4 Replies Latest reply on Mar 10, 2014 8:02 PM by Harry_Wild
    IE 11 does not see FlashPlayer 12 in Manage Add-Ons window
    MarkO
      I have IE 11.0.9600.16518 and am trying to get flashplayer to function, because many sites do not display content and some links on various sights do not work. Because the adobe flashplayer site does not display content in IE, I used Safari to go to the site and download the necessary files. I have attempted a clean install of flashplayer by running the uninstall utility from the adobe site. I looked for the Macromed folder in Windows\SysWOW64 and it only contained a FlashInstall notepad file.  I restarted the PC, then downloaded the current flashplayer 12 installer, then ran it.  It looked like it installed, I think, but the adobe web screen remained on step 2 of 3 and I could see now way to advance to step 3. When I opened IE and attempted to manage add-ons, Adobe did not show in the window with Toolbars and Extensions selected (though many other add-ons did show). The Macromed folder in SysWOW64 still does not contain any files except the Notepad file.  I have done this process several times to make sure I didn't miss something. When I try to install flashplayer a second time, the system tells me that "only a single instance of this program can run."  So it appears the system thinks flashplayer is installed or installing, but I can't find it and IE can't see it.  Please help.
        • 1. Re: IE 11 does not see FlashPlayer 12 in Manage Add-Ons window
          MarkO Level 1
          I forgot to include this:  Windows 7 ultimate SP1, 64-bit.
          • 2. Re: IE 11 does not see FlashPlayer 12 in Manage Add-Ons window
            pwillener Level 8
            Try running these installers
            Flash Player for ActiveX (Internet Explorer)
            Flash Player Plug-in (All other browsers)
            If there is still nothing in the Flash Player install folders, can you post the contents of that FlashInstall.log file (from both C:\Windows\System32\Macromed\Flash & C:\Windows\Syswow64\Macromed\Flash).
            • 3. Re: IE 11 does not see FlashPlayer 12 in Manage Add-Ons window
              MarkO Level 1
              Thanks, Pat.  These are the actions that I took and the results:
              1.  Ran Adobe Flash Uninstaller
              2.  Rebooted
              3.  Cleaned out all four folders per the "clean install" instructions
              4.  Installed the two Flash Player executables from the links you provided (I installed both because I have IE and Safari browsers installed)
              5.  Checked the System32 and SysWOW64 folders and they contained exe files and installation logs which I will attach
              6.  Opened up IE 10 (I had previously reverted from IE 11 based on other comments in this forum), but then realized that the new flash player might only be for IE 11
              7.  Installed IE 11 through windows update
              8.  Opened IE 11, and Manage Add-Ons now shows Adobe Shockwave Flash Object, enabled (32-bit and 64-bit).
              9.  Tried YouTube -- video windows remain black and the "loading" wheel spins continuously; tried other sites and seemed to have similar results
              10.  Opened Safari (ver 5.1.7), ensured Java was enabled, and had similar results
              11.  I'm interpreting my problems as being due to Flash Player, though I could be incorrect.  For example, when trying to log in to this forum discussion, IE 11 took me to the sign-in page, displayed the "Joint the Adobe Community" header, and showed a continuos spinning wheel.  Safari produced similar results, except it let me enter email address and password before going into the spinning wheel mode.  When I used Chrome to sign-in, all worked fine (I'm assuming because Chrome comes with flash already loaded.)
