11 Replies Latest reply on Mar 31, 2014 12:43 AM by matthieu.helder
    InDesign CS5.5 on OSX 10.9.1 suddenly crashes at startup
    matthieu.helder
      For some reason my copy of InDesign CS5.5 suddenly crashes at startup, in libxml2.2. This is new; it used to work fine. I don't know of anything that has changed in my system. It *may* be an update of the OS.
      I have tried deleting user preferences, application settings, (both manually and by using command-ctrl-option-shift at startup). Also tried starting InDesign from a user that never used it, with the same result.
      The same holds for Illustrator CS5.5: it crashes at exact the same place.
      Please find a part of the crash log below.
      Anyone knows how to solve this? Your help will greatly be appreciated!
      Best regards,
      Matthieu
      InDesign crash log:
      Process:         Adobe InDesign CS5.5 [8240]
      Path:            /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/MacOS/Adobe InDesign CS5.5
      Identifier:      com.adobe.InDesign
      Version:         7.5.3.333 (7530)
      Code Type:       X86 (Native)
      Parent Process:  launchd [166]
      Responsible:     Adobe InDesign CS5.5 [8240]
      User ID:         504
      Date/Time:       2014-02-28 14:26:52.856 +0100
      OS Version:      Mac OS X 10.9.1 (13B42)
      Report Version:  11
      Anonymous UUID:  410B6B8A-2546-CAAC-1C14-F31433FBA547
      Sleep/Wake UUID: 54CE87D9-A051-42D7-BCEB-087AE1EAD289
      Crashed Thread:  0  Dispatch queue: com.apple.main-thread
      Exception Type:  EXC_BAD_ACCESS (SIGBUS)
      Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
      VM Regions Near 0:
      --> __PAGEZERO             0000000000000000-0000000000001000 [    4K] ---/--- SM=NUL  /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/MacOS/Adobe InDesign CS5.5
          __TEXT                 0000000000001000-0000000000005000 [   16K] r-x/rwx SM=COW  /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/MacOS/Adobe InDesign CS5.5
      Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
      0   libxml2.2.dylib                         0x99fef8ad xmlInitParserCtxt + 841
      1   libxml2.2.dylib                         0x99fefd96 xmlNewParserCtxt + 59
      2   libxml2.2.dylib                         0x99feb2c8 xmlCreateMemoryParserCtxt + 35
      3   libxml2.2.dylib                         0x99febeb4 xmlCreateDocParserCtxt + 34
      4   com.adobe.dvaadameve.framework          0x20a32e1c get_widget_set + 720796
      5   com.adobe.dvacore.framework             0x1f48796a dvacore::proplist::utils::ReadPropList(std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const&, dvacore::proplist::PropList&) + 106
      6   com.adobe.dvaui.framework               0x20ee0ab4 dvaui::utility::OS_ResourceManager::GetBinary(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::vector<char, std::allocator<char> >*) const + 1204
      7   com.adobe.dvaui.framework               0x20ee183f dvaui::utility::OS_ResourceManager::CursorInfoFromID(int, dvaui::utility::OS_ResourceManager::BigCursorInfo&) const + 719
      8   com.adobe.dvaui.framework               0x20ee2b17 dvaui::utility::OS_ResourceManager::MakeCursorFromPNG(int) const + 71
      9   com.adobe.dvaui.framework               0x20ec44b7 dvaui::ui::OS_NodeManager::OS_NodeManager() + 71
      10  com.adobe.dvaadameve.framework          0x2098149c dvaadameve::evaluate_serialization(adobe::version_1::string_t const&) + 14812
      11  com.adobe.dvaadameve.framework          0x209899cc get_widget_set + 27468
      12  com.adobe.dvaadameve.framework          0x20982efa get_widget_set + 122
      13  AdobeOwlCanvas                          0x02cd07e0 adobe::owl_canvas::version_0::session_t::~session_t() + 640
      14  AdobeOwlCanvas                          0x02cd0c73 adobe::owl_canvas::version_0::session_t::~session_t() + 1811
      15  AdobeOwlCanvas                          0x02cd1dc2 adobe::owl_canvas::version_0::session_t::~session_t() + 6242
      16  AdobeOwlCanvas                          0x02cd1fd1 adobe::owl_canvas::version_0::session_t::~session_t() + 6769
      17  com.adobe.InDesign.Application UI          0x1350cd6a GetPlugIn + 740170
      18  com.adobe.InDesign.Application UI          0x134e06ae GetPlugIn + 558222
      19  com.adobe.InDesign.Application UI          0x134427fb 0x13409000 + 235515
      20  com.adobe.InDesign.Application UI          0x134479ce 0x13409000 + 256462
