9 Replies Latest reply on Apr 25, 2014 3:00 AM by Peter Spier
    exclude list for GREP?
    Gwouten Level 1
      Hi everyone,
      I am regularly working on annual reports and this is a problem I have come across every time, but still haven't found a solution for:
      There are lots of numbers in these reports and depending on the language, the thousands are separated by a "." or a"<thin space>". Also included in this kind of documents are years: 2009, 2010, 2011, etc...
      Usually I would use GREP to separate the thousands, but then I also seaparte all the years and I have to GREP again to attach them again.
      Ex: 2009 -> 2.009 -> I don't want this!
      Is there a way to exclude a number of strings in the GERP-search?
      Thanks!
        • 1. Re: exclude list for GREP?
          What GREP are you using to insert thousands separators?
          • 2. Re: exclude list for GREP?
            That depends on the document and how it was built.
            Find/Change queries can be limited in scope to individual stories or selections, or to match specific styles. GREP queries can also use Look-Behinf or Look-Ahead, either positive or negative, to limit matches to cases where there is or is not other text of a certain type that preceeds or follows the found string. I would guess that the best bet here is probably a style-based limit, but you haven't really given us enough detail to say for sure.
            • 3. Re: exclude list for GREP?
              Gwouten Level 1
              Currently i'm doing it like this:
              find:
              (\d{1,3})(\d{3})
              replace:
              $1.$2
              • 4. Re: exclude list for GREP?
                There is not a built-in way to automatically exclude "years" -- if only because, well, what series of digits constitute a year? (Having ran into this problem myself: yes, there *are* authors happily referring to "Dampier, William. 1681. A New Voyage Round the World.", and no: my reference processing scripts are not happy with numbers like these!)
                Try this: a lookahead that forces a no-match on '2009'
                (?!2009\b)(\d{1,3})(\d{3})
                If this works 'good enough', you can expand it to (not) match, for instance, "2000-2014" but beware of the many, many things that can go wrong (consider an amount of "$2009").
                • 5. Re: exclude list for GREP?
                  Gwouten Level 1
                  Ok, thanks!
                  I've always figured that there's no absolute way to exclude a series of digits and differentiate between "this one's a year" and "this one's something else".
                  But I'll go ahead an use your suggestion, with caution
                  Thanks!
                  • 6. Re: exclude list for GREP?
                    Pavel Emi
                    Pls, I used your solution to the separation of thousands (\d{1,3})(\d{3})   , but does not work with large numerals over a million - you have a solution?
                    • 7. Re: exclude list for GREP?
                      Pavel Emi Level 1
                      • 8. Re: exclude list for GREP?
                        Gwouten Level 1
                        If you simply add another "(\d{3})" to the end of the grep search query and a ".$3" to the replace part like this:
                        search: (\d{1,3})(\d{3})(\d{3})\b
                        replace: $1.$2.$3
                        it will also include millions.
                        You can add this for each multiple of thousand, e.g. 1.000.000.000 would need "(\d{1,3})(\d{3})(\d{3})(\d{3})\b" in the search field and a "$1.$2.$3.$4" in the replace field.
                        I'm sure there are better ways to do this, but this will do if you're in a hurry .
                        I hope that helps!
                        • 9. Re: exclude list for GREP?
                          That method requires a separate search for each multiple of thousands.
