12 Replies Latest reply on Mar 18, 2014 3:41 AM by Laubender
    [ID-CS5][JS] Pasting into a rectangle at same position
    johnD
      I am trying to make a script and have been successful to a point...
      I have content on a layer labeled "copy-layer"
      Also, rectangles and polygons marking areas of copy-layer on another layer called "export-layer"
      I want to copy all of the content from copy-layer inot each individual shape from  export-layer
      This will help me export selection(i.e. individual shape) to JPEG.
      I struggling to pasteinto() theses shapes and locate copied content at same position as it was on copy-layer.
      Any help will be appreciated.
      Thank You
      johnD
        • 1. Re: [ID-CS5][JS] Pasting into a rectangle at same position
          Jump_Over Level 5
          If your goal is to paste object in same position use object.duplicate() method, i.e.:
          mRectangle.duplicate(app.activeDocument.layers.item("export-layer"));
          Jarek
          • 2. Re: [ID-CS5][JS] Pasting into a rectangle at same position
            @Jarek – yes.
            A "Paste Into" is only possible with the app methods:
            select()
            cut() OR copy()
            pasteInto()
            If you do that in the same document, there is a fair chance it will work.
            If done from document to document, sometimes InDesign is crashing (did some experiments recently with InDesign CS5.5 in this regard).
            Also, if it happens, that source and target are not on the same spread, the pasted into object would be not at the same relative page position as before.
            Just a simple test:
            A double sided document with 3 pages starting on a right page.
            Two simple objects on page 1, a rectangle and an oval, nothing else.
            See screen grabs:
            After Paste In Place oval to rectangle:
            //Working example:
            //One document with one rectangle and one oval on the SAME spread!
            var myDoc = app.documents[0];
            app.select(null);
            app.select(myDoc.ovals[0]);
            app.cut(); //could also be app.copy()
            app.select(null);
            app.select(myDoc.rectangles[0]);
            app.pasteInto();
            app.select(null);
            The result is as expected.
            Now move the rectangle to page 3 with the same position relative to the page.
            Do the test again.
            The result is quite different:
            We now have to move the oval to its former relative position.
            Or we had to move the rectangle to the spread of the oval and after pasteInto move it back to its own spread…
            And you could change the coordinate system of the rulers from by page to by spread or to by spine. No difference.
            If the two objects are on different spreads you'll get something like in the last screen grab.
            Uwe
            • 3. Re: [ID-CS5][JS] Pasting into a rectangle at same position
              And on: even if both objects are on the same page, in the moment  one of the objects do not overlap* the other, with Paste Inside, the position of the pasted object will change to center of the container.
              *It remains to be seen, what that does exactly mean.
              So in any case it's best to write the position of the object that should be pasted inside into a variable and move the object after the paste to that position…
              Uwe
              • 4. Re: [ID-CS5][JS] Pasting into a rectangle at same position
                Marc Autret Level 4
                Thanks Uwe. Good to know.
                Marc
                • 5. Re: [ID-CS5][JS] Pasting into a rectangle at same position
                  johnD Level 1
                  All of you who who posted Thank for opting to help.
                  Sorry was busy at work for the last two weeks
                  Let me post my script and explain again what I want to do and what really happens,
                  @Laubender has placed a finger on the problem,
                  but am not able to resolve my issue
                  I have a page layout
                  The sky blue content is on a master layer
                  The orange polygons are the ones which mark the content which i want to export to jpeg (they are on "Layer 1"). They also have a style applied "exportStyle"
                  Layer 1 concists of images shapes and text.
                  What I want to finally arrive at is
                  Each orange bordered polygon moved to export-layer.
                  Then all items from Layer 1 pasteInto() the orange bordered polygons (sort of like appling a mask in photoshop).
                  But the contents position should be same as it was on Layer 1.
                  This would enable me to select each of the orange bordered polygons individually and export them to JPEG.
                  Then delete the copy & export layers and save document.
                  What really happens is
                  The Layer 1 items are not in same position.
                  They all align to the polygon co-ordinates.
                  I did try to move the pasted contents to the geometricBounds I acquired before pasteInto(),
                  but some elements disappeared.