              12.  Below are the two installation log files.
              C:\Windows\System32\Macromed\Flash\FlashInstall.log
              =O====== M/12.0.0.70 2014-03-01+19-45-41.194 ========
              0000 [I] 00000010 "C:\Users\Mark\AppData\Local\Temp\{F1269D8C-E5EC-4F58-96A9-52FE88EF9F36}\InstallFlashPlay er.exe" -install -skipARPEntry -iv 1 -au 4294967295
              0001 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/12.0 2
              0002 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0003 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0004 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
              0005 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
              0006 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash64_12_0_0_70.ocx
              0007 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_70_ActiveX.exe
              0008 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_70_ActiveX.dll
              0009 [I] 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
              0010 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
              =X====== M/12.0.0.70 2014-03-01+19-45-43.567 ========
              =O====== M/12.0.0.70 2014-03-01+19-46-48.035 ========
              0000 [I] 00000010 "C:\Users\Mark\AppData\Local\Temp\{EB75B0DF-D944-4E78-AD17-315A21301096}\InstallFlashPlay er.exe" -install -skipARPEntry -iv 1 -au 4294967295
              0001 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
              0002 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0003 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
              0004 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
              0005 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
              0006 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
              0007 [W] 00001036 Software\Opera Software/Last CommandLine 2
              0008 [W] 00001036 Software\Opera Software/Last CommandLine 2
              0009 [W] 00001036 Software\Opera Software/Plugin Path 2
              0010 [W] 00001036 Software\Opera Software/Plugin Path 2
              0011 [I] 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_12_0_0_70.dll
              0012 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_70_Plugin.exe
              0013 [I] 00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
              0014 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
              =X====== M/12.0.0.70 2014-03-01+19-46-50.120 ========
              C:\Windows\SysWOW64\Macromed\Flash\FlashInstall.log
              =O====== M/12.0.0.70 2014-03-01+19-45-33.448 ========
              0000 [I] 00000010 "C:\Users\Mark\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\XSTBBMZJ\install_flash_player_ax.exe"
              0004 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/12.0 2
              0005 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0006 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0007 [I] 00000011 1
              0008 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
              0009 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
              0010 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_12_0_0_70.ocx
              0011 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.exe
              0012 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.dll
              0013 [I] 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
              0015 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
              =X====== M/12.0.0.70 2014-03-01+19-45-58.662 ========
              =O====== M/12.0.0.70 2014-03-01+19-46-22.767 ========
              0000 [I] 00000010 "C:\Users\Mark\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\MJUNO48D\install_flash_player.exe"
              0003 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0004 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0005 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0006 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0007 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0008 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0009 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0010 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0011 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0012 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0013 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0014 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0015 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0016 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0017 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0018 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0019 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0020 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0021 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0022 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0023 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0024 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
              0025 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0026 [I] 00000011 1
              0027 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
              0028 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
              0029 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
              0030 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
              0031 [W] 00001036 Software\Mozilla\Thunderbird\extensions/Plugins 2
              0032 [W] 00001036 Software\Opera Software/Last CommandLine 2
              0033 [W] 00001036 Software\Opera Software/Last CommandLine 2
              0034 [W] 00001036 Software\Opera Software/Plugin Path 2
              0035 [W] 00001036 Software\Opera Software/Plugin Path 2
              0036 [I] 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_12_0_0_70.dll
              0037 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_Plugin.exe
              0038 [I] 00000024 C:\Windows\SysWOW64\Macromed\Flash\plugin.vch
              0039 [I] 00000017 C:\Windows\SysWOW64\Macromed\Flash
              0040 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_12_0_0_70.exe
              0041 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
              0042 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
              0043 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
              0044 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
              0045 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
              =X====== M/12.0.0.70 2014-03-01+19-47-26.767 ========
              • 4. Re: IE 11 does not see FlashPlayer 12 in Manage Add-Ons window
                Harry_Wild
                I have the exact same problem! I done everything I can thing of to install Adobe Flash Player 12 and have it recognize by either Windows 7 or IE 11.
                I unloaded it using Adobe's uninstall app and shut off my computer.
                I start it back up again and then shut if off again for the second time.
                I downloaded and run Flash Player 12.
                try it and on an video - ask again for upgrading.  For fun I upgraded it 6 times in a row and still it said to upgrade needed.
                Installed Flash Player with Xactive
                Shut down Windows 7
                Start it up again - go to an video and still ask to upgrade to the latest Flash Player!
                Uninstalled IE 11 and reboot computer.
                Go to IE10
                Use IE10 to view video - same thing - need latest Flash.  Upgrade latest Flash again and then shut off computer.
                Start it back up and go to video and ask to upgrade to latest Flash before it can show video.
                I am so frustrated.
                Why can't Windows 7 and IE  recognized the installation of Flash Player 12?
                Anyone?