      21  com.adobe.InDesign.Application UI          0x13464cf0 GetPlugIn + 51920
      22  PublicLib.dylib                         0x0128dc4f CInitializer::RegisterResources(IDResource, void*) + 95
      23  PublicLib.dylib                         0x01293c7c SchemaBasedWriteIterator::~SchemaBasedWriteIterator() + 5372
      24  PublicLib.dylib                         0x015519ee EnumerateResourcesByTypeFromPluginData(PlugInData const*, unsigned long const&, boost::function<bool (IDResource, void*, RsrcSpec)>, void*) + 1502
      25  PublicLib.dylib                         0x0155177c EnumerateResourcesByTypeFromPluginData(PlugInData const*, unsigned long const&, boost::function<bool (IDResource, void*, RsrcSpec)>, void*) + 876
      26  PublicLib.dylib                         0x01293c7c SchemaBasedWriteIterator::~SchemaBasedWriteIterator() + 5372
      27  PublicLib.dylib                         0x015519ee EnumerateResourcesByTypeFromPluginData(PlugInData const*, unsigned long const&, boost::function<bool (IDResource, void*, RsrcSpec)>, void*) + 1502
      28  PublicLib.dylib                         0x01550c7b IDResourceShell::GetLocalized(RsrcSpec const&) + 683
      29  PublicLib.dylib                         0x015510b7 IDResourceShell::EnumerateResourcesByType(IDType<PluginID_tag> const&, unsigned long const&, boost::function<bool (IDResource, void*, RsrcSpec)>, void*) + 119
      30  PublicLib.dylib                         0x01551258 IDResourceShell::EnumerateLocalizedResourcesByType(IDType<PluginID_tag> const&, unsigned long const&, boost::function<bool (IDResource, void*, RsrcSpec)>, void*, PMLocaleId const&) + 296
      31  PublicLib.dylib                         0x0128e89a CInitializer::Register(IDType<PluginID_tag>, PMLocaleId const&) + 234
      32  com.adobe.InDesign.AppFramework          0x13258fa3 GetPlugIn + 304259
      33  com.adobe.InDesign.AppFramework          0x13259059 GetPlugIn + 304441
      34  com.adobe.InDesign.AppFramework          0x13212435 GetPlugIn + 14613
      35  com.adobe.InDesign                      0x000028ab main + 187
      36  com.adobe.InDesign                      0x000027c6 start + 54
      Illustrator crash log:
      Process:         Adobe Illustrator [8256]
      Path:            /Applications/Adobe Illustrator CS5.1/Adobe Illustrator.app/Contents/MacOS/Adobe Illustrator
      Identifier:      com.adobe.illustrator
      Version:         39 (15.1.0)
      Responsible:     Adobe Illustrator [8256]
      User ID:         504
      Date/Time:       2014-02-28 14:30:10.477 +0100
      Report Version:  11
      VM Regions Near 0:
      --> __PAGEZERO             0000000000000000-0000000000001000 [    4K] ---/--- SM=NUL  /Applications/Adobe Illustrator CS5.1/Adobe Illustrator.app/Contents/MacOS/Adobe Illustrator
          __TEXT                 0000000000001000-00000000010de000 [ 16.9M] r-x/rwx SM=COW  /Applications/Adobe Illustrator CS5.1/Adobe Illustrator.app/Contents/MacOS/Adobe Illustrator
      4   com.adobe.dvaadameve.framework          0x066505dc dvacore::xml::LibXML2ParseHandler::ParseBuffer(std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const&) + 140
      5   com.adobe.dvacore.framework             0x05b7f34a dvacore::proplist::utils::ReadPropList(std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const&, dvacore::proplist::PropList&) + 106
      6   com.adobe.dvaui.framework               0x0606f844 dvaui::utility::LoadCursorHotSpot(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvaui::utility::ResourceManager const&) + 404
      7   com.adobe.dvaui.framework               0x060705cf dvaui::utility::OS_ResourceManager::CursorInfoFromID(int, dvaui::utility::OS_ResourceManager::BigCursorInfo&) const + 719
      8   com.adobe.dvaui.framework               0x060718a7 dvaui::utility::OS_ResourceManager::MakeCursorFromPNG(int) const + 71
      9   com.adobe.dvaui.framework               0x06052ca7 dvaui::ui::OS_NodeManager::OS_NodeManager() + 71
      10  com.adobe.dvaadameve.framework          0x0659d16c dvaadameve::InitDrover() + 252
      11  com.adobe.dvacore.framework             0x05b329ac void boost::call_once<void (*)()>(boost::once_flag&, void (*)()) + 252
      12  com.adobe.dvaadameve.framework          0x0659f52a dvaadameve::DroverWidgetSet::Initialize(adobe::version_1::closed_hash_map<adobe::version_ 1::name_t, adobe::version_1::any_regular_t, boost::hash<adobe::version_1::name_t>, std::equal_to<adobe::version_1::name_t>, adobe::version_1::capture_allocator<adobe::pair<adobe::version_1::name_t, adobe::version_1::any_regular_t> > > const&) + 42