                  Below is my script
                  var myFile = app.activeDocument;
                  //-----if layer does not exist creates it -------------------------------
                  function GetLayer(myFile,name){
                    var layer = myFile.layers.item(name);
                    if(!layer.isValid){
                      layer = myFile.layers.add({name:name});
                    return layer;
                  var shapes = myFile.pages[0].allPageItems;
                  var exportLayer = GetLayer(myFile,"E-Shape-Layer");
                  var copyLayer = GetLayer(myFile,"Copy-Page-Layer");
                  //------ filters out all items who do not have the style 'exportStyle' applied to it -------
                  for (var i=0; i<shapes.length; i++)
                      if (shapes[i].appliedObjectStyle.name === "exportStyle")
                  shapes[i].itemLayer=exportLayer;
                  var appliedMastr=myFile.pages[0].appliedMaster.name; //gets the master applied to the first page
                  var mastrPageContent = myFile.masterSpreads.itemByName(appliedMastr).pageItems;   //get items of the applied master
                  var mainWorkedLayerItems = myFile.layers.itemByName("Layer 1").pageItems;              //get  items of the main layer
                  app.select(NothingEnum.nothing);
                  mastrLayerItemsGroup = myFile.groups.add(mastrPageContent.everyItem());                  //add the applied master items into a group
                  workdLayerItemsGroup= myFile.groups.add(mainWorkedLayerItems.everyItem());           //add the main layer items into a group
                  mastrLayerItemsGroup.duplicate(copyLayer);        //duplicate the master items group to copy layer
                  workdLayerItemsGroup.duplicate(copyLayer);        //duplicate the main layer group to copy layer
                  copyLayerItems=myFile.layers.itemByName("Copy-Page-Layer").pageItems;                  //get  items of the copy layer
                  copyLIgroup=myFile.groups.add(copyLayerItems.everyItem());                                        //add the copy layer items into a group
                  shapes2=myFile.layers.itemByName("E-Shape-Layer").allPageItems;                              //get all items on export layer (that will be all the polygons )
                  //------- cycles through all shapes on export layer and  pasteInto() the grouped copy layer items in them---------
                  for(var i=0; i<shapes2.length; i++){
                      shapes2[i].select();
                      app.pasteInto();
                  Any and all help is appreciated
                  Thanks!
                  johnD
                  • 7. Re: [ID-CS5][JS] Pasting into a rectangle at same position
                    @John – ah, you changed your comment while I was writing my comment…
                    Uwe
                    • 8. Re: [ID-CS5][JS] Pasting into a rectangle at same position
                      johnD Level 1
                      @Uwe
                      That is exactly what I want to do (with reference to your question in post 6).
                      Thank You.
                      johnD
                      • 9. Re: [ID-CS5][JS] Pasting into a rectangle at same position
                        @John – would the scenario you lined out with your script work, if you do it without the script, just working with UI commands?
                        If you suspect that the position of the pasted groups will change, you'll have to get the x/y position of the original group still unpasted and move() the group pasted inside to that position.
                        That could be done in your last for loop.
                        Not tested:
                        app.select(null);
                            app.pasteInto();
                            //Move group inside shapes2[i]:
                            shapes2[i].groups[0].move([copyLIgroup.geometricBounds[1],[copyLIgroup.geometricBounds[0]]);
                            //Maybe a good idea:
                            app.select(null);
                        Another comment on your output file format: I hope you are aware that JPEG does not support transparant pixels. So exporting an object to JPEG that is not a regular rectangle will get you some white pixels around its shape.
                        Uwe
                        • 10. Re: [ID-CS5][JS] Pasting into a rectangle at same position
                          johnD Level 1
                          @Uwe
                          Yes I am able to do all this in the UI.
                          Getting the geometricBounds of Original Group Did the trick.
                          Shortly I will paste my entire script.
                          johnD
                          • 11. Re: [ID-CS5][JS] Pasting into a rectangle at same position
                            johnD Level 1
                            Hi
                            Thanks All for your time help, especially Uwe
                            Here is what i have worked out.
                            Basically broken the operations to 2 scripts.
                            First to select shapes and run script. This will push selected shapes to the export layer.
