1 Reply Latest reply on Feb 28, 2014 9:15 AM by cyclux
    Calculation of cursor position is not working properly with a responsive stage
    cyclux
      Hi there,
      I already wrote in another thread about it, but my problem is slightly different to the other discussion, so here again:
      I want to display a symbol next to the cursor. It should stay there like in this example here: http://sandbox.junglecrowd.org/static/publish/web/static.html
      When using a responsive Stage (what is crucial to my project, because I need 100% width on all window sizes) the placement ot the symbol is dependent on the size of the window and the position on the screen. Here is an example of the problem:
      http://sandbox.junglecrowd.org/responsive/publish/web/responsive.html
      So, gathering the coordinates within EA seems not to be the right way.. Or does someone know a solution to compensate for the responsivness?
      My idea would be to get the coordinates outside of EA.. would this be possible? And in which way?
      ..of course, any other solutions are very welcome!
      Below is my code... As you see I'm very new to EA and coding..
      Thanks!
      BTW: I read a lot in this forum before because of other problems, and I found a lot solutions: Thanks to you all!
      // CompositionReady
      sym.createsym = function(){
      var position = sym.$("box").show();
      var position2 = sym.$("text").show();
        position.css({
          top:sym.posY, left:sym.posX
          position2.css({
      // Stage.mousemove
      sym.posX = e.pageX + 30;
      sym.posY = e.pageY;
      sym.createsym();
        • 1. Re: Calculation of cursor position is not working properly with a responsive stage
          cyclux Level 1
          I found out a solution now!
          I take the window width and make a ratio variable with the stage width... Then the stageratio gets multiplicated with the coordinates... On window resize the variables are recalculated..  here's a working example:
          http://sandbox.junglecrowd.org/responsive_works/publish/web/responsive .html
          Here's the code.. If anyone knows how to improve it please tell me
          // CompositionReady
          sym.xycompensation = function() {
          var stage = sym.$('Stage');
          var parent = sym.$('Stage').parent();
          var parentWidth = stage.parent().width();
          var stageWidth = stage.width();
          sym.scaleratio = stageWidth/parentWidth;
          sym.xycompensation();
          $(window).on('resize', function(){
          sym.infolabel = function(){
            position.css({
              position2.css({
          // Stage.mousemove
          sym.posX = e.pageX * sym.scaleratio + 30;
          sym.posY = e.pageY * sym.scaleratio;
          sym.infolabel();
