When using "Store locally": Where is this excactly on the machine?
Or is it on the server, but not using the online functionality?
Thomas
Hi;
The form is "local" in that case, stored on your hard drive, but it is not a single file you can access and use for anything, it is a collection of files that require the FormsCentral application to display as a form. There is a file you can save locally as a Template/backup that you can convert to PDF in Acrobat or import into FormsCentral, from the Design tab "File" - "Export Design File...".
"Export Design File" will save an FCDT file that you can import later and will be exactly like the form you exported it from.
Josh
