0 Replies Latest reply on Jun 15, 2006 7:20 PM by busitech
    bug in JavaAdapter
    busitech
      When the JavaAdapter calls an updateItem Assembler method, an Arrays.ArrayList passed in as the changes parameter. This is an immutable object list. This means I can not change more object properties on the server side, add the property names to the list, and get the client in sync.
      I can do this effectively if I use a sync method and the ChangeObject system, which maintains a String[] for the list of changed properties. Please bring the JavaAdapter up to date with this functionality. It is very important to remember that the server side can and will make as many meaningful changes to the objects as the client. Thank you!
