1 Reply Latest reply on Jun 16, 2006 2:58 PM by milostea
    XMLSocket delays on send()
    milostea Level 1
      We are testing the XMLSocket class with our in-house server application. Server receives XML packets (null terminated) and returns data. Application works fine with our front-end product. However, we have run into a problem when sending packets via a flash application. The server receives the packets until the Flash app closes the socket. The data is sent and correctly formatted but it's sent to the server because the connection is actually being closed. I believe this is some sort of configuration issue with the XMLSocket class but our lack of internal knowledge about it leaves us scratching our heads.
      At this point we haven't been able to diagnose the problem. Can someone shed some light on the XMLSocket's peculiar behavior when sending packets? Thank you.
