8 Replies Latest reply on Feb 27, 2014 11:47 PM by StyleM
    How to run a script op Indesign startup?
    StyleM
      I have a script that runs fine when manually running it in inDesign CC.
      Now i need that script to run automatically when a file is opend in InDesign.
      I put the script in "stratup scripts" folder. But get the error that there is no active document. The script runs before the document is opened.
      on: http://forums.adobe.com/message/4005956 sommthing is mentioned but i just can't get it to run!
      Do i need to install the APID toolkit (only has a plugin for CS4 and lower) or APID toolassistent? And when i do? what then?
      I'm not an IT guy.
      Can anyone help?
      Tnx
        • 1. Re: How to run a script op Indesign startup?
          Mi_D Level 3
          HI StyleM
          Add below line
          main();
          function main(){
              var myEventListener = app.eventListeners.add("afterOpen", excuteScript);
          and ur scipt call or write under excuteScript() function ... eg
          function excuteScript(){
          your code.............................
          Mi_D
          • 2. Re: How to run a script op Indesign startup?
            Mi_D Level 3
            add
            #targetengine "session"
            in first line
            Mi_D
            • 3. Re: How to run a script op Indesign startup?
              StyleM Level 1
              Hi Mi_D,
              Like i mentioned i'm not a IT/programmer.
              This is mijn script now:
              var document = app.activeDocument
              var items = document.allPageItems;
              var textFrame = null;
              for(index = 0; index < items.length; index++)
                  if(items[index].name == "fitText")
                      textFrame= items[index];
              if(textFrame != null)
                  var minimumHorizontalScale = 50;
                  var horizontalScale = textFrame.parentStory.horizontalScale;
                  while(textFrame.overflows && horizontalScale > minimumHorizontalScale)
                      textFrame.parentStory.horizontalScale = horizontalScale--;
              What do i have to do to make it work?
              tnx
              • 4. Re: How to run a script op Indesign startup?
                StyleM Level 1
                So the new script should look something like this???:
                main();
                function main(){
                function excuteScript(fitText){
                But what do you meen by:
                add
                in first line
                tnx
                • 5. Re: How to run a script op Indesign startup?
                  Mi_D Level 3
                  main();
                  function main(){
                  • 6. Re: How to run a script op Indesign startup?
                    StyleM Level 1
                    I now get a warning massage but when ignoring it, it does run the script.
                    Is this normal?
                    The warning massage is: That there are no opend documents.
                    I have an option to never ask this any more. And when i do that it run normally.
                    I don't know if this is normal and could some problems accure in the near future?
                    tnx
                    • 7. Re: How to run a script op Indesign startup?
                      Mi_D Level 3
                      just click in check box than ok and open ur application again
                      Mi_D
                      • 8. Re: How to run a script op Indesign startup?
                        StyleM Level 1
                        Ok, it works, thank you!
