5 Replies Latest reply on Feb 28, 2014 12:30 AM by Saurav
    Using Edge Commons Parallax: Trouble with getSymbol
    efreistadt Level 1
      Hello all,
      I'm having trouble.
      I have an element, "button", and have given it a mouseover event, to call symbol, "animation", and play from the beginning of the symbol timeline.
      Right now I have written, "var mySymbolObject = sym.getSymbol("animation").play();" in the mouseover event for my "button" element.
      I have followed online tutorials, but still cannot seem to get this to work. I'm wondering if it is due to my timeline being controlled by the scrolling as this is a Edge Commons Parallax composition, and perhaps that is what is confusing the call to play the symbol.
      I do not want the symbol to be visible unless it is activated by the mouseover "button". And I want the symbol to be played from its beginning when I mouseover "button", and then play from reverse when I mouseout of "button"
      I appreciate any insight you all may offer.
      Best,
      Eric
        • 1. Re: Using Edge Commons Parallax: Trouble with getSymbol
          Saurav Adobe Employee
          Hi Eric,
          Please refer the attached file  . You can set the display option of the symbol to off on the main timeline and then write the code as provided in the attached example .
          Saurav
          • 2. Re: Using Edge Commons Parallax: Trouble with getSymbol
            efreistadt Level 1
            Thank you Saurav,
            That works—though now I have two further questions.
            1. Let's say that I want the symbol "animation" to be played from beginning when I mouseover "button", but not played reverse until "button" is clicked. What is happening is "animation" is replaying from the beginning everytime I mouseover, which I only want it played once, until the click plays from reverse. How do I set the mouseover to play "animation" only once, no matter how many mouseovers occur, until clicked to play reverse?
            2. I want "button" to expand "animation" on click, but then collapse on another click. How can I assign "button" to play symbol "animation" on click, but then if there is a second click "animation" plays from reverse (i.e. Boolean true/false)?
            Thank you so much for any further help!
            Eric
            • 3. Re: Using Edge Commons Parallax: Trouble with getSymbol
              Hi Eric ,
              For the first question you can set a variable in the compositionReady function which will act as a flag which will help to make sure that animation plays only once until reverse animation is played through click event . Please refer the attached file .
              For the second question can you please elaborate your problem in detail ? Sorry for not understanding what you meant by "exapnd animation " and " collapse animation "
              Saurav
              • 4. Re: Using Edge Commons Parallax: Trouble with getSymbol
                efreistadt Level 1
                Thank you again Saurav,
                For the second question, I am meaning that on click the symbol "animation" would play, and then on the second click "animation" would play from reverse.
                Is that clear enough?
                Eric
                • 5. Re: Using Edge Commons Parallax: Trouble with getSymbol
                  Hi Eric ,
                  There might be many ways to do the play and play reverse using click operation as described by you but this is what I think could be done .
                  We can set a variable in our compositionReady function   sym.setVariable("count", 0);
                  Then in the click handler of the symbol we can write the following code
                  var x = sym.getVariable("count");
                  var mySymbolObject = sym.getSymbol("Symbol_1");
                  //Now check if you have clicked once then play otherwise play reverse .
                  if(x%2 == 0)
                            mySymbolObject.play();
                  else
                            mySymbolObject.playReverse();
                  x++;
                  // Set the value of a Symbol variable
                  sym.setVariable("count",x);
                  Please refer the attached composition . Hope it helps
                  Saurav
