• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Captivate 7 and Powerpoint
New Here ,
Mar 01, 2014 Mar 01, 2014
I am brand new to Captivate and I'm using the trial version.  As a quick start, I decided to import a powerpoint 2010 file.  The file imported fine altho a little slow for me.  Then I previewed the file and noted the sole animation did not work well.  It is a simple "bounce" animation.  So, I tried, the "high fidelity" option to import.  The animation worked a little better but it was still goofy.  The bouncing ball was squashed into an oval shape.
The web site indicated Captivate worked well with powerpoint supporting animations and triggers.  Is this truly the case?  Is there a list of what animations and triggers work?
I read in the forum, that Captivate really doesn't work all that well with PowerPoint.  Any thoughts on this would be appreciated.  Thanks for your help.
TOPICS
Getting started
Views
373
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Mar 02, 2014 Mar 02, 2014
Personally I never would use that work flow, I would add the animation in Captivate, not in PPT. But mostly I start from scratch in Captivate which is a real elearning tool, not a presentation tool like PPT. Captivate is not in the first place a PPT-converter, it is a real authoring tool. There are a lot of PPT-plugins around to convert a PPT if that is your only goal.
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Well, it certainly helps me out to know, I am using a "real authoring tool".
My simple goal was to import a powerpoint into Captivate 7 and have it work correctly, a function Adobe clearly states is available in this "real authoring tool".
Now I will try a different work flow.
Votes
Translate
Translate
Report
Report
Resources
Help resources
