12 Replies Latest reply on Feb 26, 2014 5:44 PM by bdyomtov
    Lens Blur
    bdyomtov
      When I try to use lens blur on a selected area the filter seems to ignore the selection and blurs the whole image. Why is this?
      To be precise, for simplicity, I do the following:
      1. Open an image
      2. Convert background to layer 0.
      3. Select an area.
      4. Apply Lens blur
      The whole image then blurs.
      Note that if I do the same thing with Gaussian blur the blur is only applied to the selected area.
      What's going on?
      Thank you.
        • 1. Re: Lens Blur
          Noel Carboni Level 8
          Seems to work here on 14.2.1...
          Can you please post some screen grabs showing the problem, and also go into your Help - System Info menu, copy the info, and post it here.
          -Noel
          • 2. Re: Lens Blur
            Chuck Uebele Adobe Community Professional & MVP
            For lens blur, you want to create a alpha channel to be used as your selection.  Then when you apply your lens blur, you can use that alpha channel.  By clicking on the image in the lens blur dialog box, you can select which area of the alpha channel will be sharp.
            Here's a sample of using an Alpha Channel:
            • 3. Re: Lens Blur
              wes1 Level 1
              Try the Iris blur without making a selection first and see if that works.
              • 4. Re: Lens Blur
                bdyomtov Level 1
                Here are my steps. Notice that between 3 and 4 all I did was apply lens blur.
                Step 1 - load image
                Step 2 - select
                Step 3 - Invert selection
                Step 4 - Aplly lens blur
                Step 5 - deselect
                System info:
                Adobe Photoshop Version: 14.2 (14.2 20131211.r.515 2013/12/11:23:00:00) x64
                Operating System: Mac OS 10.8.5
                System architecture: Intel CPU Family:6, Model:26, Stepping:5 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
                Physical processor count: 4
                Logical processor count: 8
                Processor speed: 2659 MHz
                Built-in memory: 10240 MB
                Free memory: 2549 MB
                Memory available to Photoshop: 9169 MB
                Memory used by Photoshop: 70 %
                Image tile size: 1024K
                Image cache levels: 4
                Font Preview: Medium
                TextComposer: Latin
                The GPU Sniffer crashed on 1/2/14 at 4:15:56 PM
                Display: 1
                Main Display
                Display Bounds: top=0, left=0, bottom=1200, right=1920
                OpenGL Drawing: Enabled.
                OpenGL Allow Old GPUs: Not Detected.
                OpenGL Drawing Mode: Basic
                OpenGL Allow Normal Mode: True.
                OpenGL Allow Advanced Mode: True.
                AIFCoreInitialized=1
                AIFOGLInitialized=1
                OGLContextCreated=1
                NumGPUs=1
                gpu[0].OGLVersion="2.1"
                gpu[0].MemoryMB=512
                gpu[0].RectTextureSize=8192
                gpu[0].Renderer="NVIDIA GeForce GT 120 OpenGL Engine"
                gpu[0].RendererID=16918028
                gpu[0].Vendor="NVIDIA Corporation"
                gpu[0].VendorID=4318
                gpu[0].HasNPOTSupport=1
                gpu[0].CompileProgramGLSL=1
                gpu[0].TestFrameBuffer=1
                gpu[0].OCLPresent=1
                gpu[0].OCLVersion="1.2 (Apr 25 2013 18:32:06)"
                gpu[0].CUDASupported=0
                License Type: Subscription
                Serial number: 96040026404182254700
                Application folder: /Applications/Adobe Photoshop CC/
                Photoshop scratch has async I/O enabled
                Scratch volume(s):
                  Startup, 595.4G, 246.3G free
                Required Plug-ins folder: /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app/Contents/Required/Plug-Ins/
                Primary Plug-ins folder: /Applications/Adobe Photoshop CC/Plug-ins/
                Installed components:
                   adbeape.framework   adbeape   3.4.0.29366   0.1160850
                   AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.3.2.31983   79.546835
                   adobe_caps.framework   adobe_caps   7.0.0.21   1.248010
                   AdobeACE.framework   AdobeACE   2.20.02.31977   79.548223
                   AdobeAGM.framework   AdobeAGM   4.30.29.31977   79.548223
                   AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
                   AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
                   AdobeBIB.framework   AdobeBIB   1.2.03.31977   79.548223
                   AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   79.548223
                   AdobeCoolType.framework   AdobeCoolType   5.15.00.31977   79.548223
                   AdobeCrashReporter.framework   AdobeCrashReporter   7.0.1
                   AdobeExtendScript.framework   AdobeExtendScript   4.5.5.31983   79.546835
                   AdobeJP2K.framework   AdobeJP2K   1.2.2.31977   79.248139
                   AdobeLinguistic.framework      19061
                   AdobeMPS.framework   AdobeMPS   5.8.1.31977   79.535029
                   AdobeOwl.framework   AdobeOwl   5.0.24   79.547804
                   AdobePDFL.framework   AdobePDFL   11.0.0.31977   79.508720
                   AdobePDFSettings.framework   AdobePDFSettings   1.4
                   AdobePIP.framework   AdobePIP   7.0.0.1786
                   AdobeScCore.framework   AdobeScCore   4.5.5.31983   79.546835
                   AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
                   AdobeXMP.framework   AdobeXMPCore   79.154911   79.154911
                   AdobeXMPFiles.framework   AdobeXMPFiles   79.154911   79.154911
                   AdobeXMPScript.framework   AdobeXMPScript   79.154911   79.154911
                   ahclient.framework   ahclient   1.8.0.31
                   aif_core.framework   AdobeAIF   5.0.00   79.534508
