6 Replies Latest reply on Feb 28, 2014 10:50 AM by mkeatley17
    Scripting New Crop Tool
    mkeatley17 Level 1
      I'm having a difficult time scripting the new crop tool.  Despite specifying the initial 4 corners, it quickly expands to fill the entire document before anyone can use it.  Any suggestiong on how to fix this??
      Here's what I want:
      Here's what I get:
      Hee's my code:
      var idCrop = charIDToTypeID( "Crop" );
          var desc142 = new ActionDescriptor();
          var idT = charIDToTypeID( "T   " );
              var desc143 = new ActionDescriptor();
              var idTop = charIDToTypeID( "Top " );
              var idPxl = charIDToTypeID( "#Pxl" );
              desc143.putUnitDouble( idTop, idPxl, 100 );
              var idLeft = charIDToTypeID( "Left" );
              desc143.putUnitDouble( idLeft, idPxl, 100 );
              var idBtom = charIDToTypeID( "Btom" );
              desc143.putUnitDouble( idBtom, idPxl, 200 );
              var idRght = charIDToTypeID( "Rght" );
              desc143.putUnitDouble( idRght, idPxl, 200 );
          var idRctn = charIDToTypeID( "Rctn" );
          desc142.putObject( idT, idRctn, desc143 );
          var idAngl = charIDToTypeID( "Angl" );
          var idAng = charIDToTypeID( "#Ang" );
          desc142.putUnitDouble( idAngl, idAng, 0.000000 );
          var idDlt = charIDToTypeID( "Dlt " );
          desc142.putBoolean( idDlt, true );
          var idcropAspectRatioModeKey = stringIDToTypeID( "cropAspectRatioModeKey" );
          var idcropAspectRatioModeClass = stringIDToTypeID( "cropAspectRatioModeClass" );
          var idunconstrained = stringIDToTypeID( "unconstrained" );
          desc142.putEnumerated( idcropAspectRatioModeKey, idcropAspectRatioModeClass, idunconstrained );
      executeAction( idCrop, desc142, DialogModes.NO );
        • 1. Re: Scripting New Crop Tool
          Chuck Uebele Adobe Community Professional & MVP
          I think you recorded the crop with the wrong type of crop.  It looks like you used a ratio crop rather than a specific width, height, res crop.  Here's what I got using scriptListener.  Notice the difference in the last few lines.
          var docRef = activeDocument
              var desc8 = new ActionDescriptor();
                  var desc9 = new ActionDescriptor();
                  desc9.putUnitDouble( idTop, idPxl, 108.000000 );
                  desc9.putUnitDouble( idLeft, idPxl, 186.000000 );
                  desc9.putUnitDouble( idBtom, idPxl, 374.000000 );
                  desc9.putUnitDouble( idRght, idPxl, 633.000000 );
              desc8.putObject( idT, idRctn, desc9 );
              desc8.putUnitDouble( idAngl, idAng, 0.000000 );
              desc8.putBoolean( idDlt, true );
              var idtargetSize = stringIDToTypeID( "targetSize" );
              desc8.putEnumerated( idcropAspectRatioModeKey, idcropAspectRatioModeClass, idtargetSize );
          executeAction( idCrop, desc8, DialogModes.ALL);
          app.displayDialogs = DialogModes.NO;
          • 2. Re: Scripting New Crop Tool
            mkeatley17 Level 1
            Thank you.  However I'm getting an error when I run that:
            I'm not seeing which setting you are saying to choose:
            • 3. Re: Scripting New Crop Tool
              Looks like you're using CS6, and I was using CC.  It works with the setting shown below, but CS6 doesn't have that feature.  Adobe did a lot of improvements with the crop tool between CS6 and CC, this must have been one of them.
              • 4. Re: Scripting New Crop Tool
                mkeatley17 Level 1
                ok thanks.  I'm sorry I should have clairifed CS6.  I thought "new crop tool" made sense to everyone!
                • 5. Re: Scripting New Crop Tool
                  Why are you using Scriptlistener Action Manager code and not Adobe DOM. crop(bounds) is more readable
                  app.activeDocument.crop(bounds[, angle][, width][, height])
                  array of 4 UnitValue
                  number
                  UnitValue
                  UnitValue
                  Crops the document. The bounds parameter is an array of four coordinates for the region remaining after cropping,[left, top, right, bottom].
                  • 6. Re: Scripting New Crop Tool
                    mkeatley17 Level 1
                    I was using SL because at that point in the program the user needs to interact with the crop and adjust it before hitting enter.  I just wanted the crop box to begin at an exact location to give a sense of proportion to the user.
                    Thanks for the help though!