                Here is my log ->c:\windows\syswow64\macromed\flash\flashinstall.log:
                =O====== M/11.5.502.110 2012-12-01+10-36-08.040 ========
                0000 [W] 00001113 C:\Windows\SysWOW64\Macromed\Flash\\* 3
                0001 [I] 00000010 "C:\ProgramData\Adobe\AIH.ef18c66ee4c55e42825082903d380d0668d9a593\install_flash_player_a x.exe" -install -iv 8 -au 0
                0002 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
                0004 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0005 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                0006 [I] 00000011 1
                0007 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                0008 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_5_502_110.ocx
                0009 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_110_ActiveX.exe
                0010 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_110_ActiveX.dll
                0011 [I] 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
                0012 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                0013 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                0014 [I] 00000012
                =X====== M/11.5.502.110 2012-12-01+10-36-15.828 ========
                2012-12-7+8-34-0.218 [error] 1223 1056
                2012-12-12+16-52-36.165 [error] 1214 12007
                2012-12-12+16-52-36.165 [error] 1234 0
                2012-12-14+3-34-19.590 [error] 1226 1062
                =O====== M/11.5.502.135 2012-12-14+03-34-08.873 ========
                0000 [I] 00000010 FlashPlayerInstaller.exe -install -iv 9
                0001 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                0002 [I] 00000011 1
                0003 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_5_502_110.ocx 5
                0004 [I] 00000018
                0005 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_5_502_110.ocx 5
                0006 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_5_502_135.ocx
                0007 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_135_ActiveX.exe
                0008 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_135_ActiveX.dll
                0009 [I] 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
                0011 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                0012 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                0014 [W] 00001106
                0015 [W] 00001106
                0016 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                0017 [I] 00000012
                =X====== M/11.5.502.135 2012-12-14+03-34-20.807 ========
                2013-1-7+6-34-0.213 [error] 1223 1056
                2013-1-8+20-34-17.468 [error] 1226 1062
                =O====== M/11.5.502.146 2013-01-08+20-34-08.919 ========
                0002 [I] 00000011 1
                0003 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_5_502_135.ocx 5
                0004 [I] 00000018
                0005 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_5_502_135.ocx 5
                0006 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_135_ActiveX.exe 5
                0007 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_5_502_146.ocx
                0008 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_146_ActiveX.exe
                0009 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_146_ActiveX.dll
                0010 [I] 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
                0011 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                0012 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                0013 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                0014 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                0015 [W] 00001106
                0016 [W] 00001106
                0017 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                0018 [I] 00000012
                =X====== M/11.5.502.146 2013-01-08+20-34-18.700 ========
                2013-1-13+10-34-0.219 [error] 1223 1056
                =O====== M/11.5.502.146 2013-01-21+01-48-30.249 ========
                0000 [I] 00000010 "C:\Users\Harry\AppData\Local\Temp\{13BAEE5F-C349-4004-823D-B39CF2876DB3}\InstallFlashPla yer.exe" -iv 6
                0002 [I] 00000011 1
                0003 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_5_502_146.ocx
                0004 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_146_ActiveX.exe
                0005 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_146_ActiveX.dll
                0006 [I] 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
                0007 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                0008 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                0009 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                0010 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                0011 [W] 00001106
                0012 [W] 00001106
                0013 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                0014 [I] 00000012
                =X====== M/11.5.502.146 2013-01-21+01-50-09.138 ========
                =O====== M/11.5.502.146 2013-01-21+01-48-21.565 ========
                0000 [I] 00000010 C:\Users\Harry\AppData\Local\Temp\IDC2.tmp\FP_AX_CAB_INSTALLER64.exe
                0001 [I] 00000011 1
                =X====== M/11.5.502.146 2013-01-21+01-50-09.153 ========
                2013-2-8+0-34-19.840 [error] 1226 1062
                =O====== M/11.5.502.149 2013-02-08+00-34-08.514 ========
                0002 [I] 00000011 1
                0003 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_5_502_146.ocx 5
                0004 [I] 00000018
                0005 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_5_502_146.ocx 5
                0006 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_146_ActiveX.exe 5
                0007 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_5_502_149.ocx
