3 Replies Latest reply on Mar 1, 2014 1:08 PM by George_Johnson
    It was suggested I ask my question in this forum regarding texbox attributes
    bjb_jr Level 1
      I am using InDesign and have textboxes placed that require being solid or empty based on the data value from each record. For example if the field value is greater than 10, I need to make the texbox solid, if less than that It needs to be invisible, or blank when printed.
      The data file is a CSV, and the textboxes are setup. I cannot figure out how to script the events that will trigger the textbox to change accordingly. I am familiar with Access and VBA, but in this instance I must work with an existing PDF so Access is out.
      Could someone please show me how to structure the code to make this work, or at least get me started in the right direction?
      Thank you.
      BBJ