                   aif_ocl.framework   AdobeAIF   5.0.00   79.534508
                   aif_ogl.framework   AdobeAIF   5.0.00   79.534508
                   AlignmentLib.framework   xcode   Copyright © 2013 Adobe Systems Incorporated
                   amtlib.framework   amtlib   7.0.0.249
                   boost_date_time.framework   boost_date_time   7.0.0.0
                   boost_signals.framework   boost_signals   7.0.0.0
                   boost_system.framework   boost_system   7.0.0.0
                   boost_threads.framework   boost_threads   7.0.0.0
                   Cg.framework   NVIDIA Cg
                   CIT.framework   CIT   2.1.6.30929   151865
                   CITThreading.framework   CITThreading   2.1.6.30929   151865
                   dvaaudiodevice.framework   dvaaudiodevice   7.0.0.0
                   dvacore.framework   dvacore   7.0.0.0
                   dvamarshal.framework   dvamarshal   7.0.0.0
                   dvamediatypes.framework   dvamediatypes   7.0.0.0
                   dvaplayer.framework   dvaplayer   7.0.0.0
                   dvatransport.framework   dvatransport   7.0.0.0
                   dvaunittesting.framework   dvaunittesting   7.0.0.0
                   dynamiclink.framework   dynamiclink   7.0.0.0
                   FileInfo.framework   FileInfo   79.154511   79.154511
                   filter_graph.framework   AdobeAIF   5.0.00   79.534508
                   ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
                   ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
                   LogSession.framework   LogSession   2.1.2.1785
                   mediacoreif.framework   mediacoreif   7.0.0.0
                   patchmatch.framework   patchmatch   1.2.00.31977   79.542390
                   PlugPlugOwl.framework   PlugPlugOwl   4.2.0.36
                   UpdaterNotifications.framework   UpdaterNotifications   7.0.1.102   "7.0.1.102"
                   WRServices.framework
                Required plug-ins:
                   3D Studio 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Accented Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Adaptive Wide Angle 14.2, Copyright © 2014 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
                   Angled Strokes 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Average 14.2 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Average.plugin”
                   Bas Relief 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   BMP 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Camera Raw 8.3 (141), Copyright © 2013 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                   Camera Raw Filter 8.3 (141), Copyright © 2013 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                   Chalk & Charcoal 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Chrome 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Cineon 14.2 x001  ©2002-2014 Adobe Systems Incorporated - from the file “Cineon.plugin”
                   Clouds 14.2 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Clouds.plugin”
                   Collada DAE 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Color Halftone 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Colored Pencil 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   CompuServe GIF 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Conté Crayon 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Craquelure 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Crop and Straighten Photos 14.2 x001  ©2003-2014 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
                   Crop and Straighten Photos Filter 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Crosshatch 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Crystallize 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Cutout 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Dark Strokes 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   De-Interlace 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Dicom 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “dicom.plugin”
                   Difference Clouds 14.2 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Clouds.plugin”
                   Diffuse Glow 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Displace 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Dry Brush 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Eazel Acquire 14.2 x001  ©1997-2014 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
                   Embed Watermark NO VERSION - from the file “DigiSign.plugin”
                   Entropy 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Extrude 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   FastCore Routines 14.2 x001  ©1990-2014 Adobe Systems Incorporated - from the file “FastCore.plugin”
                   Fibers 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Film Grain 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Filter Gallery 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Flash 3D 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Fresco 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Glass 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Glowing Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Google Earth 4 KMZ 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Graphic Pen 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Halftone Pattern 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   HDRMergeUI 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
                   IFF Format 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Ink Outlines 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   JPEG 2000 14.2 x001  ©2001-2014 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
                   Kurtosis 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Lens Blur 14.2, Copyright © 2002-2014 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
                   Lens Correction 14.2, Copyright © 2002-2014 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
