1 Reply Latest reply on Feb 25, 2014 12:37 PM by julien_anquetil
    Place X asset on each Page JS
    julien_anquetil
      I'm working with assets from library and a xml. My goal is to read an XML file and count number of element.
      Then get nb element and place 6 assets by page.
      Before trying do it with xml value, I try to do it with Fixed Value.
      var myPages = myDoc.pages;
      var libraryFilePath=new File("/Users/Mitchum/Desktop/catalogue2015/ressources/Library.indl");
      app.open(File(libraryFilePath));
      myAsset = app.libraries[0].assets.item("test"); // name of the asset
      for (var pg =1; myPages.length>pg; pg++)
          if (myPages[pg].side==PageSideOptions.RIGHT_HAND){//Page de droite
               if (pg ==0){//check right firstpage
                  var myObj = myAsset.placeAsset(app.documents.item(0))[0];; //first place library in first page
                  myObj.move (myPages[pg]);
                  myObj.move ( [12, 15] );//change ur x.y coodinate as per ur requirement
              else{
                  myObj.move ( [210, 30] )
          if(myPages[pg].side==PageSideOptions.LEFT_HAND){
                  var myObj = myAsset.placeAsset(app.documents.item(0))[0]; //first place library in first page
      With some search on this forum I got this to place One asset by page.
      But I'm pretty lost to know how to "repeat" the process.
      I try to do a loop like
      for (var i = 0;i<7;i++){
                         alert(i);
                          //premier element
                          if(i==0){
                               var myObj = myAsset.placeAsset(app.documents.item(i))[0]; //first place library in first page
                              myObj.move ( [10, 30] );//change ur x.y coodinate as per ur requirement
                           else if(i==1){
                              myObj.move ( [103, 30] );//change ur x.y coodinate as per ur requirement
                          else if(i==2){
                              myObj.move ( [10, 110] );//change ur x.y coodinate as per ur requirement
                           else if(i==3){
                              myObj.move ( [103, 110] );//change ur x.y coodinate as per ur requirement
                            else if(i==4){
                              myObj.move ( [10, 190] );//change ur x.y coodinate as per ur requirement
                            else if(i==5){
                              myObj.move ( [103, 190] );//change ur x.y coodinate as per ur requirement
      But it's working for 3 element but fail on the 4th with an error like "30477 error, incorrect value for parameter "on" of methode "placeasset" Document or Text waiting but nothing get (I translate error message cause I'm on FR indesign)
      By the way, I think there is a better way to do this like all my elseif no ?
      Thanks for your Help !
        • 1. Re: Place X asset on each Page JS
          julien_anquetil Level 1
          Wow I didn't see I faill in app.documents.item(i).
          Like that it's working :
                            // alert(app.documents.item(0));
                              //premier element
                              if(i==0){
                               else if(i==1){
                              else if(i==2){
                               else if(i==3){
                                else if(i==4){
                                else if(i==5){
