3 Replies Latest reply on Mar 7, 2014 11:32 PM by hemanthR
    loop code x times with counting parameter / variable
    cyclux
      Hi there,
      due to my lack of knowledge about coding JavaScript, I'm stuck here and I can't find the right way by google and try and error..
      I want to loop a code / function .. let's say 100 times and each time one parameter or variable is counted up.
      I found "for"-loops and some with a counter.. but I coudn't get it to work in Edge Animate..
      Here is a fragment of the code I want to loop ->
      $.get("http://......./publish/web/output1.php?id="+Num, {}, function(ask, code) {
      switch(ask) {
              case '9':
          sym.$("leaf"+Num).show();
          var leaf = sym.$("leaf"+Num);   // How can I count the setting variable? "var leaf+Num = ... " doesn't work I guess..
          TweenMax.to(leaf+Num, 1, {scale:1.5});
          TweenMax.to(leaf+Num, 2, {rotation:rand, ease:"Power1.easeInOut", yoyo:true, repeat:-1});
          sym.randfunc();
        break;
      Thanks for help!
        • 1. Re: loop code x times with counting parameter / variable
          hemanthR Adobe Employee
          My guess is your are running into closure scoping issue of JS in your callback function like the one mentioned here
          http://stackoverflow.com/questions/3572480/please-explain-the-use-of-javascript-closures-i n-loops
          See if this work for you
          (function(Num){
          return function(ask, code) {
          switch(ask) {
                  case '9':
              sym.randfunc();
            break;
          })(Num)
          • 2. Re: loop code x times with counting parameter / variable
            cyclux Level 1
            Thanks a lot rhemanthkumar! You pointed in the right direction..
            This is my code now..It works fine, but if you see potential for optimization please tell me
            for (i=0;i<150;i++){
            $.get("http://127.0.0.1/wordpress/tree/publish/web/output1.php?id="+i, {},
            (function(i){
              switch(ask) {
                    case '0':
                        sym.$("leaf"+i).hide();
                sym.randfunc();
            break;
                    case '1':
                sym.$("leaf"+i).show();
                    TweenMax.to(sym.$("leaf"+i), 1, {scale:1});
                TweenMax.to(sym.$("leaf"+i), 2.5, {rotation:rand, ease:"Power1.easeInOut", yoyo:true, repeat:-1});
                sym.randfunc();
            break;
                    case '2':
                    TweenMax.to(sym.$("leaf"+i), 1, {scale:1.25});
                sym.randfunc();
            break;
                    case '3':
                TweenMax.to(sym.$("leaf"+i), 1, {scale:1.5});
                sym.randfunc();
                 break;
            })(i)
            • 3. Re: loop code x times with counting parameter / variable
              Sorry will not be able to help yout out much in optimizing the above code as I am not much of a JS expert and more over no sure of in what context your code being run.
