6 Replies Latest reply on Oct 21, 2017 5:57 PM by Roei Tzoref
    Equivalent of Dodge and Burn tool for After Effects
    rossy
      Is there a tool in After Effects that allows you to brighten or darken selected areas (like the dodge and burn tool in photoshop)?
        • 1. Re: Equivalent of Dodge and Burn tool for After Effects
          An adjustment layer with an animated mask and Curves, Levels, or other color correction effects would be the closest you could come to selectively changing the appearance of isolated areas in a video.
          If you really wanted to paint on the effect you could paint on a solid and use that layer as a track matte for an adjustment layer.
          You can also use masked copies of your footage with various blend modes like multiply or screen.
          Colorista has built in masking in the second section. SpeedGrade also has tools to select and correct only portions of the video.
          If that does not do it for you then please explain exactly what you are trying to accomplish and show is a sample frame or clip.
          • 2. Re: Equivalent of Dodge and Burn tool for After Effects
            rossy Level 1
            Thank you, Rick. Do you know any tutorials that show something relevantly similar to painting on a solid and then using it as a track matte?
            SpeedGrade may be a bit more adaptive for what I'm looking for. Could you tell me what the tool is called, so that I can look up demos?
            The clip that I'm editing is one due to very bright overhead lighting. The face is poorly lit but the forehead is overly lit. I'd like to dull the overhead lighting, and if possible, lighten the face a bit.
            • 3. Re: Equivalent of Dodge and Burn tool for After Effects
              You can probably do a lot of that with simple curvs adjustments. How much do you know about color correction? Is the camera moving?
              SpeedGrade comes with the CC bundle. Colorista is a great tool available from Red Giant.
              If you post a frame of the movie I'll throw a simple color correction on it probably using Levels Individual Controls. This doesn't sound like something that is going to require Dodge and Burn techniques but I can't be sure until I see the project.
              • 4. Re: Equivalent of Dodge and Burn tool for After Effects
                rossy Level 1
                I don't know too much about color correction in after effects.
                I also downloaded SpeedGrade and am taking a look at how it works.
                Finally, I sent you a message in response to the clip.
                • 5. Re: Equivalent of Dodge and Burn tool for After Effects
                  koawhkaine
                  I am trying to accomplish the same thing. I have a person in an interview setting. I just want to add a hint of shadow to a spot, and lighten another (both to create depth). Dodge and burn in photoshop, but what as an equivalent in AE>? is the tutorial keywords i look for adjustment layer  and animated mask ?
                  • 6. Re: Equivalent of Dodge and Burn tool for After Effects
                    Roei Tzoref Adobe Community Professional
                    actually even in photoshop when doing digital touch ups, it's recommended to use adjustment layers and not dodge and burn which are destructive to your pixels and only works on rasterized pixels...
                    you can do this on an adjustment layer or on the same layer by using the compositing options.
                    adjustment layer: add an adjustment layer, add the curves effect, add a feathered mask and set the curve up - this is dodge, the other way around is burn.
                    if the person is moving you will need to track the movement. if it's a soft movement with no obscure and relatively exposed then you can track the mask by right clicking on the mask and clicking track mask. you will open a tracking window where you can track the mask on the footage and it will hopefully move along accurately across the object.