                            Second, when ready to do the actual exporting
                            // ===========SCRIPT 1: MOVING SELECTED SHAPES TO E-Shape-Layer =====
                            var myDocument = app.documents.item(0);
                            if(!layer.isValid){   layer = myFile.layers.add({name:name});   }
                                else{
                            myFile.layers.itemByName("E-Shape-Layer").remove();
                              return layer;
                            function GetStyle(myFile,name){
                              var style = myFile.objectStyles.item(name);
                                if(!style.isValid){
                                    style = myFile.objectStyles.add({name:name});
                              return style;
                                app.cut();
                            myDocument.activeLayer = "E-Shape-Layer";
                            app.pasteInPlace();
                                myStyle = GetStyle(myFile,"exportStyle");
                            myStyle.strokeColor=myFile.swatches.itemByName("PT_Gold");
                            myStyle.strokeWeight=1;
                                var shapes = myFile.layers.itemByName("E-Shape-Layer").allPageItems;
                                for(var i=0; i<shapes.length; i++){
                            shapes[i].applyObjectStyle(myStyle);
                            myFile.layers[exportLayer.index].visible=true;
                            myFile.layers[exportLayer.index].locked=true;
                            myFile.layers[exportLayer.index].printable=false;
                            myDocument.activeLayer = "Layer 1";
                            // ===========SCRIPT 2: EXECUTING EXPORT===========================
                            var fileNm = myFile.name.replace(/.[^.]+$/,'');
                            var fileExt= myFile.name.replace(/^.*\./,'');
                              if(!layer.isValid){
                              return layer;
                            function javascript_abort()
                               alert('You did not enter Page Number! \n Process Terminated!!!');
                               exit(0);
                            var FolderNm = Folder("/d/000000/JPEG");*/
                            var pgName=""; pgName=prompt("Please Enter PAGE NAME to export",fileNm);
                            var pgNum=""; pgNum=prompt("Please Enter Page Number to export",);
                            if(isNaN(pgNum)){ javascript_abort(); }
                            var exportLayer = myFile.layers.itemByName("E-Shape-Layer");
                            if(exportLayer.isValid){
                                    var bkupLayer = GetLayer(myFile,"Bkup-Export-Layer");
                                    for (var i=0; i<shapes.length; i++){
                            shapes[i].duplicate(bkupLayer);
                                    var appliedMastr=myFile.pages[pgNum-1].appliedMaster.name;
                            workdLayerItemsGroup = myFile.groups.add(mainWorkedLayerItems.everyItem());
                            copyLIgroup.name = "copyGroupNm";
                                    var gBounds=myFile.groups.itemByName("copyGroupNm").geometricBounds;
                                    app.select(myFile.groups.itemByName("copyGroupNm"));
                                    app.copy();
                            myFile.layers[exportLayer.index].locked=false;
                            app.select(null);
                            shapes[i].select();
                            app.pasteInto();
                            shapes[i].groups[0].move([gBounds[1],gBounds[0]]);
                                        var imgno="";
                                            if(i<10){ imgno=".0"+i;}
                                            else{ imgno="."+i;}
                            shapes[i].exportFile(ExportFormat.JPG, File(FolderFB + "/" + fileNm + imgno + i + ".jpg"), false);
                            app.select(null);
                            myFile.layers.itemByName("Copy-Page-Layer").remove();
                            myFile.layers[bkupLayer.index].visible=true;
                            myFile.layers[bkupLayer.index].locked=false;
                            myFile.layers[bkupLayer.index].printable=false;
                            myFile.layers[bkupLayer.index].name = "E-Shape-Layer";
                            //workdLayerItemsGroup.ungroup();
                                    for(var i=0; i<myFile.groups.length; i++){
                            myFile.groups[i].ungroup();
                            alert("DONE!!");
                            else{
                            alert("No export areas Marked and Applied!");
                            @Uwe
                            ran into a small problem when I was testing these scripts.
                            If I have two pages in document, it will give me an error.
                            Error No 30477, error string: invalid parameter.
                            The line causing the error : workdLayerItemsGroup= myFile.groups.add(mainWorkedLayerItems.everyItem());
                            Any guidance to proceed and resolve scenario is appreciated.
                            Thanks!
                            johnD
                            • 12. Re: [ID-CS5][JS] Pasting into a rectangle at same position
                              @John – without looking deep into ypur code, I think the error is due to the fact that you cannot group objects beyond spreads.
                              A layer is not restricted to a page or a spread. It is document wide*. So you need to build the group from all pageItems on a spread and using that.
                              * The masterSpread is an exception. If you ask for myLayer.pageItems.everyItem() you'll get all first level pageItems on every spread except the ones on masterSpreads.
                              Uwe
