4 Replies Latest reply on Jun 20, 2006 9:38 AM by cpbittner
    Mouse.listener
    cpbittner
      Is there a way to use the Mouse.listener to detect what the name of the item is that you clicked on. I have instances where the button or movieclip functions are not correctly picking up the release or mouseUp events but the Mouse.listener is shwoing me it is not missing a click, so I want to use the listener in some areas as the click detection driver, but need to know what the user clicked on.
        • 1. Re: Mouse.listener
          Level 7
          cpbittner,
          Not really. You could use something like MovieClip.hitTest() to cycle
          through all the available movie clips until you find the one under the
          mouse, but that could potentially be pretty tedious -- and, in any case, is
          unecessary.
          Aha! Well, there's your issue, then. :) Let's see example code for a
          movie clip whose events aren't being handled. Let's fix your problem at the
          source, rather than evading it.
          David
          stiller (at) quip (dot) net
          Dev essays: http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: Mouse.listener
            cpbittner Level 1
            The code for the button is:
            next.onRelease = function() {
            goNextPage();
            Unfortunately, I am dealing with a training shell that has a ton of legacy code, with no budget/time/permission to start yanking code to clean it up. (There is no money to clean up the shell - but yet I have put numerious hours into debugging misc behaviors - go figure) I wanted to use the mouse listener for debugging, but found a different way to test. Turns out the button is thinking the user has rolled off the button when the user is clicking the button even if the user stays put and does not move the mouse - but only after the user has clicked on an asfucntion hyperlink on a page that contains a hyperlink. So it appears the asfunction command is affecting something. I've got to narrow down the behavior more then determine how to repost the issue.
            • 3. Re: Mouse.listener
              Level 7
              cpbittner,
              > goNextPage();
              I can only assume that goNextPage() is a custom function, because it
              doesn't appear in the ActionScript Language Reference. It may be that on
              examples like this, you're assuming the onRelease event doesn't fire because
              nothing happens -- but maybe in actuality, it could be that goNextPage()
              doesn't do anything.
              The Button.onRelease event always fires. Prove it to yourself by adding
              a trace() function to that same button:
              trace("supposed to trigger goNextPage()");
              goNextPage();
              You'll see the the quoted string in your Output panel.
              In fact, you can use trace() to output the button's instance name, which
              is what you were asking for earlier:
              trace(this._name);
              goNextPage();
              The "Button class" entry of the ActionScript 2.0 Language Reference will
              show you everything a button offers. As with all class entries, you'll find
              one or more of the following three categories: properties (characteristics
              the object has), methods (things the object can do) and events (things the
              object can react to).
              Sounds like there's a lot going on under the hood on this one. I don't
              envy you the headache. ;) I really think tracing the Button._name property
              on your event handlers is the best/easiest way to troubleshoot this one.
              David
              • 4. Re: Mouse.listener
                cpbittner Level 1
                Everything still points to the asFunction call causing an issue with the buttons. I use trace to debug everything and that is how I saw that the button appeared to be getting temporarily disabled as the onRelease wasn't getting fired (no trace reply). Thanks for your feedback anyway.