                0008 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_149_ActiveX.exe
                0009 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_149_ActiveX.dll
                0015 [W] 00001106
                0016 [W] 00001106
                0018 [I] 00000012
                =X====== M/11.5.502.149 2013-02-08+00-34-21.103 ========
                =O====== M/11.6.602.168 2013-02-14+07-42-13.770 ========
                0000 [I] 00000010 "C:\Users\Harry\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\RMDLOHWN\install_flash_player_ax.exe"
                0001 [I] 00000011 1
                0002 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                0003 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_5_502_149.ocx 5
                0004 [I] 00000018
                0005 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_5_502_149.ocx 5
                0006 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_149_ActiveX.exe 5
                0007 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_6_602_168.ocx
                0008 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_168_ActiveX.exe
                0009 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_168_ActiveX.dll
                0015 [W] 00001106
                0016 [W] 00001106
                =X====== M/11.6.602.168 2013-02-14+07-42-34.130 ========
                2013-3-3+9-34-19.500 [error] 1226 1062
                =O====== M/11.6.602.171 2013-03-03+09-34-09.642 ========
                0001 [I] 00000011 1
                0003 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_6_602_168.ocx 5
                0004 [I] 00000018
                0005 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_6_602_168.ocx 5
                0006 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_168_ActiveX.exe 5
                0007 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_6_602_171.ocx
                0008 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_171_ActiveX.exe
                0009 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_171_ActiveX.dll
                0015 [W] 00001106
                0016 [W] 00001106
                0018 [I] 00000012
                =X====== M/11.6.602.171 2013-03-03+09-34-20.733 ========
                =O====== M/11.6.602.171 2013-03-13+06-34-09.629 ========
                0001 [F] 00001041
                =X====== M/11.6.602.171 2013-03-13+06-34-10.269 ========
                2013-3-13+16-34-27.761 [error] 1226 1062
                =O====== M/11.6.602.180 2013-03-13+16-34-16.826 ========
                0001 [I] 00000011 1
                0003 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_6_602_171.ocx 5
                0004 [I] 00000018
                0005 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_6_602_171.ocx 5
                0006 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_171_ActiveX.exe 5
                0007 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_6_602_180.ocx
                0008 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.exe
                0009 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.dll
                0015 [W] 00001106
                0016 [W] 00001106
                0018 [I] 00000012
                =X====== M/11.6.602.180 2013-03-13+16-34-28.994 ========
                =O====== M/11.7.700.169 2013-04-22+19-51-02.011 ========
                0000 [I] 00000010 "C:\ProgramData\Adobe\AIH.b834c323a3556eb42cc7c50cbd7c1d4bf87c6652\install_flash_player_a x.exe" -install -iv 10
                0001 [I] 00000011 1
                0003 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_6_602_180.ocx 5
                0004 [I] 00000018
                0005 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_6_602_180.ocx 5
                0006 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.exe 5
                0007 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_7_700_169.ocx
                0008 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_169_ActiveX.exe
                0009 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_169_ActiveX.dll
                0015 [W] 00001106
                0016 [W] 00001106
                0018 [I] 00000012
                =X====== M/11.7.700.169 2013-04-22+19-51-08.021 ========
                =O====== M/11.7.700.169 2013-04-23+09-04-47.687 ========
                0000 [I] 00000010 "C:\Users\Harry\AppData\Local\Temp\{89626395-05EE-470B-8183-3311A0B662E2}\InstallFlashPla yer.exe" -iv 6
                0001 [I] 00000011 1
                0003 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_7_700_169.ocx
                0004 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_169_ActiveX.exe
                0005 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_169_ActiveX.dll
                0011 [W] 00001106
                0012 [W] 00001106
                0014 [I] 00000012
                =X====== M/11.7.700.169 2013-04-23+09-05-54.779 ========
                =O====== M/11.7.700.169 2013-04-23+09-04-38.842 ========
                0001 [I] 00000011 1
                =X====== M/11.7.700.169 2013-04-23+09-05-54.795 ========
                =O====== M/11.7.700.169 2013-04-24+16-43-15.636 ========
                0000 [I] 00000010 "C:\Users\Harry\AppData\Local\Temp\{609113C9-2B98-4047-AEB0-2B8506F908FE}\InstallFlashPla yer.exe" -iv 6
                0001 [I] 00000011 1
                0011 [W] 00001106
                0012 [W] 00001106
                0014 [I] 00000012
                =X====== M/11.7.700.169 2013-04-24+16-43-42.344 ========
                =O====== M/11.7.700.169 2013-04-24+16-43-07.010 ========
                0001 [I] 00000011 1
                =X====== M/11.7.700.169 2013-04-24+16-43-42.375 ========
                2013-5-15+9-34-15.215 [error] 1226 1062
                =O====== M/11.7.700.202 2013-05-15+09-34-06.541 ========
                0000 [I] 00000010 FlashPlayerInstaller.exe -install -iv 11
                0001 [I] 00000011 1
                0003 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_7_700_169.ocx 5
