3 Replies Latest reply on Mar 3, 2014 9:03 AM by A.T. Romano
    musiques
    gerardgp
      comment ajouter des musiques pour sonoriser les films ?
      Merci
        • 1. Re: musiques
          the_wine_snob Level 9
          Welcome to the forum.
          What version of PrE are you running?
          What OS version are you running it on?
          For general instructions, one would just Import the music file (ideally a PCM/WAV file @ 48KHz 16-bit), then drag it to an empty Audio Track, say Audio Track 2, or 3.
          One could drag to the Soundtrack Audio Track, but that has caused some problems with certain Projects, so I just use an empty "regular" Audio Track.
          Good luck, and if that does not work, or you have any questions on the procedure, just let us know.
          • 2. Re: musiques
            nealeh Level 5
            In v12 you can use the Adobe provided Scores and Sound Effects from the bottom Tool panels. Or you can import your own files into the project as assets and drag them to an audio track (or drag directly to an audio track from Windows Explorer / Mac Finder). PRE11 and earlier used SmartSound instead of Scores.
            Some formats import better than others .wav at 48KHz is best, MP3 is usually OK. Full official list is here  - http://helpx.adobe.com/photoshop-elements/kb/supported-file-formats-premiere-elements.html #main_Audio_File_Formats___Import
            Cheers,
            Neale
            If this post or another user's post resolves the original issue, please mark the posts as correct and/or helpful accordingly. This helps other users with similar trouble get answers to their questions quicker. Thanks.
            • 3. Re: musiques
              A.T. Romano Level 7
              gerardgp
              What version of Premiere Elements are you using and on what computer operating system is it running?
              Are you using primarily iTunes music?
              Thanks.
              ATR