      13  AdobeOwlCanvas                          0x047a07e0 adobe::owl_canvas::version_0::session_t::~session_t() + 640
      14  AdobeOwlCanvas                          0x047a0c73 adobe::owl_canvas::version_0::session_t::~session_t() + 1811
      15  AdobeOwlCanvas                          0x047a1dc2 adobe::owl_canvas::version_0::session_t::~session_t() + 6242
      16  AdobeOwlCanvas                          0x047a1fd1 adobe::owl_canvas::version_0::session_t::~session_t() + 6769
      17  com.adobe.illustrator.plugins.AppBarControlsPlugin          0x18e34d3c PluginMain + 17508
      18  com.adobe.illustrator.plugins.AppBarControlsPlugin          0x18e34e11 PluginMain + 17721
      19  com.adobe.illustrator.plugins.AppBarControlsPlugin          0x18e3401a PluginMain + 14146
      20  com.adobe.illustrator.plugins.AppBarControlsPlugin          0x18e30e43 PluginMain + 1387
      21  com.adobe.illustrator.plugins.AppBarControlsPlugin          0x18e2ee66 0x18e2d000 + 7782
      22  com.adobe.illustrator.plugins.AppBarControlsPlugin          0x18e30a85 PluginMain + 429
      23  com.adobe.illustrator                   0x006e856e AWS_CUI_RevertAlert(OpaqueWindowPtr*, adobe::aws::gen::String<unsigned short>&, adobe::aws::gen::String<unsigned short>&) + 3769694
      24  com.adobe.illustrator                   0x006e46d3 AWS_CUI_RevertAlert(OpaqueWindowPtr*, adobe::aws::gen::String<unsigned short>&, adobe::aws::gen::String<unsigned short>&) + 3753667
      25  com.adobe.illustrator                   0x006ec396 AWS_CUI_RevertAlert(OpaqueWindowPtr*, adobe::aws::gen::String<unsigned short>&, adobe::aws::gen::String<unsigned short>&) + 3785606
      26  com.adobe.illustrator                   0x001b6d35 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1678649
      27  com.adobe.illustrator                   0x0056bf01 AWS_CUI_RevertAlert(OpaqueWindowPtr*, adobe::aws::gen::String<unsigned short>&, adobe::aws::gen::String<unsigned short>&) + 2211569
      28  com.adobe.coretech.adm                  0x126cabf8 0x126be000 + 52216
      29  com.adobe.illustrator                   0x001141bc AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1012160
      30  com.adobe.illustrator                   0x00114fec AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1015792
      31  com.adobe.illustrator                   0x001c06e6 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1717994
      32  com.adobe.illustrator                   0x00050648 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 210508
      33  com.adobe.illustrator                   0x000512d6 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 213722
      34  com.adobe.illustrator                   0x00050a4e AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 211538
      35  com.adobe.illustrator                   0x001be56b AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1709423
      36  com.adobe.illustrator                   0x001c0093 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1716375
      37  com.adobe.illustrator                   0x00113c1a AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1010718
      38  com.adobe.illustrator                   0x00050648 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 210508
      39  com.adobe.illustrator                   0x000512d6 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 213722
      40  com.adobe.illustrator                   0x00050a4e AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 211538
      41  com.adobe.illustrator                   0x00112ee1 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1007333
      42  com.adobe.illustrator                   0x000d412a AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 749870
      43  com.adobe.illustrator                   0x00003316 0x1000 + 8982
        • 1. Re: InDesign CS5.5 on OSX 10.9.1 suddenly crashes at startup
          Larry G. Schneider Adobe Community Professional & MVP
          Try repairing permissions on the HD
          • 2. Re: InDesign CS5.5 on OSX 10.9.1 suddenly crashes at startup
            potassiumdesign
            I'm having the same problem after upgrading to maverick wtih Indesign only. I've tried all the steps you mentioned as well. have you found a solution yet?
