8 Replies Latest reply on Feb 26, 2014 10:57 AM by hemanthR
    Set browser (not stage) background to gradient
    mdharrington1
      HI...
      Very noob to css and all....
      I am trying to set my browseer background to a radial gradient...but I dont know the proper syntax.
      I am trying to reconcile this pages code
      http://www.w3schools.com/css/css3_gradients.asp....
      #grad
      /* Safari 5.1 to 6.0 */
      background: -webkit-repeating-linear-gradient(red, yellow 10%, green 20%);
      /* Opera 11.1 to 12.0 */
      background: -o-repeating-linear-gradient(red, yellow 10%, green 20%);
      /* Firefox 3.6 to 15 */
      background: -moz-repeating-linear-gradient(red, yellow 10%, green 20%);
      /* Standard syntax */
      background: repeating-linear-gradient(red, yellow 10%, green 20%);
      and somehow inject it into a composition ready statement like this
      $("body").css("background-color","#000");
      Ideally i would like a gradient to border the edges of the stage, just in the browser background instead of a solid color
        • 1. Re: Set browser (not stage) background to gradient
          hemanthR Adobe Employee
          To set your background to a gradient, you could add the above code in the style tag of the html file published by Aniamate i.e
          <style>
          .edgeLoad-EDGE-123145483 { visibility:hidden; }//this is added  by Animate
          body
          </style>
          • 2. Re: Set browser (not stage) background to gradient
            mdharrington1 Level 1
            Wow, thanks for the prompt answer....
            So no way to do this inside edge?
            I was just hoping to see it in the preview browser....not a big deal though
            • 3. Re: Set browser (not stage) background to gradient
              didnt seem to work...tried in IE and Chrome
              this is the code
              <!DOCTYPE html>
              <html>
              <head>
                        <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
                        <meta http-equiv="X-UA-Compatible" content="IE=Edge"/>
                        <title>Divine Eye Studios</title>
              <!--Adobe Edge Runtime-->
                  <script type="text/javascript" charset="utf-8" src="divine%20eye_edgePreload.js"></script>
                  <style>
                      .edgeLoad-EDGE-546946741 { visibility:hidden; }
                                  body
                  </style>
              <!--Adobe Edge Runtime End-->
              </head>
              <body style="margin:0;padding:0;">
                        <div id="Stage" class="EDGE-546946741">
                        </div>
              </body>
              </html>
              • 4. Re: Set browser (not stage) background to gradient
                Hey HI,
                You can definitely add this within Aniamte too.
                In creation complete  ,add the below lines
                $("body").css({
                "background": "-webkit-repeating-linear-gradient(red, yellow 10%, green 20%)",
                "background": "-o-repeating-linear-gradient(red, yellow 10%, green 20%)",
                "background":" -moz-repeating-linear-gradient(red, yellow 10%, green 20%)",
                "background":" -ms-repeating-linear-gradient(red, yellow 10%, green 20%)",
                "background":" repeating-linear-gradient(red, yellow 10%, green 20%)"
                I check the code both on Chrome 33 and IE 11.Its working for me.
                • 5. Re: Set browser (not stage) background to gradient
                  I got it to work in a new composition...but not my existing composition... even though I removed the code I had in for the solid background
                  should only be a small matter to fix
                  Thanks for the help...
                  • 6. Re: Set browser (not stage) background to gradient
                    darsh136
                    Hello,
                    If you want to create some great gradient background in css3 there are free online tool that can help you:
                    http://www.colorzilla.com/gradient-editor/
                    Darsh
                    • 7. Re: Set browser (not stage) background to gradient
                      Thanks Darsh....thats a useful tool
                      rhemanthkumar,
                      I just think I discovered the problem....but not the solution
                      When 'center stage' is enabled....the gradients don't work
                      • 8. Re: Set browser (not stage) background to gradient
                        That seems to be because the margin of stage is set to auto and the left,right,top,bottom are all 0px,thus your stage is completely covering the body.
