1 Reply Latest reply on Mar 2, 2014 5:28 AM by try67
    Hide one layer, and remove the visible layers using preflights!
    Johanet Level 1
      Hello,
      I have one pdf (with one layer called "ARTWORK")  in which I create a layer using Javascript. To do this I create a watermark and asigning it to a OCG contents with this code:
      this.addWatermarkFromText("watermark");
      this.getOCGs();
      function FindOCG(cName) {
          var aOCGs = this.getOCGs();
          for(var i=0; aOCGs && i<aOCGs.length;i++) {
              if(aOCGs[i].name == cName) return aOCGs[i];
          return null;
      var ocg = null;
      while( (ocg = FindOCG("Watermark")) != null) ocg.name = "NEW LAYER";
      this.setOCGOrder(this.getOCGs());
      Then I successfully run a preflight profile, which is able to select an object filled with a defined spot colour and put it on the layer named "NEW LAYER"
      The result of this is that I have two layers, (ARTWORK and NEW LAYER)
      But when I want to view ONLY the contents of the NEW LAYER, it is necessary to  show the ARTWORK layer as well, otherwise I see the only the text "watermark" added in the Javascript.
      My intention is hide the ARTWORK layer and show only the elements that I moved to the NEW LAYER, running the following Javascript code:
      var ocgs = this.getOCGs();
      for (var i in ocgs) {
          if (ocgs[i].name=="NEW LAYER")
              ocgs[i].state = true;
      else ocgs[i].state = false;
      and then run another preflight to remove invisible layers.
      But it seems  that even that I move the elements to the new layer, somehow they still remain in the artwork layer...
      Anyone could help me to solve this, please?
      Thanks and Regards.
