1 Reply Latest reply: Mar 4, 2014 12:19 AM by Liam Dilley RSS
    Help with tweaking blog and webform built in Adobe Muse
    justasking506 Community Member
      Hi there.
      A client of mine had a 3rd party do a re-design (in Adobe Muse) of their current site in BC. Managed to get most of the re-design all launched except for a couple of tweaks that have been giving me major headaches.
      Firstly, is it possible to edit the site that was built in Muse directly from BC itself and not Muse? I don't have a Muse subscription.
      If so, I need help with the following that I have tried to tweak myself, but just can't find out how. BTW I am not a developer but muddle my way around editing existing code etc etc.
      1. On the contact us page, I need to add an additional field to the webform. A radio button question: "preferred contact method". Phone or email. I know how to add the field to the webform in BC. Apparently Muse forms don't support radio buttons? Anyway, I can't figure out how to edit the source on the contact page  to include the fields that I add to the webform.
      2. Some minor tweaks to the layout of the blog page. I need to make the horizontal and vertical lines meet up and not have a space. Also, the left column width needs to be decreased and the right column width increased. Basically I need the current live blog http://www.robertsonburns.com.au/blah-blog to look like the previously coded muse blog (which is not live) http://robertsonburns-test5.businesscatalyst.com/blah.html which it does, except for these two minor issues.
      Would appreciate anyone's help and/or advice.
      Thanks.
        • 1. Re: Help with tweaking blog and webform built in Adobe Muse
          Liam Dilley CommunityMVP
          Hey there,
          Yes you just go to the site either via... site.buisnesscatalyst.com/admin or livesite.com/admin
          Once you do that you can login. It depends how it was built though. Properly a site will have content holders and templates and the pages just hold the content. A user can go to those pages, webapps, blogs (dependng on the plan and build of the site) can edit that content.
          Muse is not the best in terms of handling that and making updates, I am aware the Team updated Muse to handle fetching updates etc though but there is a note of caution on that stil though.
          1. What is the plan of the site? If it is just a CC site then there is no web form manager with that plan of BC. You will have to edit and update the form built in Muse.
          If it is on a plan that supports web forms it also depends on how you built it. If in Muse you should be able to just update the form in Muse I think and it posts into the system to update. If not then you need to go into the admin and web form manager and edit the html to make changes. This depends though if the form was inserted as a module, if not you need to navigate to the template or page and update it there once you have added the new fields to the form under the web form itself.
          2. Layouts are managed via SFTP under the folder Layouts or in the admin under Module Templates in the main menu and Blog layouts.