                   Lens Flare 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Liquify 14.2, Copyright © 2001-2014 Adobe Systems Incorporated - from the file “Liquify.plugin”
                   Matlab Operation 14.2 x001  ©1993-2014 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                   Maximum 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Mean 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Measurement Core 14.2 x001  ©1993-2014 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
                   Median 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Mezzotint 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Minimum 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                   MMXCore Routines 14.2 x001  ©1990-2014 Adobe Systems Incorporated - from the file “MMXCore.plugin”
                   Mosaic Tiles 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Multiprocessor Support 14.2 x001  ©1990-2014 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
                   Neon Glow 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Note Paper 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   NTSC Colors 14.2 x001  ©1993-2014 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
                   Ocean Ripple 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Oil Paint 14.2, Copyright © 2014 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
                   OpenEXR 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Paint Daubs 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Palette Knife 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Patchwork 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Paths to Illustrator 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   PCX 14.2 x001  ©1989-2014 Adobe Systems Incorporated - from the file “PCX.plugin”
                   Photocopy 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Photoshop 3D Engine 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
                   Photoshop Touch CC (14.2.0.0) ©1993-2014 Adobe Systems Incorporated - from the file “PSDX.plugin”
                   Picture Package Filter 14.2 x001  ©1993-2014 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                   Pinch 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Pixar 14.2 x001  ©1989-2014 Adobe Systems Incorporated - from the file “Pixar.plugin”
                   Plaster 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Plastic Wrap 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   PNG 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Pointillize 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Polar Coordinates 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Portable Bit Map 14.2 x001  ©1989-2014 Adobe Systems Incorporated - from the file “PBM.plugin”
                   Poster Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Radial Blur 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Radiance 14.2 x001  ©2003-2014 Adobe Systems Incorporated - from the file “Radiance.plugin”
                   Range 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Read Watermark NO VERSION - from the file “DigiRead.plugin”
                   Reticulation 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Ripple 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Rough Pastels 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Save for Web 14.2, Copyright © 1999-2014 Adobe Systems Incorporated - from the file “Save for Web.plugin”
                   ScriptingSupport 14.2, Copyright © 2014 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
                   Shake Reduction 14.2, Copyright © 2014 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
                   Shear 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Skewness 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Smart Blur 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Smudge Stick 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Solarize 14.2 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Solarize.plugin”
                   Spatter 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Spherize 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Sponge 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Sprayed Strokes 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Stained Glass 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Stamp 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Standard Deviation 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                   STL 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Sumi-e 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Summation 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Targa 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Texturizer 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Tiles 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Torn Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Twirl 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Underpainting 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Vanishing Point 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
                   Variance 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Water Paper 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Watercolor 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Wave 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Wavefront|OBJ 14.2 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Wind 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Wireless Bitmap 14.2 x001  ©1989-2014 Adobe Systems Incorporated - from the file “WBMP.plugin”
                   ZigZag 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                Optional and third party plug-ins:
                   Topaz DeNoise 5 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_denoise5.plugin”
                Plug-ins that failed to load: NONE
                Flash:
                   Mini Bridge
                   Kuler
                   Adobe Exchange
                Installed TWAIN devices: NONE
                • 5. Re: Lens Blur
                  bdyomtov Level 1
                  OK.
