0 Replies Latest reply on Jun 22, 2006 9:31 PM by Newsgroup_User
    Re: CFLDAP missing attribute or security error
    Level 7
      This is a multi-part message in MIME format.
      --------------030808010109050103050805
      Content-Type: text/plain; charset=UTF-8; format=flowed
      Content-Transfer-Encoding: 7bit
      Thank you for your response... I probably should explain better what
      this code does...
      It queries a data source (DB2 database) for a list of about 2000 names
      (specifically their Employee number).
      Then it queries the MS Active directory for a list of anyone who has an
      attribute of employeeNumber that
      is not an empty string.
      Next, it uses a QofQ to join the two record sets together, tossing out
      any records that do not match from
      both of the data sources.
      Then I loop over that list of employees adding them into a group.
      This operation dos nothing to modify a users password.
      D.
      Ian Skinner wrote:
      > This came off of another CF related list. Not sure if it applies to
      > your situation or not.
      > * You cannot change passwords unless you have a SSL cert setup for the
      > CF server and the AD domain controller.
      > I have not first hand experience with this, so all I can offer is to
      > pass along the above comment.
      > dnagel wrote:
      >> So, this is the advanced techniques group... and no one feels the
      >> least bit challenged?
      >> Theres got to be someone who enjoys delving into LDAP out there...
      >> D.
      Content-Type: text/html; charset=UTF-8
      Content-Transfer-Encoding: 8bit
      <!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
      <html>
      <head>
      <meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
      </head>
      <body bgcolor="#ffffff" text="#336666">
      Thank you for your response...�� I probably should explain better what
      this code does...<br>
      <br>
      (specifically their Employee number).<br>
      <br>
      attribute of employeeNumber that<br>
      is not an empty string.<br>
      <br>
      any records that do not match from<br>
      both of the data sources.<br>
      <br>
      Then I loop over that list of employees adding them into a group.<br>
      <br>
      This operation dos nothing to modify a users password.<br>
      <br>
      Thanks,<br>
      <br>
      D.<br>
      <br>
      <br>
      <br>
      Ian Skinner wrote:
      <blockquote cite="mide7f6op$4pd$2@forums.macromedia.com" type="cite">This
      came off of another CF related list.�� Not sure if it applies to your
      situation or not.
      <br>
      <br>
      <br>
      <br>
      <br>
      <br>
      dnagel wrote:
      <br>
      <blockquote type="cite">So, this is the advanced techniques group...
      and no one feels the least bit challenged?
      <br>
      <br>
      <br>
      D.
      <br>
      </blockquote>
      </blockquote>
      <br>
      </body>
      </html>
      --------------030808010109050103050805--