                0004 [I] 00000018
                0005 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_7_700_169.ocx 5
                0006 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_169_ActiveX.exe 5
                0007 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_169_ActiveX.exe 5
                0008 [I] 00000013 C:\Windows\TEMP\{A0707BCB-DA08-42A9-B57A-D1D8EB573F81}\Flash32_11_7_700_202.ocx
                0009 [I] 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.exe
                0010 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.exe
                0011 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.dll
                0012 [I] 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
                0013 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                0014 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                0015 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                0016 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                0017 [W] 00001106
                0018 [W] 00001106
                0019 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                0020 [I] 00000012
                =X====== M/11.7.700.202 2013-05-15+09-34-16.447 ========
                2013-6-12+4-34-13.930 [error] 1226 1062
                =O====== M/11.7.700.224 2013-06-12+04-34-07.114 ========
                0001 [I] 00000011 1
                0003 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_7_700_202.ocx 5
                0004 [I] 00000018
                0005 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_7_700_202.ocx 5
                0006 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.exe 5
                0007 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.exe 5
                0008 [I] 00000013 C:\Windows\TEMP\{94969095-E2C3-4DDE-AFB9-8D9799B2316D}\Flash32_11_7_700_224.ocx
                0009 [I] 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.exe
                0010 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.exe
                0011 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.dll
                0017 [W] 00001106
                0018 [W] 00001106
                0020 [I] 00000012
                =X====== M/11.7.700.224 2013-06-12+04-34-15.146 ========
                =O====== M/11.8.800.94 2013-07-10+16-27-35.797 ========
                0000 [I] 00000010 "C:\Users\Harry\AppData\Local\Adobe\AIH.4cf9c30282e2ed2e769f27b439a7ede692e9f923\install_ flash_player_ax.exe" -install -iv 8
                0001 [I] 00000011 1
                0003 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_7_700_224.ocx 5
                0004 [I] 00000018
                0005 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_7_700_224.ocx 5
                0006 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.exe 5
                0007 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.exe 5
                0008 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_8_800_94.ocx
                0009 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.exe
                0010 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.dll
                0013 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                0014 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                0016 [W] 00001106
                0017 [W] 00001106
                0018 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                0019 [I] 00000012
                =X====== M/11.8.800.94 2013-07-10+16-27-42.656 ========
                2013-9-4+9-34-0.207 [error] 1223 1056
                2013-9-11+4-34-17.536 [error] 1226 1062
                =O====== M/11.8.800.168 2013-09-11+04-34-05.430 ========
                0001 [I] 00000011 1
                0003 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_8_800_94.ocx 5
                0004 [I] 00000018
                0005 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_8_800_94.ocx 5
                0006 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.exe 5
                0007 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.exe 5
                0008 [I] 00000013 C:\Windows\TEMP\{BA9F5688-C687-4EC1-8738-83EF45EE2A7F}\Flash32_11_8_800_168.ocx
                0009 [I] 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_168_ActiveX.exe
                0010 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_168_ActiveX.exe
                0011 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_168_ActiveX.dll
                0017 [W] 00001106
                0018 [W] 00001106
                0020 [I] 00000012
                =X====== M/11.8.800.168 2013-09-11+04-34-18.815 ========
                2013-9-14+11-34-13.460 [error] 1226 1062
                =O====== M/11.8.800.174 2013-09-14+11-34-03.667 ========
                0001 [I] 00000011 1
                0003 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_8_800_168.ocx 5
                0004 [I] 00000018
                0005 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_8_800_168.ocx 5
                0006 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_168_ActiveX.exe 5
                0007 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_168_ActiveX.exe 5
                0008 [I] 00000013 C:\Windows\TEMP\{BF9133C2-A74E-4134-BC1F-D28B201374C6}\Flash32_11_8_800_174.ocx
                0009 [I] 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_174_ActiveX.exe
                0010 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_174_ActiveX.exe
                0011 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_174_ActiveX.dll
                0017 [W] 00001106
                0018 [W] 00001106
                0020 [I] 00000012
                =X====== M/11.8.800.174 2013-09-14+11-34-14.708 ========
                2013-9-20+4-37-2.240 [error] 1226 1062
                =O====== M/11.8.800.175 2013-09-20+04-36-45.400 ========
                0000 [I] 00000010 "C:\Users\Harry\AppData\Local\Temp\{ABBBE644-4A65-4E17-AB87-13035D916D44}\InstallFlashPla yer.exe" -iv 4
                0001 [I] 00000011 1