            • 3. Re: InDesign CS5.5 on OSX 10.9.1 suddenly crashes at startup
              matthieu.helder Level 1
              Thank you for your advice!
              Of which files should I repair the permissions?
              $ ls -l ~/Library/Application Support/Adobe
              gives
              drwxr-xr-x  3 username  staff  102 Feb 28 13:58 Adobe Illustrator CS5.1
              drwxr-xr-x  4 username  staff  136 Dec 20 11:59 Adobe PDF
              drwxr-xr-x  3 username  staff  102 Jun 17  2013 Adobe Photoshop CS5.1
              which seems to be OK, because Photoshop is working alright. The files inside these directories have the same permissions.
              The /Library/Application\ Support directories also seem to be fine:
              $ ls -l /Library/Application\ Support/Adobe/Adobe\ Creative\ Suite\ 5.5\ Design\ Premium/
              total 0
              drwxrwxr-x   7 root  admin   238 Jun 12  2013 AMT
              drwxrwxr-x  30 root  admin  1020 Jun 12  2013 legal
              $ ls -l /Library/Application\ Support/Adobe/Adobe\ Creative\ Suite\ 5.5\ Design\ Premium/AMT/
              total 1528
              -r--r--r--  1 root  admin  225863 Jun 12  2013 SLConfig.xml
              -r--r--r--  1 root  admin   64234 Jun 12  2013 application.sif
              -r--r--r--  1 root  admin     390 Jun 12  2013 application.xml
              -r--r--r--  1 root  admin  162624 Jun 12  2013 aul.xml
              -r--r--r--  1 root  admin  318032 Jun 12  2013 designpremium_install_pkg.icns
              • 4. Re: InDesign CS5.5 on OSX 10.9.1 suddenly crashes at startup
                I haven't found a solution yet. If I will, I certainly will post it here.
                • 5. Re: InDesign CS5.5 on OSX 10.9.1 suddenly crashes at startup
                  I did a trace to find out on which file libxml chokes:
                  # opensnoop
                    UID    PID COMM          FD PATH
                    504   9975 Adobe InDesign   43 /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/MacOS/Required/Spline UI.InDesignPlugin/Resources/idrc_PLST/1901.idrc
                    504   9975 Adobe InDesign   43 /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/MacOS/Required/Spline UI.InDesignPlugin/Resources/idrc_LOCR/1800.idrc
                    504   9975 Adobe InDesign   43 /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/MacOS/Required/Spline UI.InDesignPlugin/Resources/idrc_VIEW/1801.idrc
                    504   9975 Adobe InDesign   43 /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/Frameworks/dvaadameve.framework
                    504   9975 Adobe InDesign   43 /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/Frameworks/dvaadameve.framework/Resources
                    504   9975 Adobe InDesign   43 /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/Frameworks/dvaadameve.framework/Resources/Info.plist
                    504   9975 Adobe InDesign   43 /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/Frameworks/dvaadameve.framework/dvaadameve
                    504   9975 Adobe InDesign   43 /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/MacOS/../Frameworks/dvacore.framework/Versions/A/dvacore
                    504   9975 Adobe InDesign   43 /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/MacOS/../Frameworks/dvaui.framework/Versions/A/dvaui
                    504   9975 Adobe InDesign   43 /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/Frameworks/dvaui.framework
                    504   9975 Adobe InDesign   43 /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/Frameworks/dvaui.framework/Resources
                    504   9975 Adobe InDesign   43 /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/Frameworks/dvaui.framework/Resources/Info.plist
                    504   9975 Adobe InDesign   -1 /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/Frameworks/dvaui.framework/Resources/English.lproj
                    504   9975 Adobe InDesign   -1 /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/Frameworks/dvaui.framework/Resources/Base.lproj
                    504   9975 Adobe InDesign   -1 /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/Frameworks/dvaui.framework//English.lproj
                    504   9975 Adobe InDesign   -1 /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/Frameworks/dvaui.framework//Base.lproj
