4 Replies Latest reply: Mar 8, 2014 7:50 AM by jackblackweb RSS
    Repeat With + Property List + leaderboard / rank of best scores
    MAC800 Community Member
      Hello I have a List question
      I am stuck writing this line of code
      He is my project
      I need to "rank" in descending order 50 game contestants
      The names of the contestants are in fields "contestants1" to "contestants50"
      The scores of the contestants are in fields "score1" to "score50"
      A property list will have or be created ? Yes? No?
      Then that list will have to be sorted with "best score" to "lowest score" and the "contestant" name with the score in the list. Example if Brandon ends up being in 32nd place with 344 points  the list would have the player name and result.
      **I am familiar with max() however, that is only going to give me one result .. I need them reordered descending
      Lastly the really easy part the sorted list placed in a filed cast member "FinalResults"
      Example member("FinalResults").text = string(aList)
        • 1. Re: Repeat With + Property List + leaderboard / rank of best scores
          jackblackweb Community Member
          -- Message Window
          thisNumberList = ["5", "2", "1", "4", "3"]
          put thisNumberList
          -- ["5", "2", "1", "4", "3"]
          thisNumberList.sort()
          put thisNumberList
          -- ["1", "2", "3", "4", "5"]
          If more is needed let me know. Love writing code.
          Jack
          • 2. Re: Repeat With + Property List + leaderboard / rank of best scores
            Hey thanks for the reply
            How would you go about sorting in descending order. "Sort" seems to order them ascending
            • 3. Re: Repeat With + Property List + leaderboard / rank of best scores
              Dee McDee Community Member
              You would need to do something like this:
              on mouseUp me
                newNumberList = []
                repeat with i = thisNumberList.count() down to 1
                  newNumberList.add(thisNumberList[i])
                end repeat
                put newNumberList
              end mouseUp
              -- ["5", "4", "3", "2", "1"]
              • 4. Re: Repeat With + Property List + leaderboard / rank of best scores
                Hey MAC800,
                Heres a way using text strings and comma separated values to sort scores and contestant names for display.
                Link to sample movie:
                http://www.theclickpoint.com/DIRECTOR FORUM/sortScores.dir
                Screen shot of display:
                Code:
                on mouseDown me
                  -- here a string of comma separated scores is created "scores"
                  scores = ""
                  firstScoreMemberNumber = member("score1").number
                  lastScoreMemberNumber = member("score50").number
                  repeat with scoreMemberNumber = firstScoreMemberNumber to lastScoreMemberNumber
                    if member(scoreMemberNumber).text > "" then -- avoid error
                      scoreToAdd = string(member(scoreMemberNumber).text).value
                      scores = scores&scoreToAdd&","
                    end if
                  end repeat
                  -- delete last comma to avoid error
                  if scores.char[scores.char.count] = "," then delete scores.char[scores.char.count]
                  -- put scores
                  -- "22,59,67,62,77,84,98,22,73,99,79,62,84,69,61,77,64,84,89,99"
                  -- here a string of comma separated contestant names is created "names"
                  names = ""
                  firstScoreMemberName = member("contestants1").number
                  lastScoreMemberName = member("contestants50").number
                  repeat with scoreMemberName = firstScoreMemberName to lastScoreMemberName
                    if member(scoreMemberName).text > "" then -- avoid error
                      nameToAdd = member(scoreMemberName).text
                      names = names&nameToAdd&","
                    end if
                  end repeat
                  if names.char[names.char.count] = "," then delete names.char[names.char.count]
                  -- put names
                  -- "Bob,John,Susie,Paul,Judie,Ray,Chris,Jose,Katie,Quen,Arnold,Betty,Mary,Marlo,Julio,Ben,Ke vin,Matthew,Barack,George"
                  -- here the contestants name and score are placed on the line number of member("step1").text corresponding to the score value
                  -- for example, if the score is 20 the contestants name and score are placed on line 20 (separated by a colon &SPACE)
                  -- if contestant scores match they are placed on the same line separated by a comma
                  member("step1").text = ""
                  repeat with zxc = 1 to scores.item.count
                    member("step1").line[string(scores.item[zxc]).value] = member("step1").line[string(scores.item[zxc]).value]&names.item[zxc]&":"&SPACE&scores.ite m[zxc]&","
                  end repeat
                  -- here a comma separated string of the contestants names and scores is created
                  step2 = ""
                  repeat with zxc = 1 to member("step1").line.count
                    if member("step1").line[zxc] > "" then
                      step2 = step2&member("step1").line[zxc]
                    end if
                  end repeat
                  if step2.char[step2.char.count] = "," then delete step2.char[step2.char.count]
                  -- put step2
                  -- "Bob: 22,Jose: 22,John: 59,Julio: 61,Paul: 62,Betty: 62,Kevin: 64,Susie: 67,Marlo: 69,Katie: 73,Judie: 77,Ben: 77,Arnold: 79,Ray: 84,Mary: 84,Matthew: 84,Barack: 89,Chris: 98,Quen: 99,George: 99"
                  -- here the contestants name and score are copied as items to member("displayScores").text
                  member("displayScores").text = ""
                  repeat with zxc = 1 to step2.item.count
                    member("displayScores").text = member("displayScores").text&step2.item[zxc]&RETURN
                  end repeat
                end