                0003 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_8_800_175.ocx
                0004 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe
                0005 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.dll
                0011 [W] 00001106
                0012 [W] 00001106
                0014 [I] 00000012
                =X====== M/11.8.800.175 2013-09-20+04-37-06.904 ========
                2013-10-9+1-34-15.806 [error] 1226 1062
                =O====== M/11.9.900.117 2013-10-09+01-34-05.752 ========
                0001 [I] 00000011 1
                0003 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_8_800_175.ocx 5
                0004 [I] 00000018
                0005 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_8_800_175.ocx 5
                0006 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe 5
                0007 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe 5
                0008 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_9_900_117.ocx
                0009 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.exe
                0010 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.dll
                0016 [W] 00001106
                0017 [W] 00001106
                0019 [I] 00000012
                =X====== M/11.9.900.117 2013-10-09+01-34-17.101 ========
                =O====== M/11.9.900.117 2013-10-12+20-57-03.512 ========
                0000 [I] 00000010 "C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.exe" -maintain activex
                =X====== M/11.9.900.117 2013-10-12+20-57-08.442 ========
                =O====== M/11.9.900.117 2013-10-12+20-58-20.254 ========
                0001 [F] 00001041
                =X====== M/11.9.900.117 2013-10-12+20-58-21.599 ========
                =O====== M/11.9.900.117 2013-10-12+20-58-41.057 ========
                0001 [I] 00000011 1
                0003 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_9_900_117.ocx
                0004 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.exe
                0005 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.dll
                0011 [W] 00001106
                0012 [W] 00001106
                0014 [I] 00000012
                =X====== M/11.9.900.117 2013-10-12+20-58-53.179 ========
                2013-10-31+4-34-0.231 [error] 1223 1056
                =O====== M/11.9.900.152 2013-11-14+02-14-16.337 ========
                0000 [I] 00000010 "C:\Users\Harry\AppData\Local\Adobe\AIH.d66fc191baffe432f5aeb605b98c4f3456cb6de6\install_ flash_player_ax.exe" -install -iv 10
                0001 [I] 00000011 1
                0003 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_9_900_117.ocx 5
                0004 [I] 00000018
                0005 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_9_900_117.ocx 5
                0006 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.exe 5
                0007 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.exe 5
                0008 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_9_900_152.ocx
                0009 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_152_ActiveX.exe
                0010 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_152_ActiveX.dll
                0016 [W] 00001106
                0017 [W] 00001106
                0019 [I] 00000012
                =X====== M/11.9.900.152 2013-11-14+02-14-27.327 ========
                2013-12-11+7-34-14.877 [error] 1226 1062
                =O====== M/11.9.900.170 2013-12-11+07-34-04.765 ========
                0001 [I] 00000011 1
                0003 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_9_900_152.ocx 5
                0004 [I] 00000018
                0005 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_9_900_152.ocx 5
                0006 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_152_ActiveX.exe 5
                0007 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_152_ActiveX.exe 5
                0008 [I] 00000013 C:\Windows\TEMP\{27AEB172-453E-4F51-8838-A96A0B571345}\Flash32_11_9_900_170.ocx
                0009 [I] 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_170_ActiveX.exe
                0010 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_170_ActiveX.exe
                0011 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_170_ActiveX.dll
                0017 [W] 00001106
                0018 [W] 00001106
                0020 [I] 00000012
                =X====== M/11.9.900.170 2013-12-11+07-34-16.158 ========
                =O====== M/11.9.900.170 2013-12-15+10-30-30.516 ========
                0000 [I] 00000010 "C:\Users\Harry\AppData\Local\Adobe\AIH.67e39b587695464c746800d140653cc969ed6884\install_ flash_player.exe" -install -iv 8 -au 0
                0003 [I] 00000011 1
                0005 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
                0006 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
                0007 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
                0009 [W] 00001036 Software\Opera Software/Last CommandLine 2
                0011 [W] 00001036 Software\Opera Software/Plugin Path 2
                0012 [I] 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_9_900_170.dll
                0013 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_170_Plugin.exe
                0014 [I] 00000024 C:\Windows\SysWOW64\Macromed\Flash\plugin.vch
                0015 [I] 00000017 C:\Windows\SysWOW64\Macromed\Flash
                0016 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_9_900_170.exe
                0017 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                0018 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                0019 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                0020 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                0021 [W] 00001106
                0022 [W] 00001106
                0023 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                0024 [I] 00000012
                =X====== M/11.9.900.170 2013-12-15+10-30-40.798 ========
