                                        _setPref();
                                        // Variablen initialisieren
                                        var pWidth = curDoc.documentPreferences.pageWidth;
                                        pWidth = Math.floor((pWidth * 1000) + 0.5) / 1000;
                                        var pHeight = curDoc.documentPreferences.pageHeight;
                                        pHeight = Math.floor((pHeight * 1000) + 0.5) / 1000;
                                        var curPage = app.activeWindow.activePage;
                                        // weitere Variablen deklarieren
                                        var curPage;
                                        var pM;
                                        var curPos;
                                        var allPos = new Array;
                                        if(curPage.side == PageSideOptions.leftHand) {
                                            // bei Doppelseiten bedeutet left > innen; right > außen
                                            pM = curPage.marginPreferences.right;
                                        else{
                                            // entweder Einzelseite oder rechte Seite
                                            pM = curPage.marginPreferences.left;
                                        // die Anzahl der Spalten auf der Seite
                                        var nC = curPage.marginPreferences.columnCount;
                                        // die Positionen der Spaltenlinien
                                        var colPos = curPage.marginPreferences.columnsPositions;
                                        // Schleife durch alle Positionen, der Spaltenlinien, Werte runden
                                        for (var k=0; k<colPos.length; k++) {
                                            curPos = (Math.floor((colPos[k] * 1000) + 0.5) / 1000) + pM;
                                            allPos.push(curPos);
                                        gB[1] = allPos[0];
                                        gB[3] = allPos[1];
                                        if (curSel.constructor.name == "TextFrame") fitFrame(curSel);
                                        _reStorePref();
                                        // --------------------- Funktionen -------------------------
                                            gB[2] = gB[2]+ 50;
                                        // Voreinstellungen verändern und zurücksetzen
                                        function _setPref() {
                                            curDoc.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.millimeters;
                                            curDoc.viewPreferences.verticalMeasurementUnits = MeasurementUnits.millimeters;
                                            curDoc.viewPreferences.rulerOrigin = RulerOrigin.PAGE_ORIGIN;
                                        function _reStorePref() {
                                            curDoc.viewPreferences.horizontalMeasurementUnits = hM;
                                            curDoc.viewPreferences.verticalMeasurementUnits = vM;
                                        • 17. Re: ID cs6:How to Fit Frame to Version heart(or Page) with script?
                                          喜狼_edny Level 1
                                          HI~Kai Rübsamen~
                                          I have see you~you so great,I only can say:I love you ~ best wishes for you!
                                          I test it It is very good~,have some  advice:When this point at Which column, it should fit to Which column, But not always fit to the first column.