                    504   9975 Adobe InDesign   43 /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/Frameworks/dvaui.framework/Resources/xml
                    504   9975 Adobe InDesign   -1 /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/Frameworks/dvaui.framework/Resources/English.lproj/xml
                    504   9975 Adobe InDesign   -1 /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/Frameworks/dvaui.framework/Resources/Base.lproj/xml
                    504   9975 Adobe InDesign   43 /.vol/16777220/14043973/CursorDataID-10.xml
                    504   9966 ReportCrash    5 /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app
                  It seems to be on the file /.vol/16777220/14043973/CursorDataID-10.xml
                  but this file looks OK to me. It contents are:
                  <?xml version='1.0'?>
                  <prop.map version='1'>
                  <prop.list>
                  <prop.pair>
                  <key>DVA_CursorData</key>
                  <string>1.0</string>
                  </prop.pair>
                  <prop.pair>
                  <key>kHotSpot</key>
                  <array>
                  <array.type><int type='signed' size='32'/></array.type>
                  <int type='signed' size='32'>7</int>
                  <int type='signed' size='32'>8</int>
                  </array>
                  </prop.pair>
                  </prop.list>
                  </prop.map>
                  Anyone any idea?
                  • 6. Re: InDesign CS5.5 on OSX 10.9.1 suddenly crashes at startup
                    ... and Illustrator crashes on the same file (in another directory):
                      504  10087 Adobe Illustrat 181 /Applications/Adobe Illustrator CS5.1/Adobe Illustrator.app/Contents/Frameworks/dvaui.framework/Resources/xml
                      504  10087 Adobe Illustrat  -1 /Applications/Adobe Illustrator CS5.1/Adobe Illustrator.app/Contents/Frameworks/dvaui.framework/Resources/English.lproj/xml
                      504  10087 Adobe Illustrat  -1 /Applications/Adobe Illustrator CS5.1/Adobe Illustrator.app/Contents/Frameworks/dvaui.framework/Resources/Base.lproj/xml
                      504  10087 Adobe Illustrat 181 /.vol/16777220/14017677/CursorDataID-10.xml
                    this file has the same content:
                    <prop.list>
                    <prop.pair>
                    </prop.pair>
                    <prop.pair>
                    <key>kHotSpot</key>
                    <array>
                    </array>
                    </prop.pair>
                    </prop.list>
                    </prop.map>
                    • 7. Re: InDesign CS5.5 on OSX 10.9.1 suddenly crashes at startup
                      If you changed versions of the OS (going from 10.8 to 10.9, for example). you should uninstall and reinstall. You should probably go ahead and do that anyway as it's likely to take less time than you're going to spend tracking things down.
                      • 8. Re: InDesign CS5.5 on OSX 10.9.1 suddenly crashes at startup
                        Nathan Durai
                        Matthieu
                        How did you generarate the crash log for Indesign?? My indesign CS6 on windows freezes/crashes often at different times.
                        Is yours a release version or debug version??
                        thanks
                        Nathan
                        • 9. Re: InDesign CS5.5 on OSX 10.9.1 suddenly crashes at startup
                          Mac has better error reporting than Windows and crash logs are generated at the system level. There is no equivalent crash log generated in XP or Windows 7, not sure if that's changed for Windows 8.
                          • 10. Re: InDesign CS5.5 on OSX 10.9.1 suddenly crashes at startup
                            @Nathan:
                            It is as Peter sais: it comes with the operating system.
                            On Windows you may be able to gather more information from the event log:
                            control panel --> administrative tools --> event viewer
                            • 11. Re: InDesign CS5.5 on OSX 10.9.1 suddenly crashes at startup
                              I updated the OS to 10.9.2, and now the problems are gone.
                              Apparently was an OSX issue.
                              Thanks for thinking along everybody!
