1 Reply Latest reply on Feb 25, 2014 9:58 AM by jcanepa
    Options
    INGO
      I need a data submitter to sellect 10 out of 15 choices. The system is only allowing  selection of 2 choices maximum. How do I go about this?
      I need the data sumitter to submit data only once with no possibility of using the same email to submit again. Please help?
        • 1. Re: Options
          jcanepa Adobe Employee
          To create a field that requires a user to select 10 choices, you create a multiple choice field with your 15 choices.  Then in the Field Properties pallet check the checkbox labeled Limit Choice Selections.  This will expose a couple of input fields for the Min and Max number of choices a user has to select before they can submit.  Put 10 into the the Min and Max fields to require exactly 10 choices.
          As for limiting a user to only submit once, this is functionality that is not supported by FormsCentral.
          -Jeff
