1 Reply Latest reply on Feb 25, 2014 1:19 PM by osgood_
    Input date format validation
    barrydocks Level 1
      Following on from a previous thread http://forums.adobe.com/thread/1413595
      I would like to validate the format of an input date.  I have used form validation to ensure that manditory fields are completed, how do I make the dob field also check the date format entered at the same time?
      Heres the validation script gnereated by DM:
      <script language="JavaScript" type="text/JavaScript">
      function MM_findObj(n, d) { //v4.01
        var p,i,x;  if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
          d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
        if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
        for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
        if(!x && d.getElementById) x=d.getElementById(n); return x;
      function MM_validateForm() { //v4.0
        var i,p,q,nm,test,num,min,max,errors='',args=MM_validateForm.arguments;
        for (i=0; i<(args.length-2); i+=3) { test=args[i+2]; val=MM_findObj(args[i]);
          if (val) { nm=val.name; if ((val=val.value)!="") {
            if (test.indexOf('isEmail')!=-1) { p=val.indexOf('@');
              if (p<1 || p==(val.length-1)) errors+='- '+nm+' must contain an e-mail address.\n';
            } else if (test!='R') { num = parseFloat(val);
              if (isNaN(val)) errors+='- '+nm+' must contain a number.\n';
              if (test.indexOf('inRange') != -1) { p=test.indexOf(':');
                min=test.substring(8,p); max=test.substring(p+1);
                if (num<min || max<num) errors+='- '+nm+' must contain a number between '+min+' and '+max+'.\n';
          } } } else if (test.charAt(0) == 'R') errors += '- '+nm+' is required.\n'; }
        } if (errors) alert('The following error(s) occurred:\n'+errors);
        document.MM_returnValue = (errors == '');
      </script>
      Here's the php to submit the form:
      <form action="<?php echo $editFormAction; ?>" method="post" name="form1" onSubmit="MM_validateForm('firstname','','R','surname','','R','dob','','R');return document.MM_returnValue">
        • 1. Re: Input date format validation
          osgood_ Level 8
          I Googled for this and came up with a solution http://jsfiddle.net/EywSP/849/
          Below is the same code as at the url above BUT I have replaced the / with - so the date should be good to be inserted into the database.
          <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
          <html>
          <head>
          <meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
          <title>Untitled Document</title>
          <script src="http://code.jquery.com/jquery-1.10.2.min.js"></script>
          <script>
          $(function() {
              $('#btnSubmit').bind('click', function(){
                  var txtVal =  $('#txtDate').val();
                  if(isDate(txtVal))
                      alert('Valid Date');
                  else
                      alert('Invalid Date');
          function isDate(txtDate)
              var currVal = txtDate;
              if(currVal == '')
                  return false;
              var rxDatePattern = /^(\d{4})(\-|-)(\d{1,2})(\-|-)(\d{1,2})$/; //Declare Regex
              var dtArray = currVal.match(rxDatePattern); // is format OK?
              if (dtArray == null)
                  return false;
              //Checks for mm/dd/yyyy format.
              dtMonth = dtArray[3];
              dtDay= dtArray[5];
              dtYear = dtArray[1];
              if (dtMonth < 1 || dtMonth > 12)
                  return false;
              else if (dtDay < 1 || dtDay> 31)
                  return false;
              else if ((dtMonth==4 || dtMonth==6 || dtMonth==9 || dtMonth==11) && dtDay ==31)
                  return false;
              else if (dtMonth == 2)
                  var isleap = (dtYear % 4 == 0 && (dtYear % 100 != 0 || dtYear % 400 == 0));
                  if (dtDay> 29 || (dtDay ==29 && !isleap))
                          return false;
              return true;
          </script>
          </head>
          <body>
          Date : <input type="text" id="txtDate" /> (yyyy-mm-dd)
          <br/><br/><br/>
          <input type="button" value="ValidateDate" id="btnSubmit"/>
          </body>
          </html>
