3 Replies Latest reply on Feb 28, 2014 3:53 PM by heathrowe
    automatic hyperlinks inside a text block
    vimster303909 Level 1
      I'm doing page with multiple pop-ups that each contain an information paragraph with adress, phone numbers and email adresses...
      Is it possible to have all email adresses automatically converted to hyperlinks??
      thanks, j
        • 1. Re: automatic hyperlinks inside a text block
          hyadav Adobe Employee
          Check the thread http://forums.adobe.com/thread/1086907
          -Harshit yadav
          • 2. Re: automatic hyperlinks inside a text block
            hemanthR Adobe Employee
            There is no direct way to turn all the text elemetents to hyper links .
            You could hand code to surround all mail text elements with anchor tags
            Add click events seperately to all the email text elements
            You could add your email addresses in a div and give all divs a common class name say 'email_button'
            Than in composition ready event you  could bind all the tags with the class name you gave with a click event listener.
            $('.email_button').live('click', function() {
            //code to mail
            • 3. Re: automatic hyperlinks inside a text block
              heathrowe Most Valuable Participant
              Another option is to use a reg expression to detect static email references and filter them out (ie find a match) among target selector; then replace it with a live email vesion.
              http://www.joe-stevens.com/2010/02/18/convert-all-static-text-email-addresses-to-mailto-li nks-using-jquery/
              So as per example in the above link reference, your solution would be something like this (place in compositionReady event handler
              //////// copy to compositionReady /////////
              var regEx = /(\w+([-+.']\w+)*@\w+([-.]\w+)*\.\w+([-.]\w+)*)/;
                  $("div").filter(function() {
                      return $(this).html().match(regEx);
                  }).each(function() {
                      $(this).html($(this).html().replace(regEx, "<a href=\"$1mailto:$1\">$1</a>"));
              //////////end copy//////////////////
              Note - the only change I made to the orginal authors script is the element selector reference. The default tag selector in Edge Animate is div so that is what I used.
              If you have other tag slectors to filter from you will need to chain it into the matched selects.
