2 Replies Latest reply on Sep 9, 2014 4:04 AM by TerjeUnhjem
    How do I change the PS language from Norwegian to UK/US english?
    torelh
        • 1. Re: How do I change the PS language from Norwegian to UK/US english?
          PECourtejoie Adobe Community Professional
          Hello, it all depends what version you are running. for CC or CS6 via creative cloud, change the language of the CC application, then reinstall with that language. You will be then be able to change the language of Photoshop via preferences/interface. For older version, there is a way to remove a file, but it's not officially supported. (google can help)
          • 2. Re: How do I change the PS language from Norwegian to UK/US english?
            TerjeUnhjem Level 1
            Hello
            I had the same question minutes ago, and got this answer (from polish to english, but the prosedure is the same) and it worked perfectly! (I own a PS CC 2014 btw, still works the same way!)
            Simply navigate to this directory: C:\Program Files\Adobe\Adobe Photoshop CS5.1\Locales\sv_SE\Support Files
            the sv_SE folder is named such because my version is Swedish. Just find the similar named folder that looks like it should correspond with your language.
            In the support files directory there will be a file named tw10428.dat
            Make sure that photoshop is closed, change the file extension to .bak  instead of .dat, and then restart photoshop.
            Your software will now be in English.
