2 Replies Latest reply on Feb 24, 2014 3:44 AM by rickaclark54
    How do I use OUTER JOIN to email different message than the default
    rickaclark54 Level 1
      I have a devotional that goes out daily from a MOBILE table containing:
      • mob_id
      • calendardate
      • title
      • scripture
      • body
      The same devotional goes out to 3 different churches.
      I have a second TABLE called EDITED that holds an edited version of the daily devotional, containing:
      • edit_id
      • calendardate
      • etitle
      • escripture
      • ebody
      The query should look in the edited table for a devotional first to see if it matches the current date then send it out. Otherwise it sends out the default devotional  that corresponds with the current date.
      I would like to send out in replacement of the default devotional  to the church that edited the devotional.
      I am using the following outer Join but it doesn’t work. It sends the same devotional to everybody.
      <cfoutput>
      <cfloop query="getClients">
      <!--- determine if there is an edited version of the devotional available for this day --->
      <cfquery name="getDevotional" datasource="#application.dsn#">
      SELECT mobile.mob_id, mobile.display_date, mobile.title, mobile.body, mobile.scripture,edited.edit_id,edited.contact_id,edited.etitle,edited.escripture,edited. ebody
      FROM mobile
      left outer join edited ON mobile.display_date = edited.display_date
      where mobile.display_date = <cfqueryparam value ="#dateformat(now(), "YYYY-MM-DD")#" cfsqltype="cf_sql_date">
      </cfquery>
      What am I missing?
