1 Reply Latest reply on Mar 4, 2014 9:29 AM by Todd_Kopriva
    Texture Memory/Multiprocessing
    Nightjar Level 1
      In the Preview menu there is an option for "Texture Memory". What exactly is it for an how high should I set it?
      (I can only go up to 2900MB eventhough I have a 4 GB Card, is that normal?)
      In the multiprocessing menu I can enable "Render multiple frames simultaniously" --> I guess that speeds
      op my work flow. Ho high should I set "Ram Allocation per backgorund CPU"? Defaul is 4 GB
      Thanks for helping.
      Cheers
      System:
      Windows 8.1 64-bit
      Intel i7 4930K
      Gigabyte GTX 770 4GB
      ASUS P9X79
      32GB Gforce 2133Mhz RAM
      Corsair H100i water Cooling
      Coolermaster 850 W
      250 GB SSD for OS and Programms
        • 1. Re: Texture Memory/Multiprocessing
          Todd_Kopriva Level 8
          Regarding what texture memory is, see this.
          The setting within After Effects is limited to a fraction of the total VRAM on your GPU because the VRAM is also needed for other things (e.g., your monitor, other applications using the GPU). A good rule of thumb is to set the texture memory for After Effects to 70% of the VRAM if After Effects is the only GPU-heavy application that you're using.
          See this:
          "FAQ: What are optimum memory settings for best performance in After Effects?"