                  I did that. I saved the selection and then used that channel as the "Depth Map." It blurred the unselected area rather than the selected. Then I backed up, clicked as you suggest, and reapplied the filter. Now the selected area got blurred, as the "Blur Focal Distance" went from 255 to 0. I assume this deals with how to handle gray areas in a mask somehow.
                  Fine. I see, more or less, how it works now. Thank you very much.
                  But is this explained anywhere? I couldn't find it, even in an Adobe video that purports to explain lens blur. Are we just supposed to figure it out through pain and suffering?
                  • 6. Re: Lens Blur
                    You may have marked an answer, but you absolutely should not have to make a special channel to use Lens Blur on a selection.
                    If it is blurring pixels you do not have selected, then it is a bug - and apparently one not seen on all systems.
                    Note:
                    -Noel
                    • 7. Re: Lens Blur
                      bdyomtov Level 1
                      It's not clear why you reposted these two images, but as you can see from my images, it definitely blurs pixels I haven't selected.
                      As far as I can tell, it needs (on my system anyway) to be told how to interpret the selection/alpha channel. Blur selected or unselected, black or white on a mask?
                      I do find it strange.
                      Is there a simple way to get Adobe to address it?
                      • 8. Re: Lens Blur
                        I posted the images to illustrate to you that what you tried to do is perfectly legitimate, and that you shouldn't have to do backflips to get Lens Blur to respect your selection (you did ask, "Are we just supposed to figure it out through pain and suffering?").
                        As far as reporting it to Adobe, you've done about as well as you can by posting it here.
                        Since a lot of things have been moved to the GPU lately, I wonder if recent changes by Adobe have uncovered a deficiency in your display driver...
                        Here's something to try:
                        1.  Go into your Performance preferences panel, and uncheck the [ ] Use Graphics Processor checkbox.
                        2.  Close Photoshop and restart it to ensure the setting change takes.
                        3.  Try the Lens Blur function again with a selection.
                        If you find it to work now, then chances are something's amiss with your display driver.  We can discuss what to do next in that case.
                        -Noel
                        • 9. Re: Lens Blur
                          bdyomtov Level 1
                          Ok.
                          I turned that off and it worked fine.
                          I then turned it back on and it worked again.
                          I believe my problem has to do with the "Depth Map" controls. If I hit "Layer Mask," as the source, which I may have done before, it seems to ignore the selection (there was no layer mask, of course). If I use "none," as I did on these two tests, the selection method works.
                          That turns off the very confusingly named "Blur Focal Distance" slider and leaves it at zero. Apparently, if you use a layer mask, this slider somehow tells PS how far from the selected area the blur should be or something of that nature. So at zero it's right on it.
                          When I turned the selection into a channel and then used that channel as the source of the depth map the slider came to life. When I moved it from zero to 255 the blur shifted from the selected to the unselected area. I suppose if I used the layer mask and put in some gray that would have an effect.
                          Who knows. Certainly not a PS user who relies on Adobe for information.
                          • 10. Re: Lens Blur
                            bdyomtov Level 1
                            OK.
                            So here's how it works.
                            It needs a "Depth map." The layer mask provides that, with different shades apparently indicating different distances, from 0 to 255. The "Blur Focal Distance" then tells it what distance is in focus, with 255 for white areas on the mask and 0 for black areas. You can invert this. Seems to me it should just say "Focal Distance," with 0 being white, etc. That would be more intuitive, but what do I know?
                            The "Radius" then adjusts the maximum blur. In effect, I think, it establishes the range of blurring, so if you want almost no depth of field you set it high so the black areas are really out of focus, and so on.
                            Those are my guesses, anyway.
                            • 11. Re: Lens Blur
                              Thanks pretty much how it works.  Just wish they'd make this work with Smart Objects.  I like this filter a lot!
                              • 12. Re: Lens Blur
                                bdyomtov Level 1
                                Good. But why was it so hard to ferret this out?
                                Are you listening, Adobe? Are you listening, Photoshop book writers and the like?
                                Everyone is full of examples, vague discussions, and step-by-step instructions: "Now click on this and see how wonderful the image looks." But that's useless if you don't understand what you're doing.
