9 Replies Latest reply on Mar 4, 2014 9:11 AM by HeyMikey
    How do I show what styles look like?
    riott.girl Level 1
      I received a file that has over 50 different styles loaded.
      I'd like to see what the styles look like.
      Is there a way to show this without having to apply each?  A sort of index of styles, sort of what it looks like when viewing fonts in a viewer.
      InDesign CS5.
      Thanks.
        • 1. Re: How do I show what styles look like?
          You can script it. If you are using OSX this AppleScript adds a page at the end of the active document with a list of document paragraph styles styled:
          tell application "Adobe InDesign CS6"
              set stylePage to make page at end of active document
              tell stylePage
                  set t to make text frame with properties {geometric bounds:{0.5, 0.5, 10.5, 8}}
                  set text column count of text frame preferences of t to 3
              end tell
              set s to every paragraph style of active document
              repeat with x in s
                  set sname to name of x
                  set contents of last insertion point of t to return & return & sname
                  set applied paragraph style of paragraph (count of paragraphs of t) of t to x
              end repeat
          end tell
          • 2. Re: How do I show what styles look like?
            @riott_girl – there is an ExtendScript script (for  Windows and OSX) by Kasyan Servetsky, that  lists the properties and values of every paragraph style in a CSV or TEXT file list:
            Kasyan Servetsky
            Export paragraph style description settings
            Script for InDesign CS3–6. Version 3.5
            http://kasyan.ho.com.ua/export_styles_description_settings_to_csv.html
            Uwe
            • 3. Re: How do I show what styles look like?
              Uwe, I think the OP wants to see the styles applied to text rather than a list of properties. So my script does this:
              • 4. Re: How do I show what styles look like?
                Obi-wan Kenobi Level 5
                Hi Rob,
                Cool [AS]. Can you do the same thing with character styles?
                • 5. Re: How do I show what styles look like?
                  Yes. And you might want some extra text for the paragraph styles, which I've included in this version:
                  set pText to ":  The quick brown fox jumps"
                      tell stylePage
                          set text column count of text frame preferences of t to 2
                      end tell
                      set contents of last insertion point of t to "Paragraph Styles"
                      set applied paragraph style of paragraph (count of paragraphs of t) of t to item 2 of s
                      repeat with x in s
                          set contents of last insertion point of t to return & return & sname & pText
                      end repeat
                      set c to every character style of active document
                      set contents of last insertion point of t to return & return & return & return & "Character Styles"
                      repeat with i in c
                          set cname to name of i
                          set contents of last insertion point of t to return & return & cname
                          set applied character style of every word of paragraph (count of paragraphs of t) of t to i
                      end repeat
                  end tell
                  Message was edited by: Rob Day
                  • 6. Re: How do I show what styles look like?
                    riott.girl Level 1
                    Thanks Rob.  Would you happen to have this for Windows?
                    It is exatly what I'm after.
                    • 7. Re: How do I show what styles look like?
                      Rob,
                      You're cool! Thanks.
                      I am putting it now in my ID Scripts folder.
                      • 8. Re: How do I show what styles look like?
                        You'd have to get it translated to JavaScript. You could ask in the Scripting forum—the code is pretty simple.
                        • 9. Re: How do I show what styles look like?
                          HeyMikey Level 3
                          Hey Rob, this is great! I've got it in my Scripts folder now, just tried it and it's gonna be a lifesaver!
                          Cheers!
                          -Mikey