                2014-2-5+6-34-20.892 [error] 1226 1062
                =O====== M/12.0.0.44 2014-02-05+06-34-07.180 ========
                0002 [I] 00000011 1
                0004 [I] 00000013 C:\Windows\TEMP\{FEEDD719-2F4E-401C-949F-601BFFB06298}\Flash32_12_0_0_44.ocx
                0005 [I] 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_44_ActiveX.exe
                0006 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_44_ActiveX.exe
                0007 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_44_ActiveX.dll
                0008 [I] 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
                0009 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                0010 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                0011 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                0012 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                0013 [W] 00001106
                0014 [W] 00001106
                0015 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                0016 [I] 00000012
                =X====== M/12.0.0.44 2014-02-05+06-34-22.132 ========
                2014-2-5+7-34-8.540 [error] 1226 1062
                =O====== M/12.0.0.44 2014-02-05+07-34-05.036 ========
                0002 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
                0003 [W] 00001036 Software\Opera Software/Last CommandLine 2
                0004 [W] 00001036 Software\Opera Software/Last CommandLine 2
                0005 [W] 00001036 Software\Opera Software/Plugin Path 2
                0006 [W] 00001036 Software\Opera Software/Plugin Path 2
                0007 [I] 00000014 C:\Windows\TEMP\{B2198E59-806D-4B56-BCD5-58BF43E1E11D}\NPSWF32_12_0_0_44.dll
                0008 [I] 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_44_Plugin.exe
                0009 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_44_Plugin.exe
                0010 [I] 00000024 C:\Windows\SysWOW64\Macromed\Flash\plugin.vch
                0011 [I] 00000017 C:\Windows\SysWOW64\Macromed\Flash
                0012 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_12_0_0_44.exe
                0017 [W] 00001106
                0018 [W] 00001106
                0020 [I] 00000012
                =X====== M/12.0.0.44 2014-02-05+07-34-09.700 ========
                =O====== M/12.0.0.44 2014-02-05+08-00-46.173 ========
                0000 [I] 00000010 "C:\Users\Harry\AppData\Local\Adobe\AIH.c1c0122cb42212923a4536ecd9576bc598161594\install_ flash_player_ax.exe" -install -iv 8
                0002 [F] 00001041
                =X====== M/12.0.0.44 2014-02-05+08-00-47.246 ========
                =O====== M/12.0.0.44 2014-02-05+08-00-54.835 ========
                0002 [F] 00001041
                =X====== M/12.0.0.44 2014-02-05+08-00-55.884 ========
                =O====== M/12.0.0.44 2014-02-05+08-01-01.216 ========
                0002 [F] 00001041
                =X====== M/12.0.0.44 2014-02-05+08-01-02.257 ========
                =O====== M/12.0.0.44 2014-02-05+08-01-03.536 ========
                0002 [F] 00001041
                =X====== M/12.0.0.44 2014-02-05+08-01-04.577 ========
                =O====== M/12.0.0.44 2014-02-05+08-01-05.318 ========
                0002 [F] 00001041
                =X====== M/12.0.0.44 2014-02-05+08-01-06.364 ========
                =O====== M/12.0.0.44 2014-02-05+08-01-07.195 ========
                0002 [F] 00001041
                =X====== M/12.0.0.44 2014-02-05+08-01-08.235 ========
                =O====== M/12.0.0.44 2014-02-05+08-01-08.873 ========
                0002 [I] 00000011 1
                0003 [E] 00001041
                =X====== M/12.0.0.44 2014-02-05+08-01-13.553 ========
                =O====== M/12.0.0.44 2014-02-05+08-01-24.545 ========
                0002 [I] 00000011 1
                0004 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_12_0_0_44.ocx
                0005 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_44_ActiveX.exe
                0006 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_44_ActiveX.dll
                0007 [I] 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
                0008 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                0009 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                0010 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                0011 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                0012 [W] 00001106
                0013 [W] 00001106
                0014 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                0015 [I] 00000012
                =X====== M/12.0.0.44 2014-02-05+08-01-34.379 ========
                2014-2-5+8-34-0.218 [error] 1223 1056
                2014-2-16+2-34-0.216 [error] 1223 1056
                2014-2-22+4-34-15.765 [error] 1226 1062
                =O====== M/12.0.0.70 2014-02-22+04-34-04.430 ========
                0002 [I] 00000011 1
                0004 [I] 00000013 C:\Windows\TEMP\{2CB9C7CD-EDC8-4A5E-9CA8-4B6D28F44994}\Flash32_12_0_0_70.ocx
                0005 [I] 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.exe
                0006 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.exe
                0007 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.dll
                0013 [W] 00001106
                0014 [W] 00001106
                0016 [I] 00000012
                =X====== M/12.0.0.70 2014-02-22+04-34-17.015 ========
                2014-2-22+5-34-14.942 [error] 1226 1062
                =O====== M/12.0.0.70 2014-02-22+05-34-06.129 ========
                0001 [I] 00000011 1
                0003 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
                0005 [W] 00001036 Software\Opera Software/Last CommandLine 2
                0007 [W] 00001036 Software\Opera Software/Plugin Path 2
                0008 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_12_0_0_44.dll 5
                0009 [W] 00001015 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_12_0_0_44.dll 5
