2 Replies Latest reply on Feb 27, 2014 4:54 AM by Awaddell9950
    Form White Space
    Awaddell9950
      Hi there,
      I've got a little problem with my form. When I added it onto my page, there appeared this unmoveable mass of white... I can't find the problem in the code and I was hoping that someone could help me solve it.
      Here is the screenshot of the problem:
      And here is the code:
      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
      <html xmlns="http://www.w3.org/1999/xhtml"><!-- InstanceBegin template="/Templates/main.dwt" codeOutsideHTMLIsLocked="false" -->
      <head>
      <meta name="keywords" content="mountain snow resort holiday skiing scotSki explore thrilling"/>
      <meta name="description" content="skiing website"/>
      <meta name="author" content="Andrew Waddell"/>
      <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
      <!-- InstanceBeginEditable name="doctitle" -->
      <title>Contact Us</title>
      <!-- InstanceEndEditable -->
      <link href="oneColLiqCtrHdr.css" rel="stylesheet" type="text/css" />
      <style type="text/css">
      a:hover {
          color: #C63;
      a:link {
          color: 0033ff;
      body {
          background-color: #ccffff;
          color:#3366ff
      body,td,th {
          color: #3366ff;
      form {
          background-color:#FFF;
        text {
            text: Arial, Helvetica, sans-serif;
      </style>
      <!-- InstanceBeginEditable name="head" -->
      function MM_validateForm() { //v4.0
        if (document.getElementById){
          var i,p,q,nm,test,num,min,max,errors='',args=MM_validateForm.arguments;
          for (i=0; i<(args.length-2); i+=3) { test=args[i+2]; val=document.getElementById(args[i]);
            if (val) { nm=val.name; if ((val=val.value)!="") {
              if (test.indexOf('isEmail')!=-1) { p=val.indexOf('@');
                if (p<1 || p==(val.length-1)) errors+='- '+nm+' must contain an e-mail address.\n';
              } else if (test!='R') { num = parseFloat(val);
                if (isNaN(val)) errors+='- '+nm+' must contain a number.\n';
                if (test.indexOf('inRange') != -1) { p=test.indexOf(':');
                  min=test.substring(8,p); max=test.substring(p+1);
                  if (num<min || max<num) errors+='- '+nm+' must contain a number between '+min+' and '+max+'.\n';
            } } } else if (test.charAt(0) == 'R') errors += '- '+nm+' is required.\n'; }
          } if (errors) alert('The following error(s) occurred:\n'+errors);
          document.MM_returnValue = (errors == '');
      </script>
      </head>
      <body class="oneColLiqCtrHdr">
      <div id="container">
        <div id="header"><!-- end #header -->
        <div id="nav">
          <div align="center">
            <p><a href="index.html"><img src="Images/Banner Image/bannerimage.png" width="500" height="100" alt="banner_logo_snow_mountain" /></a></p>
            <a href="index.html">Homepage</a> | <!-- InstanceBeginEditable name="nav_bar" --><a href="packages.html">Packages</a><!-- InstanceEndEditable --> | <a href="ski_centers.html">Ski Centers</a> | <a href="about_us.html">About Us</a> | <a href="contact_us.html">Contact Us</a>
          </div>
        </div>
        </div>
        <!-- InstanceBeginEditable name="main_content" -->
        <div id="mainContent">
          <h1> <u>Contact Us</u></h1>
          <div id="main">
            <img style="right;" alt="contact_agent" src="Images/Contact Us/contact_agent.jpg" width="475" height="336" />
            <p></p><p></p>
          <p></p>
        <form action="" method="get" >
          <table width="266" border="1">
            <tr>
              <td width="84">Forename</td>
              <td width="166"><label>
                <input name="forename" type="text" id="forename" onblur="MM_validateForm('forename','','R');return document.MM_returnValue" />
              </label></td>
            </tr>
            <tr>
              <td>Surname</td>
              <td><label>
                <input name="surname" type="text" id="surname" onblur="MM_validateForm('surname','','R');return document.MM_returnValue" />
              </label></td>
            </tr>
            <tr>
              <td>Address</td>
              <td><label>
                <input name="address" type="text" id="address" onblur="MM_validateForm('address','','R');return document.MM_returnValue" />
              </label></td>
            </tr>
            <tr>
              <td>Postcode</td>
              <td><label>
                <input name="postcode" type="text" id="postcode" onblur="MM_validateForm('postcode','','R');return document.MM_returnValue" />
              </label></td>
            </tr>
            <tr>
              <td><p>Tel. No</p></td>
              <td><label>
                <input name="tel no" type="text" id="tel_no" onblur="MM_validateForm('tel_no','','R');return document.MM_returnValue" />
              </label></td>
            </tr>
            <tr>
              <td>Email</td>
              <td><label>
                <input name="email" type="text" id="email" onblur="MM_validateForm('email','','R');return document.MM_returnValue" />
              </label></td>
            </tr>
          </table>
            <label>
              <input type="submit" name="submit" id="submit" value="Submit" />
            </label>
            <label>
              <input type="reset" name="clear" id="clear" value="Reset" />
            </label>
        </form>
          <center>Telephone: 01236 756114|
          <a href="mailto:awaddell9950@coatbridge.ac.uk">Email Us</a>|
          Postcode: ML6 0HY|</center>
        <p> </p>
      </div>
          <!-- end #mainContent -->
        </div>
        <div id="footer">
          <p>Andrew Waddell &copy; 2014</p>
        <!-- end #footer --></div>
      <!-- end #container --></div>
      </body>
      <!-- InstanceEnd --></html>
