I have had no other issues with CC products apart from this.
I have Adobe CS5.5 installed, is this the reason why it wont start?
Thanks.
Same problem
No, having an older version of Adobe installed doesn't usually cause any problems. I have several versions from AA 1.5 upto and including Audition CC and they all work quite happily alongside each other on the same PC.
Are you both using Audition on PC or Mac systems? More information would be useful including which version of Operating System are you running and what sort of audio interface?
Im running a pc with windows 7. I have'nt a clue what type of audio interface I'm running.
basically i have downloaded the trival version and as soon as i went to open it came up with this
I am using windows 7. I have already got dreawweaver and photoshop and fireworks they have all worked
I now have the same problem with Adobe Flash and Adobe Premiere Pro CC. They are all trials, as i dont want to have to pay for them if they are no good for me. so please help
This is sometimes caused by a corrupted or mis-installed Visual C++ runtime library, which is a Windows library that provides support for applications. This is usually installed by the application if it's not already available.
If you open Control Panel > Programs and Features, how many items do you see labeled "Microsoft Visual C++ #### Redistributable" ?
I have 11
There's a thread in the Premiere Pro forum about the same issue: http://forums.adobe.com/message/4998719
I would recommend uninstalling the Microsoft Visual c++ Redistributable 2010 x64 item, which both Audition and Premiere (and other applications) require, and reinstall it clean. You can download it directly from Microsoft by visiting http://www.microsoft.com/en-us/download/details.aspx?id=14632
So delete all of them files that I currently have and replace with what I download from windows?
Sorry, no. Just uninstall the items "Microsoft Visual C++ 2010 x64 Redistributable" and ".. Runtime" if you have both. The Redistributable package contains both, and I suspect there may be some conflicts if multiple variations of the same version/package are installed as it appears in Charlie_Creese's screenshot.
I have uninstalled REDISTRIBUATLE x64 do i do the same for designtime x64, runtime x64 and what about the x86
I downloaded and installed from the link and this is what I have now. But now adobe audtion still wont work. Have I done something wrong or missed something. I appologise I'm not computer or tech savy at all!
Still not working either
Ok. I recommend visiting http://helpx.adobe.com/contact.html?product=creative-cloud&topic=downloading-updating-and-installing... and chatting with an Adobe Technical Support rep who can walk you through troubleshooting this problem in more depth.
Okay, thank you for your help!
Hannah,
I saw you're still having this issue. Can you send me an e-mail to audbugs@adobe.com and we'll see if we can figure this out?
Thanks.
One thing that's occurred to me - exactly how many copies of the redistributable does one need? Can't help thinking that rather less of them might not be a bad thing...
Which is a roundabout way of saying to try ditching all of them, and just installing single 32- and 64- bit versions, perhaps?
I have started to uninstal the microsoft visual c ++ 2010 redistrubutavble package x64
Not sure which ones but here are all
