4 Replies Latest reply on Feb 27, 2014 11:29 AM by Magus069
    Email Submit button trying to save
    talon16 Level 1
      When I use the email submit button it is trying to save the form instead of attaching it to an email.  Started doing this since changed OS to WIndows 7 from XP
        • 1. Re: Email Submit button trying to save
          Magus069 Level 4
          Are you using submit button or you are using the mailDoc method to submit the form as email?
          • 2. Re: Email Submit button trying to save
            Magus069 Level 4
            instead of using the submit button, use the normal button to send it via email
            Insert this code to send it via email
            var oDoc = event.target;
                                          oDoc.mailDoc({
        bUI: false,
        cTo: "DGASAT.ACQBTHS@tpsgc-pwgsc.gc.ca",
        cCC: "",
        cSubject: "THS Extension Request - " + this.resolveNode("Main1.frmPart1.frmInformation.frmCallUpInfo.txtCallUpRef").rawValue,
        cMsg: "Before submiting the email, include attachments 1, 2 and 3:\n"
            Also if you want to validate your form before submitting, you can check before submitting it by email with this
            if (form1.execValidate()){
                 //mailDoc
            • 3. Re: Email Submit button trying to save
              talon16 Level 1
              Hi Robert,
              Thanks for your response,
              I am using the email submit button, it tries to save the form on my computer which has windows7.    I tried it on another computer with windows 7 and it attached the form to an email in outlook.  It works fine on laptops with XP, thinking it is a setting on my PCM.
              Chris
              Sent from my iPad
              • 4. Re: Email Submit button trying to save
                Magus069 Level 4
                if you try the mailDoc method shown above, it should fix the problem
