This content has been marked as final.
Show 3 replies
1. Re: Linking to local files - strange behavior
Captiv8r Feb 28, 2014 6:00 AM (in response to R_Sem)Hi Robert
This is one purpose or reason you would use Baggage Files.
Add the file you are linking to as a Baggage File and link to the baggage file.
This may also have issues inside a CHM output though. But before we delve into the possible issues, give it a try and see if it works for you. It may work straight away. If so, that's great. But if you start seeing issues, post back for more help.
Cheers... Rick
2. Re: Linking to local files - strange behavior
R_Sem Feb 28, 2014 6:09 AM (in response to Captiv8r)Hi Rick, regrettably in this case it really is required to link to a file outside of the CHM. Perhaps it is possible to place the file on a web location, at least that should work reliably as long as the user has web access.
Robert
3. Re: Linking to local files - strange behavior
Captiv8r Feb 28, 2014 9:20 AM (in response to R_Sem)Okay, so in this case you would want to use a HTML Help Shortcut control to open the file.
Cheers... Rick
