10 Replies Latest reply on Feb 25, 2014 8:04 AM by iCurioso
    How enable Parallax.js?
    iCurioso
      Hello
      How connect parallax.js with adobe edge?
      https://github.com/wagerfield/parallax
      I want this effect: http://wagerfield.github.com/parallax/
        • 1. Re: How enable Parallax.js?
          iCurioso Level 1
          Help!
          • 2. Re: How enable Parallax.js?
            heathrowe Most Valuable Participant
            I had a look at it but I could not get it to work.
            I believe it has something to do with the way this library utilizes data-depth=" " on the individual elements.
            Darrell
            • 3. Re: How enable Parallax.js?
              resdesign Adobe Community Professional & MVP
              I have use it and have it working.
              Below was my code at the time:
              yepnope(
                  nope:[
                    'js/parallax.js',
                    'js/requestAnimationFrame.js'
                  complete: init
              function init() {
                        sym.$('scene').html('<ul id="scene" data-scalar-x="2"  data-scalar-y="5"  data-friction-x="0.1"  data-friction-y="0.1">'
                        + '<li class="layer" data-depth="0.20"><img src="images/layer_0009_trees.png"></li>'
                        //+' <li class="layer" data-depth="0.50"><img src="images/layer_0010_field3.png"></li>'
                        +' <li class="layer" data-depth="0.50"><img src="images/layer_0008_field2.png"></li>'
                        +'<li class="layer" data-depth="0.60"><img src="images/layer_0007_hucleberries.png"></li>'
                        +'<li class="layer" data-depth="0.50"><img src="images/layer_0006_blueberries.png"></li>'
                        +'<li class="layer" data-depth="0.40"><img src="images/layer_0005_field1.png"></li>'
                        +'<li class="layer" data-depth="0.50"><img src="images/layer_0004_strawberies.png"></li>'
                        +'<li class="layer" data-depth="0.30"><img src="images/layer_0003_flowers.png"></li>'
                        +'<li class="layer" data-depth="0.50"><img src="images/woman.png"></li>'
                        +'<li class="layer" data-depth="0.20"><img src="images/layer_0002_treeFront.png"></li>'
                 +'<li class="layer" data-depth="0.50"><img src="images/layer_0001_birds.png"></li></ul>'
                        var scene = document.getElementById('scene');
                        var parallax = new Parallax(scene);
              • 4. Re: How enable Parallax.js?
                iCurioso Level 1
                What this - requestAnimationFrame?
                • 5. Re: How enable Parallax.js?
                  iCurioso Level 1
                  I don't have SCENE. A have a stage and many objects on stage.
                  I using timeline - offset left. And using TweenMax: sym.stop(frameNumber). And it's working.
                  • 6. Re: How enable Parallax.js?
                    I am just providing this sample for you to see if you can adapt to your composition. i currently do not have time to look at your files.
                    https://app.box.com/s/i75ijbjcbpz89ctwgpw8
                    • 7. Re: How enable Parallax.js?
                      You do not need requestAnimationFrame and I adapted the new file with the script loading included in Animate version 3.
                      Code was an adaptation of a sample provided on the plugin site.
                      Anyway, if it is working, then why the question?
                      • 8. Re: How enable Parallax.js?
                        Nice example Marie
                        I mangaged to work something out by injecting the attributes;
                        Sample: http://www.heathrowe.com/edge/parallax/
                        Download: http://www.heathrowe.com/edge/parallax/parallax.zip
                        What I did - you will see in the example download.
                        - create a scene element
                        - import images and nest them into the scene element
                        - select those images and add a class to these called 'layer' (without the quotes).
                        - Edge Animate 3 use the Library import script from harddrive option
                        Then in compositionReady event handler I have the following
                        //////////// compositionReady /////////////////////////////
                        // scene element
                        // be sure to set the child elements of scene class to 'layer'
                            var element = sym.$("scene");
                        // inject scene element attributes
                                element.attr("id","scene");
                                element.attr("data-scalar-x","25");
                                element.attr("data-scalar-y","15");
                                element.attr("data-friction-x","0.1");
                                element.attr("data-friction-y","0.1");
                        // set/inject children of scene elements data-depth values
                        // add as many elements to this scene with matching lookup selector and desired data-depth
                                sym.$("cloud").attr("data-depth","0.70");
                                sym.$("cloud2").attr("data-depth","0.70");
                                sym.$("cloud3").attr("data-depth","0.90");
                                sym.$("lighthouse").attr("data-depth","0.20");
                        // call script function parallax
                        element.parallax();
                        ////////////////////// End Script //////////////////////////////////////
                        hth
                        Darrell
                        • 9. Re: How enable Parallax.js?
                          Thanks!
                          Great job Darrell! Always fun to play with new toys!
                          • 10. Re: How enable Parallax.js?
                            iCurioso Level 1
                            It's great! Thank you!!!
