0 Replies Latest reply on Feb 25, 2014 8:44 AM by tibay
    Using CFGrid with groupfield attibute displaying different column headers/data for each group
    tibay
      I'm trying to use CFGRID with groupfield attribute to display search results on a page.  The results data depending on the criteria being used by a user may result to many different product category.  Each product category has many different fields although there are some fields that are common to all product category.  So far I was able to display the result in group; however, it only displays the columns based on the first group.  Below is my code as my test.  There are 100+ fields, but have to simplify for testing purposes.
      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
      <html xmlns="http://www.w3.org/1999/xhtml">
      <head>
      <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
      <title>Untitled Document</title>
      </head>
      <body>
      <cfquery name="qGetProductsCategory" datasource="#application.DSN#">
          SELECT referenceunitid,referencesource, ID,orderyear, startupyear, fwclient,plantname,PlantCountry,UnitNo,
                      ProductId, Product,
                      CASE WHEN ProductId NOT IN (101600,101601,101602, 102100, 102157) THEN 101552
                      ELSE ProductId
                      END AS ProductCategoryId,
                      CASE WHEN ProductId=101600 THEN 'CNDR'
                      WHEN ProductId=101601 THEN 'FWH'
                      WHEN ProductId=102100 THEN 'GASIFIER'
                      WHEN ProductId=101602 THEN 'HRSG'
                      WHEN ProductId=102157 THEN 'SCRUBBER'
                      ELSE 'BOILERS'
                      END AS ProductCategory,
                      case when prifuel is not null then prifuel
                      else prifueltype
                      End as show_prifueldesc,
                      case when secfuel is not null then secfuel
                      else secfueltype
                      end as show_secfueldesc,
                      supplycompanies
             FROM vUnitsAllData
      </cfquery>
      <cfform name="gridform">
          <cfgrid
             name="ProductsGrid"
             format="HTML"
             query="qGetProductsCategory"
             collapsible="true"
             groupfield="ProductCategory">
              <cfif qGetProductsCategory.productcategory eq 'boilers'>
                <cfgridcolumn name="referenceunitid" header="ID" /> <!---tried to repeat many columns below but still did not work--->
                <cfgridcolumn name="referencesource" header="Ref Source" />
                <cfgridcolumn name="orderyear" header="Order Year" />
                <cfgridcolumn name="startupyear" header="Start-up Year" />
                <cfgridcolumn name="fwclient" header="Client" />
                <cfgridcolumn name="plantname" header="Plant Name" />
                <cfgridcolumn name="PlantCountry" header="Plant Country" />
                <cfgridcolumn name="unitno" header="Unit No" />
                <cfgridcolumn name="productid" header="ProductId" />
                <cfgridcolumn name="product" header="Product" />
                <cfgridcolumn name="productcategoryid" header="Product CategoryId" />
                <cfgridcolumn name="productcategory" header="Product Category" />
               <cfelseif qGetProductsCategory.productcategory eq 'HRSG'>
                    <cfgridcolumn name="show_prifueldesc" header="Primary Fuel" />
                    <cfgridcolumn name="show_secfueldesc" header="Secondary Fuel" />
               <cfelse>
                        <cfgridcolumn name="supplycompanies" header="Supplying Co" />
                </cfif>
          </cfgrid>
      </cfform>
      </body>
      </html>
      What I would like to do, is depending on the product category, the column headers and data changes.  Is this possible in CF10?
      Thanks.
