3 Replies Latest reply on Mar 3, 2014 7:26 AM by DavidFdezGlez
    Setting MasterSpread to single-sided page and Page Number
    DavidFdezGlez
      Hello everyone,
      I'm trying to set the Master Spread to single-sided page, and also the page number.
       // height, width, pageNumber are well defined
       var document = app.documents.add();
          with (document.viewPreferences) {
              horizontalMeasurementUnits = MeasurementUnits.POINTS;
              verticalMeasurementUnits = MeasurementUnits.POINTS;
          with (document.documentPreferences){
              pageHeight = height;
              pageWidth = width;
              facingPages = false;
              pagesPerDocument = pageNumber;
        while(document.masterSpreads. item(0).pages.length > 1){
             document.masterSpreads. item(0).pages.item(-1).remove();
          mastertextFrames = document.masterSpreads.item(0).textFrames.add();
          mastertextFrames.geometricBounds=  [(height - 40), (width-40), (height-20), (width -20)];
          mastertextFrames.contents=SpecialCharacters.AUTO_PAGE_NUMBER;
      When I open the document with InDesign, I still can see 2 pages in the A-Master, and also in the first page, the page number is not well positioned.
      Can anyone help please?
      Thanks in advacanced,
        • 1. Re: Setting MasterSpread to single-sided page and Page Number
          Jump_Over Level 5
          Suggest to use documentPreset:
          var
               mPreset = app.documentPresets.add({
                  pageHeight: height,
                  pageWidth: width,
                  facingPages: false,
                  pagesPerDocument: pageNumber
               document = app.documents.add(true, mPreset),
          mPreset.remove();     // or not...
          Jarek
          • 2. Re: Setting MasterSpread to single-sided page and Page Number
            @David – I do not have InDesign Server installed so cannot know if the following is working:
            app.documents.add({
                documentPreferences:{
                    facingPages:false
            If not you can try with app instead of document:
            app.documentPreferences.facingPages = false;
            But be aware that not facing pages is now the default!
            Uwe
            //EDIT: one comma too much in the first snippet. Corrected.
            Message was edited by: Laubender
            • 3. Re: Setting MasterSpread to single-sided page and Page Number
              DavidFdezGlez Level 1
              Hi, thanks
              Finally this worked (Indesign CS6)
              var mPreset = app.documentPresets.add({
                      pageHeight: height,
                      pageWidth: width,
                      facingPages: false,
                      pagesPerDocument: pageNumber,
                  var document = app.documents.add(mPreset);
                  var mastertextFrames = document.masterSpreads.item(0).textFrames.add();