                0010 [I] 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_12_0_0_70.dll
                0011 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_Plugin.exe
                0012 [I] 00000024 C:\Windows\SysWOW64\Macromed\Flash\plugin.vch
                0013 [I] 00000017 C:\Windows\SysWOW64\Macromed\Flash
                0014 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_12_0_0_70.exe
                0015 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                0016 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                0017 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                0018 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                0019 [W] 00001106
                0020 [W] 00001106
                0021 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                0022 [I] 00000012
                =X====== M/12.0.0.70 2014-02-22+05-34-16.119 ========
                2014-2-23+7-34-0.213 [error] 1223 1056
                =O====== M/12.0.0.70 2014-03-08+00-45-33.360 ========
                0001 [F] 00001041
                =X====== M/12.0.0.70 2014-03-08+00-45-34.454 ========
                =O====== M/12.0.0.70 2014-03-08+00-45-52.206 ========
                0001 [I] 00000011 1
                0003 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_12_0_0_70.ocx
                0004 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.exe
                0005 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.dll
                0011 [W] 00001106
                0012 [W] 00001106
                0014 [I] 00000012
                =X====== M/12.0.0.70 2014-03-08+00-46-04.866 ========
                =O====== M/12.0.0.70 2014-03-08+17-24-07.116 ========
                0000 [I] 00000010 "C:\Users\Harry\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\C3BFQ915\install_flash_player_ax.exe"
                0001 [I] 00000011 1
                0011 [W] 00001106
                0012 [W] 00001106
                =X====== M/12.0.0.70 2014-03-08+17-24-49.972 ========
                =O====== M/12.0.0.70 2014-03-10+01-25-44.574 ========
                0001 [F] 00001041
                =X====== M/12.0.0.70 2014-03-10+01-25-45.614 ========
                =O====== M/12.0.0.70 2014-03-10+01-25-59.780 ========
                0001 [I] 00000011 1
                0011 [W] 00001106
                0012 [W] 00001106
                0014 [I] 00000012
                =X====== M/12.0.0.70 2014-03-10+01-26-12.301 ========
                =O====== M/12.0.0.70 2014-03-10+22-46-16.200 ========
                0000 [I] 00000010 "C:\Users\Harry\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\VJJUVXD3\uninstall_flash_player.exe" -force
                0001 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                0002 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
                0003 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
                0004 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                0005 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
                0006 [W] 00001021
                0007 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0008 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0009 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0010 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                0011 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
                0012 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
                0013 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                0014 [W] 00001021
                0015 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0017 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0019 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 2
                0020 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0022 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
                0023 [W] 00001036 Software\Opera Software/Last CommandLine 2
                0024 [W] 00001036 Software\Opera Software/Last CommandLine 2
                0025 [W] 00001036 Software\Opera Software/Plugin Path 2
                0026 [W] 00001036 Software\Opera Software/Plugin Path 2
                0027 [I] 00000011 1
                =X====== M/12.0.0.70 2014-03-10+22-46-33.766 ========
                =O====== M/12.0.0.70 2014-03-10+23-00-35.699 ========
                0000 [I] 00000010 "C:\Users\Harry\AppData\Local\Adobe\AIH.c1c0122cb42212923a4536ecd9576bc598161594\install_ flash_player_ax.exe" -install -iv 8 -au 2
                0004 [I] 00000011 1
                0006 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                0007 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_12_0_0_70.ocx
                0008 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.exe
                0009 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.dll
                0013 [I] 00000012
                =X====== M/12.0.0.70 2014-03-10+23-00-44.454 ========
                =O====== M/12.0.0.70 2014-03-11+02-19-03.722 ========
                0001 [F] 00001041
                =X====== M/12.0.0.70 2014-03-11+02-19-04.764 ========
                =O====== M/12.0.0.70 2014-03-11+02-19-15.066 ========
                0001 [I] 00000011 1
                0011 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                0012 [I] 00000012
                =X====== M/12.0.0.70 2014-03-11+02-19-26.438 ========
                =O====== M/12.0.0.70 2014-03-11+02-22-24.727 ========
                0001 [F] 00001041
                =X====== M/12.0.0.70 2014-03-11+02-22-25.757 ========
                =O====== M/12.0.0.70 2014-03-11+02-22-33.824 ========
                0001 [I] 00000011 1
                0012 [I] 00000012
                =X====== M/12.0.0.70 2014-03-11+02-22-42.717 ========
                =O====== M/12.0.0.70 2014-03-11+02-36-33.018 ========
                0000 [I] 00000010 "C:\Users\Harry\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\TEHS9RE5\install_flash_player_ax.exe"
                0001 [I] 00000011 1
                =X====== M/12.0.0.70 2014-03-11+02-37-16.317 ========
