why I am unable to install flash player on my android devices??
There is no more Flash Player for Android and there won't be another. Android is no longer compatible with Flash Player. Playing Flash content is very processor consumptive and it drains your battery, also shortening the life of it. Android (Google) recommends using either "Dolphin" or "Puffin" as your browser if you need to view Flash content with a mobile device running Android. They're both free in the GooglePlay store. These browsers use "server side" rendering to reduce the load on your dev
...Copy link to clipboard
There is no more Flash Player for Android and there won't be another. Android is no longer compatible with Flash Player. Playing Flash content is very processor consumptive and it drains your battery, also shortening the life of it. Android (Google) recommends using either "Dolphin" or "Puffin" as your browser if you need to view Flash content with a mobile device running Android. They're both free in the GooglePlay store. These browsers use "server side" rendering to reduce the load on your device.
You can also check this.
Yes you can install Flash player very easy actually check out my profile I have instructions. Ya I can agree with the battery part but even with puffin it will drain the battery. It will not shorten your device life. I have done it on set top boxes, Phones, and Tablets it works.
Best
Hi it works perfectly follow the instructions. I have tested this on Phones, Tablets and Set Top Boxes or TV Boxes. Here is the important Part you need the right APK file just like any app on Play here is the right one download this http://download.macromedia.com/pub/flashplayer/installers/archive/android/11.1.115.81/install_flash_... using your device or using your computer. here is the link right here at Adobe Manually install on Android devices . Once you have it done please test with is amazing TV Network built with Flash http://askmilton.tv please post your comments and your experience. I had to edit my post the moderator did not like my first one sorry.
Best
